DFPLAYER Mini Adafruit
mansur
PostPosted: Sat Oct 06, 2018 11:21 pm    Post subject: DFPLAYER Mini Adafruit Reply with quote
Please use 10K resistor from microcontroller to module (series), if not, your module will be noised.
Please read the pdf tutorial as attached carefully.
this is the sample code:
$regfile=\"m328pdef.dat\"
$crystal=16000000
$baud=9600
$hwstack = 32
$swstack = 32
$framesize = 32
Declare sub dfPlayer(byval command as byte, byval feedback as byte, byval para1 as byte, byval para2  as byte)
\'IO Button Configuration
config pinb.0 =input
playButton alias portb.0
\'Config Software UART for DFPlayer
wait 2
Open \"comd.7:9600,8,n,1\" For Output As #1
\'DFPlayer COMMAND
const NextCommand=&H01
const prevCommand=&H02
const specTracking=&H03
const volUp=&H04
const volDown=&H05
const specVol=&H06
const specEqu=&H07
const playMode=&H08
const specPlayback=&H09
const stbdyMode=&H0A
const Normal=&H0B
const ResetModule=&H0C
const playBack=&H0D
const pause=&H0E
const specFolderPlay=&H0f
const volAdjust=&H10
const repeatPlay=&H11
dfplayer specVol,0,0,30 \'adjust volume
waitms 200
dfplayer specEqu,0,0,0  \'adjust equalizer  normal
waitms 200
   if playButton=0 then
      dfplayer specFolderplay , 0,1,1     \'play folder 01  and 001.mp3
   end if
   \'Format command in Hex ($S        Ver        Len        Cmd        Feedback        para1        para2        Checksum     $O)
   local _$S as byte, _ver as byte, _len as byte, _$O as byte
   local checksum_ as integer  , checksum1 as byte, checksum2 as byte
   _ver=&HFF
   _len=&H06
   _$O=&HEF
   _$S=&H7E
   checksum_=_ver+_len
   checksum_=checksum_+command
   checksum_=checksum_+feedback
   checksum_=checksum_+para1
   checksum_=checksum_+para2
   checksum_=0-checksum_
   checksum1=high(checksum_)
   checksum2=low(checksum_)
   print #1, chr(_$S);chr(_VER);chr(_LEN);chr(command);chr(feedback);chr(para1);chr(para2);chr(checksum1);chr(checksum2);chr(_$O); \'send command to dfplayer
end sub
Mansur. H
Automation & Instrument Engineer
PostPosted: Sun Oct 07, 2018 9:30 am    Post subject: Reply with quote
Seems very interesting, did you do a video ?
Wink
JP
mansur
PostPosted: Sun Oct 07, 2018 10:21 am    Post subject: Reply with quote
i will post the video as soon. please take me time for make video.😁
Mansur. H
PostPosted: Sun Oct 07, 2018 1:48 pm    Post subject: Reply with quote
thank you for sharing, a nice versatile player module indeed !
lslabs2005
PostPosted: Tue Apr 16, 2019 11:39 am    Post subject: dfplayer how to load mp3 files to NOR FLASH (64Mb) ? Reply with quote
hi, how to load mp3 files to NOR FLASH (64Mb) internal dfplayer
O-Family
PostPosted: Tue Apr 16, 2019 2:07 pm    Post subject: Reply with quote
It copies MP3 files to SD card or NOR type flash memory (SPI) using PC.
By the way, USB memory can also be used.
However, since the DFPlayer Mini's [YX5200-24SS] chip is compatible with [KT403A], SPI may not work.
http://translate.google.com/translate?hl=ja&sl=auto&tl=en&u=http%3A%2F%2Fwww.ne.jp%2Fasahi%2Fshared%2Fo-family%2FElecRoom%2FAVRMCOM%2FMP3module%2FMP3module.html&sandbox=1
http://www.ne.jp/asahi/shared/o-family/ElecRoom/AVRMCOM/MP3module/MP3module.html
https://www.youtube.com/watch?v=miCwtyQiUFk&feature=youtu.be
six1
PostPosted: Wed Apr 17, 2019 6:11 am    Post subject: Reply with quote
@O-FAMILY *LIKE* Cool
