Posted: Thu Mar 07, 2019 10:19 am Post subject: |
hi Pikczu
great work on the 4D display.
I noticed the printbin code. it has been asked multiple time and is high on the to do list. so i thought it is a good idea to get it done in 2082.
if you contact support i can deliver a test version when i am done with it.
the ideas :
printbin somevar ; 2 ; othervar ,numbytes ; thirdvar
this way the optional comma can be used to specify number of bytes
other option would be to add printbinX which is incompatible with printbin. like : printbinX somevar ; numbytes
that is it, just one parameter with optional num of bytes
i think the first alternative is the best. _________________ Mark |
Pikczu
Joined: 22 Jan 2006 Posts: 72 Location: Dublin, Ireland
Posted: Thu Mar 07, 2019 12:58 pm Post subject: |
Hi Mark,
Thank you, it is all possible because of you and your team.
So thank you for all the hard work during the years.
Quote: | printbin somevar ; 2 ; othervar ,numbytes ; thirdvar
this way the optional comma can be used to specify number of bytes |
This sounds good.
My personal choice would be the printbinx but whatever option you chose I will be happy with it.
I will contact the support as per your advice.
Best regards
Pawel aka Pikczu |
bellon
Posted: Tue Mar 12, 2019 5:12 pm Post subject: Recept nul char / Bascom |
Hi Pikczu
After a lot of trouble with my PC (no USB port works) I had to change it and reinstall the new one!
I am testing and trying to understand your program and for that I have defined in workschop4 1 coolgauge, 1 angularmeter and 1 4dbutton and 1 leddigits.
Leddigits, coolgauge and angularmeter work. but I can not read the state of the 4dbutton. here is the call of functions that I have imagined ....
it's just ? |
Pikczu
Posted: Tue Mar 12, 2019 10:26 pm Post subject: |
Hi Bernard
The buttons can be read by read_obj
(Which in my opinion doesn't have sense, maybe for toggle type of the button)
By calling this sub:
Code: | Sub 4d_read_obj(byval 4d_object_id As Byte , Byval 4d_object_index As Byte )
'this should be a fuction
4d_arr_tx(1) = Write_obj '&h00 constant
4d_arr_tx(2) = 4d_object_id 'object ID as per constants
4d_arr_tx(3) = 4d_object_index 'object index
Xor_crc = 4d_arr_tx(1) Xor 4d_arr_tx(2) 'calculate the xor check sum
Xor_crc = Xor_crc Xor 4d_arr_tx(3)
4d_arr_tx(4) = Xor_crc
Printbin #1 , 4d_arr_tx(1) ; 4 'print binary the final result
Ack_flag.1 = 1 'for feature use
'The response from the display should be Report_obj: &h05
End Sub |
Results of the read object will be assigned to array in select case for Case Report_obj: '&H05
(I probably gonna make this a function so the value and index will be reported back.)
Other way is to simply check the events.
Events are checked in the do- loop by Ischarwaiting.
So if you simply set the flag in the select case: report_event: '&h07
Code: | Case 4dbutton: '30
4dbutton_idx = 4d_arr_rx(3)
4dbutton_val(1) = 4d_arr_rx(4)
4dbutton_val(2) = 4d_arr_rx(5)
Lcd "Event: 4dbutton "
'set your flag here
'then clear he values of 4dbutton_idx and 4dbutton_val(2) after you finish
'the value will be only 0 or 1
Don't forget there is different type of the buttons 4dbuttons, user buttons, animated buttons and also windows button.
Make sure you are checking the correct ones.
Also they can send event just when you release them, or one event for touch and new event for the release.
Code: | If Ischarwaiting(#1) = 1 Then
Inputbin #1 , 4d_arr_rx(1) , 1
' Cls
'Lcd "received= " ; 4d_arr_rx(1)
Select Case 4d_arr_rx(1) 'command
'****************************Object reports ***************************************
'If Ack_flag.1 = 1 Then 'for feature use
'Ack_flag.1 = 0
'Else
'lcd , " Error there was no &H05 request !"
'End If
Inputbin #1 , 4d_arr_rx(2) , 5 'get next 5
Xor_crc = Xor_this(4d_arr_rx(1)) ' check the crc
' Upperline
If 4d_arr_rx(6) = Xor_crc Then 'if crc ok then check what came
Select Case 4d_arr_rx(2) 'object ID
Case Dipswitch: '0
Dipswitch_idx = 4d_arr_rx(3)
Dipswitch_val(1) = 4d_arr_rx(4)
Dipswitch_val(2) = 4d_arr_rx(5)
' Lcd "Dipswitch "
Case Knob: '1
Knob_idx = 4d_arr_rx(3)
Knob_val(1) = 4d_arr_rx(4)
Knob_val(2) = 4d_arr_rx(5)
' Lcd "Knob "
Case Rockerswitch: '2
Rockerswitch_idx = 4d_arr_rx(3)
Rockerswitch_val(1) = 4d_arr_rx(4)
Rockerswitch_val(2) = 4d_arr_rx(5)
' Lcd "Rockerswitch "
Case Rotaryswitch: '3
Rotaryswitch_idx = 4d_arr_rx(3)
Rotaryswitch_val(1) = 4d_arr_rx(4)
Rotaryswitch_val(2) = 4d_arr_rx(5)
' Lcd "Rotaryswitch "
Case Slider: '4
Slider_idx = 4d_arr_rx(3)
Slider_val(1) = 4d_arr_rx(4)
Slider_val(2) = 4d_arr_rx(5)
' Lcd "Slider "
Case Trackbar: '5
Trackbar_idx = 4d_arr_rx(3)
Trackbar_val(1) = 4d_arr_rx(4)
Trackbar_val(2) = 4d_arr_rx(5)
' Lcd "Trackbar "
Case Winbutton: '6
Winbutton_idx = 4d_arr_rx(3)
Winbutton_val(1) = 4d_arr_rx(4)
Winbutton_val(2) = 4d_arr_rx(5)
' Lcd "Winbutton "
Case Angularmeter: '7
Angularmeter_idx = 4d_arr_rx(3)
Angularmeter_val(1) = 4d_arr_rx(4)
Angularmeter_val(2) = 4d_arr_rx(5)
' Lcd "Angularmeter "
Case Coolgauge: '8
Coolgauge_idx = 4d_arr_rx(3)
Coolgauge_val(1) = 4d_arr_rx(4)
Coolgauge_val(2) = 4d_arr_rx(5)
' Lcd "Coolgauge "
Case Customdigits: '9
Customdigits_idx = 4d_arr_rx(3)
Customdigits_val(1) = 4d_arr_rx(4)
Customdigits_val(2) = 4d_arr_rx(5)
' Lcd "Customdigits "
Case Form: '10
Form_idx = 4d_arr_rx(3)
Form_val(1) = 4d_arr_rx(4)
Form_val(2) = 4d_arr_rx(5)
' Lcd "Form "
Case Gauge: '11
Gauge_idx = 4d_arr_rx(3)
Gauge_val(1) = 4d_arr_rx(4)
Gauge_val(2) = 4d_arr_rx(5)
' Lcd "Gauge "
Case Image: '12
'Image_idx = 4d_arr_rx(3)
'Image_val(1) = 4d_arr_rx(4)
'Image_val(2) = 4d_arr_rx(5)
' lcd , "Image "
Case Keyboard: '13
Keyboard_idx = 4d_arr_rx(3)
Keyboard_val(1) = 4d_arr_rx(4)
Keyboard_val(2) = 4d_arr_rx(5)
' Lcd "Keyboard "
Case Led: '14
Led_idx = 4d_arr_rx(3)
Led_val(1) = 4d_arr_rx(4)
Led_val(2) = 4d_arr_rx(5)
' Lcd "Led "
Case Leddigits: '15
Leddigits_idx = 4d_arr_rx(3)
Leddigits_val(1) = 4d_arr_rx(4)
Leddigits_val(2) = 4d_arr_rx(5)
' Lcd "Leddigits "
Case Meter: '16
Meter_idx = 4d_arr_rx(3)
Meter_val(1) = 4d_arr_rx(4)
Meter_val(2) = 4d_arr_rx(5)
' Lcd "Meter "
Case Strings: '17
Strings_idx = 4d_arr_rx(3)
Strings_val(1) = 4d_arr_rx(4)
Strings_val(2) = 4d_arr_rx(5)
' Lcd "Strings "
Case Thermometer: '18
Thermometer_idx = 4d_arr_rx(3)
Thermometer_val(1) = 4d_arr_rx(4)
Thermometer_val(2) = 4d_arr_rx(5)
' Lcd "Thermometer "
Case Userled: '19
Userled_idx = 4d_arr_rx(3)
Userled_val(1) = 4d_arr_rx(4)
Userled_val(2) = 4d_arr_rx(5)
' Lcd "Userled "
Case Video: '20
Video_idx = 4d_arr_rx(3)
Video_val(1) = 4d_arr_rx(4)
Video_val(2) = 4d_arr_rx(5)
' Debug "Video "
Case Statictext: '21
'Statictext_idx = 4d_arr_rx(3)
'Statictext_val(1) = 4d_arr_rx(4)
'Statictext_val(2) = 4d_arr_rx(5)
' lcd "Statictext "
Case S_ound: '22
S_ound_idx = 4d_arr_rx(3)
S_ound_val(1) = 4d_arr_rx(4)
S_ound_val(2) = 4d_arr_rx(5)
' Lcd "S_ound "
Case T_imer: '23
T_imer_idx = 4d_arr_rx(3)
T_imer_val(1) = 4d_arr_rx(4)
T_imer_val(2) = 4d_arr_rx(5)
' Lcd "T_imer "
Case Spectrum: '24
Spectrum_idx = 4d_arr_rx(3)
Spectrum_val(1) = 4d_arr_rx(4)
Spectrum_val(2) = 4d_arr_rx(5)
' Lcd "Spectrum "
Case Scope: '25
Scope_idx = 4d_arr_rx(3)
Scope_val(1) = 4d_arr_rx(4)
Scope_val(2) = 4d_arr_rx(5)
' Lcd "Scope "
Case Tank: '26
Tank_idx = 4d_arr_rx(3)
Tank_val(1) = 4d_arr_rx(4)
Tank_val(2) = 4d_arr_rx(5)
' Lcd "Tank "
Case Userimages: '27
Userimages_idx = 4d_arr_rx(3)
Userimages_val(1) = 4d_arr_rx(4)
Userimages_val(2) = 4d_arr_rx(5)
' Lcd "Userimages "
Case Pinoutput: '28
Pinoutput_idx = 4d_arr_rx(3)
'Pinoutput_val(1) = 4d_arr_rx(4)
Pinoutput_val = 4d_arr_rx(5)
' Lcd "Pinoutput "
Case Pininput: '29
Pininput_idx = 4d_arr_rx(3)
'Pininput_val(1) = 4d_arr_rx(4)
Pininput_val = 4d_arr_rx(5)
' Lcd "Pininput "
Case 4dbutton: '30
Lcd "object read: 4dbutton " ;
Case Anibutton: '31
Anibutton_idx = 4d_arr_rx(3)
Anibutton_val(1) = 4d_arr_rx(4)
Anibutton_val(2) = 4d_arr_rx(5)
' Lcd "Anibutton "
Case Colorpicker: '32
Colorpicker_idx = 4d_arr_rx(3)
Colorpicker_val(1) = 4d_arr_rx(4)
Colorpicker_val(2) = 4d_arr_rx(5)
' Lcd "Colorpicker "
Case Userbutton: '33
Userbutton_idx = 4d_arr_rx(3)
Userbutton_val(1) = 4d_arr_rx(4)
Userbutton_val(2) = 4d_arr_rx(5)
' Lcd "Userbutton "
Case Magicobject: '34
Magicobject_idx = 4d_arr_rx(3)
Magicobject_val(1) = 4d_arr_rx(4)
Magicobject_val(2) = 4d_arr_rx(5)
' Lcd "Magicobject "
Case Smartgauge: '35
Smartgauge_idx = 4d_arr_rx(3)
Smartgauge_val(1) = 4d_arr_rx(4)
Smartgauge_val(2) = 4d_arr_rx(5)
' Lcd "Smartgauge "
Case Smartslider: '36
Smartslider_idx = 4d_arr_rx(3)
Smartslider_val(1) = 4d_arr_rx(4)
Smartslider_val(2) = 4d_arr_rx(5)
' Lcd "Smartslider "
Case Smartknob: '37
Smartknob_idx = 4d_arr_rx(3)
Smartknob_val(1) = 4d_arr_rx(4)
Smartknob_val(2) = 4d_arr_rx(5)
' Lcd "Smartknob "
Case Else:
' Lcd "Event report wrong ID: " ; 4d_arr_rx(3)
Clear Serialin1
' Lcd "S_pace" ; S_pace
' Lcd , "frame error"
End Select
Case A_ck: '&H06 ACK
' Lcd "ACK"
Ack_flag.0 = 0 'reset ack flag not really in use yet
'*****************************Events report ************************************
Case Report_event: '&H07
If 4d_arr_rx(6) = Xor_crc Then 'if crc ok, then check what came
' Lowerline
Case Dipswitch: '0
' Lcd "Dipswitch "
Case Knob: '1
' Lcd "Knob "
Case Slider: '4
' Lcd "Slider "
Case Trackbar: '5
' Lcd "Trackbar "
Case Winbutton: '6
' Lcd "Winbutton "
Case Coolgauge: '8
' Lcd "Coolgauge "
Case Form: '10
' Lcd "Form "
Case Gauge: '11
' Lcd "Gauge "
Case Image: '12
' Lcd "Image "
Case Keyboard: '13
' Lcd "Keyboard "
Case Led: '14
' Lcd "Led "
Case Leddigits: '15
' Lcd "Leddigits "
Case Meter: '16
' Lcd "Meter "
Case Strings: '17
' Lcd "Strings "
Case Userled: '19
' Lcd "Userled "
Case Video: '20
' Debug "Video "
' Lcd "Statictext "
Case S_ound: '22
' Lcd "S_ound "
Case T_imer: '23
' Lcd "T_imer "
Case Spectrum: '24
' Lcd "Spectrum "
Case Scope: '25
' Lcd "Scope "
Case Tank: '26
' Lcd "Tank "
' Lcd "Userimages "
Case Pinoutput: '28
' Lcd "Pinoutput "
Case Pininput: '29
' Lcd "Pininput "
Case 4dbutton: '30
Flag_dosomthing.0 = 1
Case Anibutton: '31
' Lcd "Anibutton "
' Lcd "Userbutton "
' Lcd "Smartgauge "
Case Smartknob: '37
' Lcd "Smartknob "
Case Else:
' Lowerline
Clear Serialin1
' Lcd "frame error"
End Select
Case Nak:
' Lcd "NACK" '&h15 NAK
Case Else:
' Lcd "Error in Code =: " ; 4d_arr_rx(1)
Clear Serialin1
' Lcd "S_pace= " ; S_pace
' Lcd "frame error"
End Select
End If |
I Will try to create small demo for you.
Regards
Pikczu |
bellon
Posted: Wed Mar 13, 2019 1:41 pm Post subject: Recept nul char / Bascom |
Hi Pikczu
well, I use an arduino card with a processor atmega 2560. if I did not receive the command of the lcd it is because I kept your configuration "Config Serialin1" while it is "Config Serialin" !!
But something strange is happening:
If I update only the 4 digits of the LCD, the LCD switch is working very well, but if I want to update the other two gauges then the switch lcd walk randomly!
there is some function that I did not understand well:
Incr Tablica (5)
Tablica (6) = Xor_this (tablica (1))
Is Enable Interrupts absolutely necessary?
Thank you !! |
Pikczu
Posted: Wed Mar 13, 2019 7:38 pm Post subject: |
Hi Bernard,
That part is actually a leftover from the test.
So you can delete it. |
bellon
Posted: Wed Mar 13, 2019 8:08 pm Post subject: Recept nul char / Bascom |
You mean ?
Incr Tablica (5)
and
Tablica(1) = Write_obj
Tablica(2) = Leddigits
Tablica(3) = Obj_index
Tablica(4) = Tablica(4)
Tablica(5) = 0 |
Pikczu
Posted: Wed Mar 13, 2019 8:17 pm Post subject: |
Yes, also there is still some config for Xmega i have removed them. |
bellon
Posted: Fri Mar 15, 2019 9:39 pm Post subject: Recept nul char / Bascom |
Hello Pikczu
Something strange happens to me ...
When I press the switch on the LCD to activate or deactivate
the update of the Leddigit (4) I see that the program can take up to 10 seconds to take into account the change of state of the switch while the rs232 command arrives immediately on my board. (as if something slowed down has function if ischarwaiting (# 1) ......
An idea ?
Sincerely Bernard
'************************* Main loop *******************************************
'Wait 5
Ack_flag = 1
State_button = 0
Digit_cnt = 0
'lcd , "MCU Rev. = " ' ; Mcu_revid 'version of the MCU
'Call 4d_write_contrast(&H07)
'Call 4d_write_str(0 , "Hi there" , 0 )
'***************************************** Mesuere la distance Ultrason ********
Mesure_us:
Set Trig
Waitus 20 '
Reset Trig
Pulsein Mesure_ultrason , Pind , 0 , 1
M = Mesure_ultrason
M = M * 12.9 'a ajuster en fonction du quartz
M = M / 100
Neige = M
Locate 1 , 8 : Lcd " "
Locate 1 , 8 : Lcd Neige 'M 'M
' Call 4d_write_obj(coolgauge , &H00 , Neige) ' mettre à jour la coolgauge
' Call 4d_write_obj(angularmeter , &H00 , Neige) 'mettre a jour l'angularmetter
Wait 1
Incr Digit_cnt
Locate 1 , 1 : Lcd State_button ; 4d_arr_rx(5) <<<<<Here, my display of control tells me the change of the switch that 10 seconds after having actuated
Locate 2 , 1 : Lcd Ack_flag ; 4d_arr_rx(1)
Waitms 500
If State_button <> 0 Then 'And Ack_flag = 1
4dbutton_idx = &H00
4d_arr_rx(5) = &H00
Call 4d_write_obj(leddigits , &H00 , Digit_cnt) 'mettre a jour les digits
' Ack_flag = 1
'************************************pour test uniquement *********************
' For I = 1 To 10
' Call 4d_write_contrast(i)
' Waitms 100
' Next I
' 4d_string_tx = "12345"
' Call 4d_write_str(&H00 , 4d_string_tx , &H00)
'********************************* Lescture des rapports "OBJETS (07)" ***************
If Ischarwaiting(#1) = 1 Then |
Pikczu
Posted: Fri Mar 15, 2019 11:14 pm Post subject: |
Hi Bernard,
Can you attach whole code for Bascom and 4d project ?
Remove all the wait form the code, and setup debug port then print everything what happens in to the debug this help a lot.
PS.I will be away for week I may have access to forum only from mobile. |
bellon
Posted: Sun Mar 17, 2019 12:19 am Post subject: Recept nul char / Bascom |
Hello Pikczu
The board used to test the application is an Arduino 2560 board (Atmega2560). Here is the problem:
the 4 digits of the 4D display are written as long as the switch is ON.
This works very well!
The problem is that if at the same time I write in the angularmeter a value, even fixed, then I see that the program takes a long time to take into account the change of state of the switch 4D!
In attachments, the bascom source, 4d system files, 1 prototype photo. The 2-line lcd display on the prototype is used for debugging ..... (rs232)
I have no idea .............
Thank you.
Bernard |
Pikczu
Posted: Sun Mar 17, 2019 11:43 am Post subject: |
Hi Bernard,
This sound strange, i will take a look in to the code.
But as mentioned im away for week, I have no access to the equipment. |
bellon
Posted: Sun Mar 17, 2019 1:08 pm Post subject: Recept nul char / Bascom |
Hi
I found my mistake stupid: instead of writing * clear serialin1 "I wrote" clear serialin * of course the serial input buffer is filled ..... and it's a disaster !!
thank you for everything
Bernard |
bellon
Posted: Sun Mar 17, 2019 1:36 pm Post subject: |
........ false good idea, if I validate "Call 4d_write_obj (angularmeter, & H00, & H32)" the problem remains the same!
have a nice week end ! |
Pikczu
Posted: Sun Mar 17, 2019 6:17 pm Post subject: |
Hi Bernard,
I Could not test the code.
Google blocked my license key can't download it.
Any way issue may be with the crc so i have added
printbin #1, &h06 after the crc is calculated and is ok.
Similar i have added printbin #1, &h15 where the crc is not ok
Please check this as I could not even test this demo version wont let me do it, and i can not download my license file to test on full version.
Code: | '$sim
$regfile = "m2560def.dat" '$regfile = "m328pdef.dat"
$crystal = 16000000 '32MHz
$hwstack = 128
$swstack = 128
$framesize = 128
$baud = 9600
Config Submode = New
'************ CONFIGURATION FOR COM1 UART ************************************
Config Com1 = 9600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Serialin = Buffered , Size = 100 , Bytematch = None 'for COM1
Config Serialout = Buffered , Size = 100
Open "COM1:" For Binary As #1
'*********************LCD de controle de reception UART ***********************
Config Lcdpin = Pin , Db4 = Portg.5 , Db5 = Porte.3 , Db6 = Porth.3 , Db7 = Porth.4 , E = Porth.6 , Rs = Porth.5
Config Lcd = 16 * 2 '2 lignes LCD
Cursor Off
Cursor Noblink
Cls
' ======= communication avec capteur ultrason, Utilisé uniquement pour ultrason====
Config Pind.1 = Output
Config Pind.0 = Input
Trig Alias Portd.1
Echo_son Alias Portd.0
Trig = 0
'Config Ping.5 = Output
'Config Pinb.7 = Output 'led seconde
'Led_cont Alias Portb.7 ' reset du lcd
'************************* Variables *******************************************
Dim S_pace As Byte
Dim A As Byte
Dim Enkoder_tmp As Word 'for the enkoder
Dim Enkoder_tmp_1 As Word 'for the enkoder
Dim Enkoder_tmp_2 As Word 'for the enkoder
Dim C As Byte
Dim R As Byte
Dim Tablica(6)as Byte
'********************************used in TX subs********************************
Dim Ack_flag As Byte ' ack byte flag setup each time we expect the ack to come form teh dispaly
Dim 4d_arr_tx(6)as Byte '
Dim 4d_helpa As Word At 4d_arr_tx(4) Overlay
Dim 4d_string_tx_arr(39) As Byte
Dim 4d_string_tx As String * 34 At 4d_string_tx_arr(1) + 3 Overlay
Dim 4d_arr_rx(6) As Byte
Dim 4d_var_rx As Word At 4d_arr_rx(4) Overlay 'overlay for rx
Dim 4d_var_rx_tmp As Word
Dim Obj_index As Byte '4d object index
'Macro
Dim Xor_crc As Byte 'xor crc for 4d
Xor_crc = 0
Dim Dipswitch_idx As Byte '0
Dim Knob_idx As Byte
Dim Rockerswitch_idx As Byte
Dim Rotaryswitch_idx As Byte
Dim Slider_idx As Byte
Dim Trackbar_idx As Byte
Dim Winbutton_idx As Byte
Dim Angularmeter_idx As Byte
Dim Coolgauge_idx As Byte
Dim Customdigits_idx As Byte
Dim Form_idx As Byte 'Used To Set The Current Form
Dim Gauge_idx As Byte '
'Dim Image_idx As Byte ' Displayed As Part Of Form , No Method To Alter
Dim Keyboard_idx As Byte ' KEYBOARD Inputs Are Always Single Bytes And Are Unsolicited
Dim Led_idx As Byte
Dim Leddigits_idx As Byte
Dim Meter_idx As Byte
Dim Strings_idx As Byte
Dim Thermometer_idx As Byte
Dim Userled_idx As Byte
Dim Video_idx As Byte
'Dim Statictext_idx As Byte ' Displayed As Part Of Form , No Method To Alter
Dim S_ound_idx As Byte
Dim T_imer_idx As Byte
Dim Spectrum_idx As Byte
Dim Scope_idx As Byte
Dim Tank_idx As Byte
Dim Userimages_idx As Byte
Dim Pinoutput_idx As Byte
Dim Pininput_idx As Byte
Dim 4dbutton_idx As Byte
Dim Anibutton_idx As Byte
Dim Colorpicker_idx As Byte
Dim Userbutton_idx As Byte
Dim Magicobject_idx As Byte 'ONLY Available When Using Genie Pro
Dim Smartgauge_idx As Byte 'ONLY Available When Using Genie Pro
Dim Smartslider_idx As Byte 'ONLY Available When Using Genie Pro
Dim Smartknob_idx As Byte 'Only Available When Using Genie Pro
Dim Dipswitch_val(2) As Byte '0
Dim Knob_val(2) As Byte
Dim Rockerswitch_val(2) As Byte
Dim Rotaryswitch_val(2) As Byte
Dim Slider_val(2) As Byte
Dim Trackbar_val(2) As Byte
Dim Winbutton_val(2) As Byte
Dim Angularmeter_val(2) As Byte
Dim Coolgauge_val(2) As Byte
Dim Customdigits_val(2) As Byte
Dim Form_val(2) As Byte 'Used To Set The Current Form
Dim Gauge_val(2) As Byte '
'Dim Image_val(2) As Byte ' Displayed As Part Of Form , No Method To Alter
Dim Keyboard_val(2) As Byte ' KEYBOARD Inputs Are Always Single Bytes And Are Unsolicited
Dim Led_val(2) As Byte
Dim Leddigits_val(2) As Byte
Dim Meter_val(2) As Byte
Dim Strings_val(2) As Byte
Dim Thermometer_val(2) As Byte
Dim Userled_val(2) As Byte
Dim Video_val(2) As Byte
'Dim Statictext_val(2) As Byte ' Displayed As Part Of Form , No Method To Alter
Dim S_ound_val(2) As Byte
Dim T_imer_val(2) As Byte
Dim Spectrum_val(2) As Byte
Dim Scope_val(2) As Byte
Dim Tank_val(2) As Byte
Dim Userimages_val(2) As Byte
Dim Pinoutput_val As Byte
Dim Pininput_val As Byte
Dim 4dbutton_val(2) As Byte
Dim Anibutton_val(2) As Byte
Dim Colorpicker_val(2) As Byte
Dim Userbutton_val(2) As Byte
Dim Magicobject_val(2) As Byte 'ONLY Available When Using Genie Pro
Dim Smartgauge_val(2) As Byte 'ONLY Available When Using Genie Pro
Dim Smartslider_val(2) As Byte 'ONLY Available When Using Genie Pro
Dim Smartknob_val(2) As Byte 'Only Available When Using Genie Pro
Dim Mesure_ultrason As Word
Dim M As Single
Dim Neige As Word
Dim I As Word
Dim Digit_cnt As Word
Dim Switch_ultra As Byte
Dim State_button_4d As Byte
Const A_ck = &H06
Const Nak = &H15
Const 4d_max_len = 32 'maxium 4D strig lengt
Const Dipswitch = &H00 '0
Const Knob = &H01
Const Rockerswitch = &H02
Const Rotaryswitch = &H03
Const Slider = &H04
Const Trackbar = &H05
Const Winbutton = &H06
Const Angularmeter = &H07
Const Coolgauge = &H08
Const Customdigits = &H09
Const Form = &H0A 'Used To Set The Current Form
Const Gauge = &H0B '
Const Image = &H0C ' Displayed As Part Of Form , No Method To Alter
Const Keyboard = &H0D ' KEYBOARD Inputs Are Always Single Bytes And Are Unsolicited
Const Led = &H0E
Const Leddigits = &H0F
Const Meter = &H10
Const Strings = &H11
Const Thermometer = &H12
Const Userled = &H13
Const Video = &H14
Const Statictext = &H15 ' Displayed As Part Of Form , No Method To Alter
Const S_ound = &H16
Const T_imer = &H17
Const Spectrum = &H18
Const Scope = &H19
Const Tank = &H1A
Const Userimages = &H1B
Const Pinoutput = &H1C
Const Pininput = &H1D
Const 4dbutton = &H1E
Const Anibutton = &H1F
Const Colorpicker = &H20
Const Userbutton = &H21
Const Magicobject = &H22 'ONLY Available When Using Genie Pro
Const Smartgauge = &H23 'ONLY Available When Using Genie Pro
Const Smartslider = &H24 'ONLY Available When Using Genie Pro
Const Smartknob = &H25 'Only Available When Using Genie Pro
Const Read_obj = &H00
Const Write_obj = &H01
Const Write_str = &H02
Const Write_stru = &H03
Const Write_contrast = &H04
Const Report_obj = &H05 'response to read obj command
Const Report_event = &H07 'response to evnt no no request needed
Const Write_magic_bytes = &H08
Const Write_magic_dbytes = &H09
Const Report_magic_event_bytes = &H0A
Function Xor_this(ar() As Byte ) As Byte ' Function XOR
Local Xor_ing As Byte 'temporary variable for xor value so could be a local
Xor_ing = Ar(1) Xor Ar(2) 'xoring
Xor_ing = Xor_ing Xor Ar(3)
Xor_ing = Xor_ing Xor Ar(4)
Xor_ing = Xor_ing Xor Ar(5)
'Xor_ing = Xor_ing Xor Ar(6)
Xor_this = Xor_ing 'final result asigment
End Function
'this shoul be a function not a sub
' Ack_flag.1 = 1 'for feature use
End Sub
Sub 4d_write_obj(byval 4d_object_id As Byte , Byval 4d_object_index As Byte , Byval 4d_obj_value As Word )
' Dim 4d_helpa As Word At 4d_arr_tx(4) Overlay 'copy for clarity
Swap 4d_obj_value 'litle endian to big endian
4d_helpa = 4d_obj_value 'asign to overlayd variable
4d_arr_tx(1) = Write_obj '&h01 constant
'4d_arr_tx(4) as this is overlay teh values are all ready there in global array
'4d_arr_tx(5) as this is overlay teh values are all ready there in global array
Xor_crc = Xor_crc Xor 4d_arr_tx(4)
4d_arr_tx(6) = Xor_crc Xor 4d_arr_tx(5)
Printbin #1 , 4d_arr_tx(1) ; 6 'print binary the final result
' Ack_flag.0 = 1 'for feature use
'The response from the display should be ACK message &h06
End Sub
Sub 4d_write_str(byval 4d_str_indx As Byte , Byval 4d_string_1 As String , Byval Cr_lf As Byte )
'the body of the command is:
'code + string_index+ string_lenght + string + xorcrc
Local Index_help_a As Byte 'used to calculate the lengt of the string
Local Index_help_b As Byte 'used to calculate position of the XOR CRC in array, string lenght+3
Dim Tot_command_len As Byte 'total comand lenght
'If Cr >= 1 Then Cr = 1
'If Lf >= 1 Then Lf = 1
Select Case Cr_lf
Case 0:
'Tot_command_len = Len(4d_string_1) + 4 'string lenght(+) commad (+) string index (+) string
Tot_command_len = Len(4d_string_1) 'string lenght(+) commad (+) string index (+) string
Case 1:
Tot_command_len = Len(4d_string_1) + 5 'string lenght(+) commad (+) string index (+) string
' Insertchar 4d_string_tx , Tot_command_len
Case 2:
Tot_command_len = Len(4d_string_1) '+ 6 'string lenght(+) commad (+) string index (+) string
End Select
4d_string_tx = 4d_string_1 'copy the string in to variable overlayd at array
4d_string_tx_arr(1) = Write_str '&h02 write string command
4d_string_tx_arr(2) = 4d_str_indx 'index of the string
4d_string_tx_arr(3) = Len(4d_string_1) 'lenght of the string
For Index_help_a = 1 To Tot_command_len -1 'we need to xor this and asign at the end
'the minus (-)1 skip xor of the null termination
4d_string_tx_arr(tot_command_len) = 4d_string_tx_arr(tot_command_len) Xor 4d_string_tx_arr(index_help_a)
Next Index_help_a
Select Case Tot_command_len ' total comand lenght
Case 5:
Printbin #1 , 4d_string_tx_arr(1) ; 5 'code +string index+ string lenght + 1 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 5 'code +string index+ string lenght + 1 char + crc
Case 6:
Printbin #1 , 4d_string_tx_arr(1) ; 6 'code +string index+ string lenght + 2 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 6 'code +string index+ string lenght + 2 char + crc
Case 7:
Printbin #1 , 4d_string_tx_arr(1) ; 7 'code +string index+ string lenght + 3 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 7 'code +string index+ string lenght + 3 char + crc
Case 8:
Printbin #1 , 4d_string_tx_arr(1) ; 8 'code +string index+ string lenght + 4 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 8 'code +string index+ string lenght + 4 char + crc
Case 9:
Printbin #1 , 4d_string_tx_arr(1) ; 9 'code +string index+ string lenght + 5 char + crc
'Printbin #4 , 4d_string_tx_arr(1) , 9 'code +string index+ string lenght + 5 char + crc
Case 10:
Printbin #1 , 4d_string_tx_arr(1) ; 10 'code +string index+ string lenght + 6 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 10 'code +string index+ string lenght + 6 char + crc
Case 11:
Printbin #1 , 4d_string_tx_arr(1) ; 11 'code +string index+ string lenght + 7 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 11 'code +string index+ string lenght + 7 char + crc
Case 12:
Printbin #1 , 4d_string_tx_arr(1) ; 12 'code +string index+ string lenght + 8 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 12 'code +string index+ string lenght + 8 char + crc
Case 13:
Printbin #1 , 4d_string_tx_arr(1) ; 13 'code +string index+ string lenght + 9 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 13 'code +string index+ string lenght + 9 char + crc
Case 14:
Printbin #1 , 4d_string_tx_arr(1) ; 14 'code +string index+ string lenght + 10 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 14 'code +string index+ string lenght + 10 char + crc
Case 15:
Printbin #1 , 4d_string_tx_arr(1) ; 15 'code +string index+ string lenght + 11 char + crc
' Printbin #4 , 4d_string_tx_arr(1) ; 15 'code +string index+ string lenght + 11 char + crc
Case 16:
Printbin #1 , 4d_string_tx_arr(1) ; 16 'code +string index+ string lenght + 12 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 16 'code +string index+ string lenght + 12 char + crc
Case 17:
Printbin #1 , 4d_string_tx_arr(1) ; 17 'code +string index+ string lenght + 13 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 17 'code +string index+ string lenght + 13 char + crc
Case 18:
Printbin #1 , 4d_string_tx_arr(1) ; 18 'code +string index+ string lenght + 14 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 18 'code +string index+ string lenght + 14 char + crc
Case 19:
Printbin #1 , 4d_string_tx_arr(1) ; 19 'code +string index+ string lenght + 15 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 19 'code +string index+ string lenght + 15 char + crc
Case 20:
Printbin #1 , 4d_string_tx_arr(1) ; 20 'code +string index+ string lenght + 16 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 20 'code +string index+ string lenght + 16 char + crc
Case 21:
Printbin #1 , 4d_string_tx_arr(1) ; 21 'code +string index+ string lenght + 17 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 21 'code +string index+ string lenght + 17 char + crc
Case 22:
Printbin #1 , 4d_string_tx_arr(1) ; 22 'code +string index+ string lenght + 18 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 22 'code +string index+ string lenght + 18 char + crc
Case 23:
Printbin #1 , 4d_string_tx_arr(1) ; 23 'code +string index+ string lenght + 19 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 23 'code +string index+ string lenght + 19 char + crc
Case 24:
Printbin #1 , 4d_string_tx_arr(1) ; 24 'code +string index+ string lenght + 20 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 24 'code +string index+ string lenght + 20 char + crc
Case 25:
Printbin #1 , 4d_string_tx_arr(1) ; 25 'code +string index+ string lenght + 21 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 25 'code +string index+ string lenght + 21 char + crc
Case 26:
Printbin #1 , 4d_string_tx_arr(1) ; 26 'code +string index+ string lenght + 22 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 26 'code +string index+ string lenght + 22 char + crc
Case 27:
Printbin #1 , 4d_string_tx_arr(1) ; 27 'code +string index+ string lenght + 23 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 27 'code +string index+ string lenght + 23 char + crc
Case 28:
Printbin #1 , 4d_string_tx_arr(1) ; 28 'code +string index+ string lenght + 24 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 28 'code +string index+ string lenght + 24 char + crc
Case 29:
Printbin #1 , 4d_string_tx_arr(1) ; 29 'code +string index+ string lenght + 25 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 29 'code +string index+ string lenght + 25 char + crc
Case 30:
Printbin #1 , 4d_string_tx_arr(1) ; 30 'code +string index+ string lenght + 26 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 30 'code +string index+ string lenght + 26 char + crc
Case 31:
Printbin #1 , 4d_string_tx_arr(1) ; 31 'code +string index+ string lenght + 27 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 31 'code +string index+ string lenght + 27 char + crc
Case 32:
Printbin #1 , 4d_string_tx_arr(1) ; 32 'code +string index+ string lenght + 28 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 32 'code +string index+ string lenght + 28 char + crc
Case 33:
Printbin #1 , 4d_string_tx_arr(1) ; 33 'code +string index+ string lenght + 29 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 33 'code +string index+ string lenght + 29 char + crc
Case 34:
Printbin #1 , 4d_string_tx_arr(1) ; 34 'code +string index+ string lenght + 30 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 34 'code +string index+ string lenght + 30 char + crc
Case 35:
Printbin #1 , 4d_string_tx_arr(1) ; 35 'code +string index+ string lenght + 31 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 35 'code +string index+ string lenght + 31 char + crc
Case 36:
Printbin #1 , 4d_string_tx_arr(1) ; 36 'code +string index+ string lenght + 32 char + crc
'Printbin #4 , 4d_string_tx_arr(1) ; 36 'code +string index+ string lenght + 32 char + crc
End Select
End Sub
Sub 4d_write_contrast(byval 4d_contrast_val As Byte)
If 4d_contrast_val => 10 Then
4d_contrast_val = 10
Dim 4d_contrast_tx(3) As Byte
4d_contrast_tx(1) = Write_contrast
4d_contrast_tx(2) = 4d_contrast_val
4d_contrast_tx(3) = Write_contrast Xor 4d_contrast_val
Printbin #1 , 4d_contrast_tx(1) ; 3
End Sub
Wait 5
Ack_flag = 0
State_button_4d = 0
Digit_cnt = 0
'************************** Mesure the Ultrason distance ***********************
Mesure_us:
Set Trig
Waitus 20 '
Reset Trig
' Pulsein Mesure_ultrason , Pind , 0 , 1 ' not in use
M = Mesure_ultrason
M = M / 100
Neige = M
'Call 4d_write_obj(angularmeter , &H00 , &H32) 'if y unmarque this, the switch on 4D dosent run wel !!
Waitms 100
Locate 1 , 1 : Lcd 4d_arr_rx(1) ; 4d_arr_rx(2) ; 4d_arr_rx(3) ; 4d_arr_rx(4) ; 4d_arr_rx(5) 'just to see the rx char
Locate 2 , 1 : Lcd 4d_arr_tx(1) ; 4d_arr_tx(2) ; 4d_arr_tx(3) ; 4d_arr_tx(4) ; 4d_arr_tx(5) 'just to see the tx char
Waitms 300
Incr Digit_cnt '***** this fonction run wel alone ************
If State_button_4d <> 0 Then '<<
' 4dbutton_idx = &H00 '<<
' 4d_arr_rx(5) = &H00 '<<
Call 4d_write_obj(leddigits , &H00 , Digit_cnt) '<<
Ack_flag = 0 '<<
End If '<<********************************************
Waitms 200
'************************************ for test only ***************************
' For I = 1 To 10
' Waitms 100
' Next I
'********************************* Lescture des rapports "OBJETS (05)" *********
'******************************* Lecture de l'etat d'un objet ******************
Case A_ck:
Ack_flag = 1
Case Nak:
Ack_flag = 0
printbin #1, &h06'********************************************added
Case Dipswitch: '0
' Lcd "Dipswitch "
Case Knob: '1
' Lcd "Knob "
Case Slider: '4
' Lcd "Slider "
Case Trackbar: '5
' Lcd "Trackbar "
Case Winbutton: '6
' Lcd "Winbutton "
Case Coolgauge: '8
' Lcd "Coolgauge "
Case Form: '10
' Lcd "Form "
Case Gauge: '11
' Lcd "Gauge "
Case Image: '12
' lcd , "Image "
Case Keyboard: '13
' Lcd "Keyboard "
Case Led: '14
' Lcd "Led "
Case Leddigits: '15
' Lcd "Leddigits "
Case Meter: '16
' Lcd "Meter "
Case Strings: '17
' Lcd "Strings "
Case Userled: '19
' Lcd "Userled "
Case Video: '20
' Debug "Video "
' lcd "Statictext "
Case S_ound: '22
' Lcd "S_ound "
Case T_imer: '23
' Lcd "T_imer "
Case Spectrum: '24
' Lcd "Spectrum "
Case Scope: '25
' Lcd "Scope "
Case Tank: '26
' Lcd "Tank "
' Lcd "Userimages "
Case Pinoutput: '28
' Lcd "Pinoutput "
Case Pininput: '29
' Lcd "Pininput "
Case 4dbutton: '30
' State_button = 4d_arr_rx(5)
' Printbin#1 , &H06
Case Anibutton: '31
' Lcd "Anibutton "
' Lcd "Userbutton "
' Lcd "Smartgauge "
Case Smartknob: '37
' Lcd "Smartknob "
Case Else:
Clear Serialin
End Select
else
Clear Serialin
Printbin #1 , &H15 '***********************************************added
lcd "object CRC error"
'Print #1 , "ACK"
'Ack_flag.0 = 0
'***************************** rapports "EVENEMENTS (07)" ***************
'***************************** quand un objet est activé ******************
printbin #1, &h06 '**************************************added
Case Dipswitch: '0
' Lcd "Dipswitch "
Case Knob: '1
' Lcd "Knob "
Case Slider: '4
' Lcd "Slider "
Case Trackbar: '5
' Lcd "Trackbar "
Case Winbutton: '6
' Lcd "Winbutton "
Case Coolgauge: '8
' Lcd "Coolgauge "
Case Form: '10
' Lcd "Form "
Case Gauge: '11
' Lcd "Gauge "
Case Image: '12
' Lcd "Image "
Case Keyboard: '13
' Lcd "Keyboard "
Case Led: '14
' Lcd "Led "
Case Leddigits: '15
' Lcd "Leddigits "
Case Meter: '16
' Lcd "Meter "
Case Strings: '17
' Lcd "Strings "
Case Userled: '19
' Lcd "Userled "
Case Video: '20
' Debug "Video "
' Lcd "Statictext "
Case S_ound: '22
' Lcd "S_ound "
Case T_imer: '23
' Lcd "T_imer "
Case Spectrum: '24
' Lcd "Spectrum "
Case Scope: '25
' Lcd "Scope "
Case Tank: '26
' Lcd "Tank "
' Lcd "Userimages "
Case Pinoutput: '28
' Pinoutput_val(1) = 4d_arr_rx(4)
' Lcd "Pinoutput "
Case Pininput: '29
' Pininput_val(1) = 4d_arr_rx(4)
' Lcd "Pininput "
Case 4dbutton: '30
State_button_4d = 4d_arr_rx(5) '<<<<<<< ad State button
' Printbin#1 , &H06
Case Anibutton: '31
' Lcd "Anibutton "
' Lcd "Userbutton "
' Lcd "Smartgauge "
Case Smartknob: '37
' Lcd "Smartknob "
Case Else:
Clear Serialin
End Select
Else
Clear Serialin
Printbin #1 , &H15 '**********************************************added
lcd "event CRC error"
Case A_ck:
' Ack_flag = 1 '&h15 NAK
Clear Serialin
Case Else:
' Ack_flag = 0
Clear Serialin
End Select
Close #1 |
Regards
Pikczu |
