dk_akj
Posted: Fri May 10, 2019 9:44 pm Post subject: Memory overflow |
Having a strange problem with my program, think its a memory overflow somewhere.
If I have these variables:
Dim v1 As byte
Dim v2 As byte
dim v3 as string * 10
dim v4 as string * 10
if v1 is assigned a value above 255, will it always make overflow into v2?
if v3 is asigned "hello bascom" will that overflow into v4
or is it random the overflow goes?
Hope this makes sense, difficult to explain for me
Anders
Posted: Sat May 11, 2019 12:31 am Post subject: |
You will get compiler errors if you just attempt to do something like
v1 = 300
v3 = "a123456789bcdef"
The first will cause error 49 - "Variable does not fit into byte"
the second will cause error 119 - "constant too big to fit in string"
However you will not get a compiler error if you do something like
Dim b1 As byte
Dim b2 As byte
Dim b3 as byte
dim b4 as byte
dim s5 as string * 10
dim s6 as string * 10
dim s7 as string * 10
dim s8 as string * 10
b1 = 200
b2 = 200
b3 = b1 + b2
print "b3 ";b3
print "b4 ";b4
s5 = "a12345678"
s6= "b12345678"
s7 = s5 + s6
print "s7 ";s7
print "s8 ";s8
Note that I have prefixed the names with indicators to tell me what the variable type is, b for byte, s for string
This means nothing to the compiler, but a lot to you when you are looking at the code later and wondering what type each variable is !
The numerics will work as expected:
b3 will end up with the value of 144, which is 400 truncated to 8 bits ( 1 byte )
b4 will not be affected - left at zero
The strings however will do really bad things
You wil get s7 = "a12345678b12345678"
and s8 = "2345678"
ie s7 will get the full concatenated string, and s8 will get the piece of that starting at the 11th position in s7 ! If you read up about how strings are formed and used in the Bascom Help you may see why this happens.
A good way of exploring this is to use the Bascom simulator, and try things out.
You also should always put a $regfile and the stack allocations in your code and examples, else no one knows what processor you are setting up for, and it matters ! Something like:
$regfile = "M64def.dat"
$Crystal=4000000
$hwstack=40
$swstack=16
$framesize=32
Its quite likely that what you are seeing as "memory overflow" is in fact stack overflow, by not setting the $swstack and $framesize allocations big enough. This can cause all sorts of wierd errors, and even processor crashes and restarts. _________________ Adrian Jansen
dk_akj
Posted: Sat May 11, 2019 9:34 am Post subject: |
Hi Adrian,
Thanks for taking time to reply
I have the regfile and hw stack in code:
$regfile = "m128def.dat"
$crystal = 3686400
$swstack = 512
$hwstack = 512
$framesize = 100
Code is for a GSM remote, using a lot of strings up to ~150 chars thats why I have those big stacks, isnt that correct when working with long strings and subs HW and SW stack should be big?
I'll continue chasing the root cause of my problem
Thanks again
Anders |
Posted: Sat May 11, 2019 2:33 pm Post subject: |
have a look at the code explorer info. it can show the stack space. it is a minimum. but it gives an idea.
all temp space goes in the the framespace so that should be large enough.
so this :
Code: | call sub1
end
sub sub1()
local s as string * 100
call sub2
end sub
sub sub2()
local s as string * 50
'HERE the frame uses 100 + 50 is 150
end sub
will use already 150 bytes.
the code explorer will make this visible. _________________ Mark |
Posted: Sat May 11, 2019 2:36 pm Post subject: |
dk_akj wrote: | I'll continue chasing the root cause of my problem |
The problem sits in front of your screen and is difficult to chase.
Quote: | if v1 is assigned a value above 255, will it always make overflow into v2?
if v3 is asigned "hello bascom" will that overflow into v4 |
If you don't know the difference how a byte overturns and an array overflows, I'd say: back to basics. |
dk_akj
Posted: Sun May 12, 2019 10:28 am Post subject: |
Mark, thanks for the tips!
MWS, wish I was as clever as you....
Anders |
Posted: Sun May 12, 2019 11:08 am Post subject: |
dk_akj wrote: | MWS, wish I was as clever as you.... |
Not sure if learning the basics of owns work can be already qualified as 'clever', however not doing so in times when such information is widely and easily available, can be qualified as lazy. |
