Understanding (or not) Timer freq mode
hzz
PostPosted: Sat Mar 09, 2019 12:46 pm    Post subject: Understanding (or not) Timer freq mode Reply with quote
In the following code timers E1 and E0 are configured equally; however the outputs at pin PE4 (Timer E1 compare A output) and pin PE0 (Timer E0 compare A output) are very different. Why? (BASCOM 2.0.8.1 - Board Crumb xmega128A3)
'________________________________________________________________________________
'                     Test frequency generation to drive a Buzzer
$regfile = "xm128A3Udef.dat"
$hwstack = 256
$swstack = 128
$framesize = 128
'  CONFIG SYSTEM CLOCK
  Config Osc = Disabled , Extosc = Enabled , Range = 12mhz_16mhz , Startup = Xtal_16kclk , 32khzosc = Enabled , Pllosc = Enabled , Pllsource = Extclock , Pllmul = 2       ' 16x2=32MHz
  Config Sysclock = Pll , Prescalea = 1 , Prescalebc = 1_1  ' 32/1=32 MHz
  $crystal = 32000000
    Config Tce1 = Freq , Prescale = 64 , Comparea = Enabled , Resolution = 16
    Tce1_cca = 277
    Config Tce0 = Freq , Prescale = 64 , Comparea = Enabled , Resolution = 16
    Tce0_cca = 277
End                                                    'end program
(BASCOM-AVR version : 2.0.8.1 )
hzz
PostPosted: Sat Mar 09, 2019 6:04 pm    Post subject: Reply with quote
But this does work as expected:
$hwstack = 256
$swstack = 128
$framesize = 128
  $crystal = 32000000
    Config Tce1 = Freq , Prescale = 64 , Comparea = Enabled , Resolution = 8
    Tce1_cca = 88
    Config Tce0 = Freq , Prescale = 64 , Comparea = Enabled , Resolution = 8
    Tce0_cca = 88
End                                                    'end program
It seems that Resolution cannot be put =16 in frequency generation mode
PostPosted: Sun Mar 10, 2019 5:12 pm    Post subject: Reply with quote
I'd say what you're doing raises questions, the help tells:
RESOLUTION
Valid options : NORMAL, BYTE, SPLIT.
Nonetheless you put 8 or 16 as option and you wonder about odd behavior?
Beside I was able to find out that by using proper arguments like RESOLUTION = BYTE/NORMAL the code works as desired.
I spared myself the effort to find out what chaotic/nonlinear/miracle side-effects the improper user configuration did create, as it is much less effort if the user simply follows parameter syntax.
In your case also a look into the data sheet would have been advisable, there you would have found:
14.12.5 CTRLE Control register E
---Bit 1:0 BYTEM[1:0]: Byte Mode
------These bits select the timer/counter operation mode according to Table 14-7 on page 166 .
---------BYTEM[1:0] Group Configuration Description
------------00 NORMAL Timer/counter is set to normal mode (timer/counter type 0)
------------01 BYTEMODE Upper byte of the counter (CNTH) will be set to zero after each counter clock cycle
------------10 SPLITMODE Timer/counter 0 is split into two 8-bit timer/counters (timer/counter type 2)
If you compare the keywords with those from the help, it should have rang a bell not to use nonsense values like 8 or 16.
