Problem Including Bootloader Code in Application Program
igortab
PostPosted: Mon Jun 09, 2014 10:30 pm    Post subject: Problem Including Bootloader Code in Application Program Reply with quote
I want to include a compiled bootloader code in to an application program.
This allows factory programming of both in one go as oppose to programming a bootloader and then bootloading the application program
I have been doing this for years with Atmega chips like this:
$Boot=$F800
$Inc BootLoader,NoSize,"My_BootLoader.bin"
(My_BootLoader.bin file is a binary image of bootloader code only, compiled with Bascom AVR).
However, this doesn't work with Xmega 256A3U:
$Boot=$20000
I have also tried:
$RomStart=$20000
All I need the compiler to do is to place the code from My_BootLoader.bin file at location $20000
If anyone can help, it would be much appreciated.
PostPosted: Tue Jun 10, 2014 9:22 am    Post subject: Reply with quote
you need to add :
! .ORG $the WORD address of the loader
'put the $Inc here
igortab
PostPosted: Tue Jun 10, 2014 11:26 am    Post subject: Reply with quote
Thank you for your help Mark.
Unfortunately, it didn't quite work. While the compiler placed the bootloader code at the right address,
it also placed a lot of data, including application program constants, after the bootloader code.
It also generated an error message: "Program will overwrite bootloader...." as the compiler is not aware
that the code following ! .ORG $20000 is a bootloader code.
I have tested the code with Ver 2.0.7.7 and it works fine with Atmega chips:
$Boot=$F800
Is there a reason why it shouldn't work with Xmega chips?
PostPosted: Tue Jun 10, 2014 12:10 pm    Post subject: Reply with quote
Did you use the $LOADERSIZE = xxx option in your main program?
igortab
PostPosted: Tue Jun 10, 2014 1:24 pm    Post subject: Reply with quote
Just tried using $LoaderSize in main program but it made no difference.
It's not the error that's the problem as the compiler still generates HEX and BIN files.
It's the fact that the compiler stores constants and other data from the main program
after the bootloader code. This makes the total size of the file bigger than can fit in to flash.
This makes sense (to me) as the compiler is not aware that code following $20000 is a bootloader
and treats it as part of the main program.
PostPosted: Tue Jun 10, 2014 1:31 pm    Post subject: Reply with quote
please post an example that works for you with atmega. (with all files).
and also a sample for xmega. the inc file can be rubbish, and the main program can be minimal, but i need some real code to look at that contains your used settings.
igortab
PostPosted: Wed Jun 11, 2014 8:06 pm    Post subject: Reply with quote
Example files attached.
Please note how "Boot_ATmega128.bas" correctly generates output binary and hex files and "Boot_Xmega256A3U.bas" does not.
Best regards.
PostPosted: Wed Jun 11, 2014 9:00 pm    Post subject: Reply with quote
The combined use of the old $Boot and $Inc is very nice.
I found the problem and changed it. it will be in the next update.
as a workaround you can merge the hex files.
Duesentrieb72
PostPosted: Fri Feb 27, 2015 9:24 am    Post subject: Reply with quote
Hello Mark,
I'm sorry to ask, but I didn't understand how to include BootLoader code in aplication program right... Sad
I compiled the BootLoader and have the .bin / .hex of it.
Next I put this at the beginning of my application:
$loader = &H30000 ' adress eg. datasheet for ATXmega384C3
$inc Bootloader , Nosize , "MA2_Front_Bootloader_2.bin"
This gives the Error
Error : 344 Line : 2359 Program will overwrite bootloader [ 392854 too long] , in File : C:\PROGRAM FILES (X86)\MCS ELECTRONICS\BASCOM-AVR\LIB\FP_TRIG.LBX
Error : 80 Line : 1360 Code does not fit into target chip , in File : C:\PROGRAM FILES (X86)\MCS ELECTRONICS\BASCOM-AVR\LIB\FP_TRIG.LBX
If I merge the BootLoader code manualy in the bin-file at the right position, everything is fine and works.
But it would be very nice to include the BootLoader automaticaly
µC = ATXmega384C3
Compiler version :2.0.7.8
Compiler build :2.0.7.8.001
IDE version :2.0.7.8.001
Thanks a lot,
Düsentrieb72
igortab
PostPosted: Fri Feb 27, 2015 3:41 pm    Post subject: Reply with quote
Put these 2 lines at the very end of your program.
$Boot=$XXXX (XXXX = Bootloader start address in uC memory)
This is how it used to work.
Igor Tabakov
PostPosted: Fri Feb 27, 2015 4:08 pm    Post subject: Reply with quote
exact, have a look at Igors sample that he attached earlier.
Duesentrieb72
PostPosted: Fri Feb 27, 2015 4:19 pm    Post subject: Reply with quote
Hi Igor and Mark,
thanks a lot for your fast reply.
It works... Very Happy
Duesentrieb72
hzz
PostPosted: Sat Jun 08, 2019 12:18 am    Post subject: Including the bootloader with $Boot and $Inc Reply with quote
I have tried to include the compiler as indicated in this thread with version 2.0.8.1 and get the error:
Error : 344 Line : 200 Program will overwrite bootloader [ 256840 too long] , in File : D:\DESARROLLO\Ei_2.26\Main.bas
Just want to know if problem has not been solved in 2.0.8.1 or am I doing something wrong.
