NOKIA-3310/5110 LCD library
Goto page Previous  1, 2, 3, 4, 5, 6, 7
Mrshilov
Bascom LCD Guru
PostPosted: Sat Jun 11, 2016 12:17 am    Post subject: Reply with quote
I check library on Atxmega256A3BU with this config:
$regfile = "xm256a3budef.dat"
$crystal = 32000000
$hwstack = 100
$swstack = 100
$framesize = 100
Const Mul_pll = _xtal / 2000000
Config Osc = Enabled , Pllosc = Enabled , Pllsource = Rc2mhz , Pllmul = Mul_pll
$lib "glcd-Nokia3310.lib"
Config Vport3 = F
Config Portf = Output
Config Graphlcd = 128x64sed , A0 = Port3.2 , Si = Port3.3 , Sclk = Port3.4
Const Contrast_lcd = 68
Const Negative_lcd = 0                                      ' Inverting screen
Const Rotate_lcd = 0                                        ' Rotate screen to 180
It starts and works fine up to 50MHz. For 52MHz and higher it need to add delay in "_gwrite_datamisc" routine:
_gwrite_datamisc:
  push r23
*#If varexist("_GLCD_PORT_CS1")
*  cbi _GLCD_PORT_CS1,_glcd_cs1         ; enable chip -  CS=0
#Endif
  nop      ; ---------- added delay !!!!!!!!
  ldi r25,8                             ; 8 bits
_gwrite_datamisc8:
Maybe your LCD slower than my and need this delay (you can use "@genus(1)" against "nop"). Also try to increase existed delays "@genus(1)" to "@genus(2)" or more.
noley
PostPosted: Tue Oct 11, 2016 5:55 am    Post subject: Help with the library glcd-nokia3310 Reply with quote
Hey.
I started playing with Bascom. I found a thread with a library for operating the display of nokia 3310. I based on the library to try to construct a bar graph. I tried pset command, line, lcd, locate, but do not work. I'm working on a demo version 2.0.7.3.
Could I ask for help in pushing it further?
Hitwert
PostPosted: Wed Nov 30, 2016 2:48 pm    Post subject: Reply with quote
am I just terribly blind or is the file no longer attatched to this thread? I think the former is the case. Where can i find the download for the zip?
Thank you very much.
Well stupid me. You got to be logged in to see the download. Never mind me asking.
kapest
PostPosted: Wed Mar 20, 2019 5:38 pm    Post subject: Were can i find glcd-Nokia3310.lib Reply with quote
I find the Link. The Problem, I was loggin but not in the new way. I register in my Profile and now I'm glad. Smile
Hello,
I looked for glcd-Nokia3310.lib some hour in Bascom-Forum and in the Internet, but I did'nt find a download-Link.
Pse Help
Tnx
kapest
O-Family
PostPosted: Tue Apr 23, 2019 2:43 am    Post subject: Library bug fixes. Reply with quote
"glcd-Nokia3310.lib" has a defect that the dot on the right edge is missing when the screen is rotated 180 degrees.
This has been fixed.
Underline option added to the "LCDAT" instruction. [2:Solid , 3:dotted]
Lcdat 1 , 1 , "Nokia5110 TEST" , 2
Lcdat 2 , 7 , "by BASCOM-AVR"
Lcdat 4 , 1 , "ABCDEFGHIJKLMN"
Lcdat 5 , 1 , "01234567890123" , 3
Lcdat 6 , 31 , "O-Family" , 1
Postscript
When setting the contrast and then using the [CLS] command, there was a bug that the screen disappeared.
matjazs
PostPosted: Fri May 10, 2019 12:39 pm    Post subject: Reply with quote
Hello.
I'm trying to connect HX1230 LCD display on ATXMEGA128A3U.
I have two different hardware with diferent connection. When I use configuration (my first hardware):
Config Vport3 = F
$lib "glcd-Nokia1100.lib"
Config Graphlcd = 128x64sed , Si = Port3.5 , Sclk = Port3.6 , Cs1 = Port3.1 , Rst = Port3.0
it work OK.
When I do so (second hardware):
Config Vport0 = A , Vport1 = C , Vport2 = D
'Config Port0.2 = Output
'Config Port1.0 = Output
'Config Port1.1 = Output
'Config Port2.1 = Output
Config Graphlcd = 128x64sed , Si = Port0.2 , Rst = Port1.0 , Cs1 = Port1.1 , Sclk = Port2.1
it doesn't work.
Could me someone explane, is it something worng, that I use Vport0, Vport1, Vport2 (3 times) and not only ones Vport3? In manual is written, that it is possible.
I checked hardware many times and I can say, that all is OK.
Regards, Matjaz
There is my test code:
$regfile = "xm128a3udef.dat"
$crystal = 32000000
$hwstack = 512
$swstack = 512
$framesize = 512
'$lib "xmega.lib"
$external _xmegafix_clear
$external _xmegafix_rol_r1014
'-Oscilator ----------------------------------------------------------------------
Config Osc = Enabled , Extosc = Enabled , Pllosc = Enabled , Range = 12mhz_16mhz , Startup = Xtal_16kclk , Pllsource = Extclock , Plldiv2 = Disabled , Pllmul = 2
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled
'-RTC-----------------------------------------------------------------------------
Config Clock = Soft , Rtc = 1khz_32khz_crystosc , Gosub = Sectic       ' we select the internal 1 KHz clock from the 32KHz external oscillator
Config Submode = New
'-EEPROM XMEGA-----------------------------------------------------------------
Config Eeprom = Mapped
'-NOKIA 1100-(HX1230 96x68)----------------------------------------------------------------
Wait 1
Const Contrast_lcd = 5
Config Graphlcd = 128x64sed , Si = Port0.2 , Rst = Port1.0 , Cs1 = Port1.1 , Sclk = Port2.1       'Contrast 0 to 127, if not defined - 72
'Config Vport3 = F
'$lib "glcd-Nokia1100.lib"
'Config Graphlcd = 128x64sed , Si = Port3.5 , Sclk = Port3.6 , Cs1 = Port3.1 , Rst = Port3.0       'Contrast 0 to 127, if not defined - 72
'1 RST - Rst  Portc.0
'2 CE  - Cs1  Portc.1
'3 DC  - A0   NC
'4 DIN - Si   Porta.2
'5 CLK - Sclk Portd.1
'6 VCC
'7 LIGHT
'8 GND
'Rst & Cs1 is optional
'Const Contrast_lcd = 20
'Const Negative_lcd = 1                                      'Inverting screen
'Const Rotate_lcd = 1                                        'Rotate screen to 180
Cls
Setfont Font8x8
Showpic 0 , 0 , Logoms
Wait 3
Sectic:
'-GLCD---------------------------------------------------------------
$include "font8x8.font"
$include "andale10x16.font"
Logoms:
$bgf "GSM-Logo3.bgf"
Page 7 of 7
