IDE BASCOM wrong display in version 2.8.0 and 2.8.1
hobby
PostPosted: Sat Mar 16, 2019 12:38 pm    Post subject: IDE BASCOM wrong display in version 2.8.0 and 2.8.1 Reply with quote
Hi Mark,
Since version 2.8.0 and 2.8.1 some line does not appear in the right color, it changes location, it's variable. I have this on 2 different PCs in Windows 10 64Bit.
Olivier
PostPosted: Tue Mar 19, 2019 10:11 am    Post subject: Reply with quote
you can turn of 'show dead code' in the edit menu.
indeed it should not show the alias as dead since it was used.
it was changed.
you best report a problem to support since i do not always read forum topics.
jenalcom
PostPosted: Tue Mar 19, 2019 2:52 pm    Post subject: Reply with quote
I think you may find that the problem happens when you make changes in your code.
Try to close the programme and re-open and see if it is then OK.
hobby
PostPosted: Tue Mar 19, 2019 4:29 pm    Post subject: Reply with quote
Hi MArk,
Thanks, it's works.
Ps for jenalcom: no, at launch bascon.
Olivier
PostPosted: Tue Mar 19, 2019 4:35 pm    Post subject: Reply with quote
you need to check the help. this option is to show which code is not used. but it did not work for your code (config with alias).
well maybe nobody needs this option.
cucuruzel
PostPosted: Tue Mar 19, 2019 5:47 pm    Post subject: Reply with quote
I use it and like it, it helps keeping the code cleaner.
View user's profile Visit poster's website Yahoo Messenger
PostPosted: Wed Mar 20, 2019 5:08 pm    Post subject: Reply with quote
As Cucuruzel I use it and I like it too
JP Wink
