Strange behavior with TWIxslave
Tiny
PostPosted: Tue Feb 12, 2019 3:03 pm    Post subject: Strange behavior with TWIxslave Reply with quote
I'm busy with making a i2c boot loader for the atxmega32a4u.
When the master sends data to the slave, everything's is fine until the "Twic_btw" counter is reaching the value of 56. After that on the next byte that is received the "Twic_btw" counter get the value of the "twic" + 1
Example
Twic: 113 Twic_btw : 53
Twic: 224 Twic_btw : 54
Twic: 112 Twic_btw : 55
Twic: 147 Twic_btw : 56
Twic: 98 Twic_btw : 148
Twic: 6 Twic_btw : 149
Twic: 114 Twic_btw : 150
Twic: 224 Twic_btw : 151
Regard Tiny
below is my testcode
'Compiler 2.0.8.1.000
'Cpu        : AtxMega32a4u
'crystal    : 8Mhz external
'eprom size 1024 byte's
'Fuses:
'  WDWP     = 8CLK
'  WDP      = 8CLK
'  BOOTRST  = BOOTLDR
'  TOSCSEL  = XTAL
'  BODPD    = DISABLED
'  RSTDISBL = [unchecked]
'  SUT      = 4MS
'  WDLOCK   = [unchecked]
'  BODACT   = CONTINUOUS
'  EESAVE   = [unchecked]
'  BODLVL   = 2V4
$regfile = "xm32a4udef.dat"
$hwstack = 120                                              'setup Stacks
$swstack = 120
$framesize = 120
'$loadersize = 4096                                          ' bootloader starts after the application
'  constanten
Config_constanten:
   Config Submode = New
   Const Buildnumber = " 1.0.0.0"
   Const Debugoutput = 1
'  Config i/o
Config_io:
'  Config Porta.0 =        '
'  Config Porta.1 =
'  Config Porta.2 =
   Config Porta.3 = Output
   Config Porta.4 = Output
'  Config Porta.5 =
   Config Porta.6 = Input
   Config Porta.7 = Input
'  Config Portb.0 =
'  Config Portb.1 =
'  Config Portb.2 =        '
'  Config Portb.3 =
   Config Portc.0 = Output                                  'SDA
   Config Portc.1 = Input                                   'SCL
   Config Portc.2 = Input
   Config Portc.3 = Output                                  'TXD Debug
   Config Portc.4 = Input
   Config Portc.5 = Input
'  Config Portc.6 =
'  Config Portc.7 =
   Config Portd.0 = Input
   Config Portd.1 = Input
'  Config Portd.2 =
   Config Portd.3 = Output                                  'Led 1
   Config Portd.4 = Output                                  'Led 2
   Config Portd.5 = Output                                  'Led 3
'  Config Portd.6 =
'  Config Portd.7 =
'  Config Porte.0 =
'  Config Porte.1 =
'  Config Porte.2 =
'  Config Porte.3 =
'  Config Portr.0 =
'  Config Portr.1 =
'  Config dim
Config_dim:
   Dim I2c_receivebyte(10) As Byte
   Dim I2c_receiverstop As Bit
'  Config alias
Config_alias:
   Led1 Alias Portd.3
   Led2 Alias Portd.4
   Led3 Alias Portd.5
'  Config Clock
'  Enable the external oscillator with Range 2MHz....9MHz
Config_clock:
   Config Osc = Disabled , Extosc = Enabled , Range = 2mhz_9mhz , Startup = Xtal_256clk
   Config Sysclock = External , Prescalea = 1 , Prescalebc = 1_1
'   Config timer 0 as 100mS ticker
'       1
'   (8MHz/256) = 0.00032 x 3125  --> 100mSecOne Tick
'   Setup overflow interrupt of Timer/Counter C0 and
'   Enable overflow interrupt in LOW Priority
Config_tcc0:
   Config Tcc0 = Normal , Prescale = 256
   Tcc0_per = 3125
   On Tcc0_ovf Tc0_isr
   Enable Tcc0_ovf , Lo
'  Config compoort
Config_comport:
   Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
   Open "COM1:" For Binary As #1
'  Config eeprom
Config_eeprom:
   Config Eeprom = Mapped
'  Configure TWI Slave hardware registers. Base address is 90 but we twiddle
'  the TWAR register if we want a secondary address
Config_twi:
   Config Scl = Portc.1                                     ' we need to provide the SCL pin name
   Config Sda = Portc.0                                     ' we need to provide the SDA pin name
   Dim Twi_start As Byte , B As Byte
   Config Twicslave = &H46 , Btr = 2                        'use address &H70 which is
'  Config Defaults
Config_defaults:
'  Config interrupts
Config_interupts:
   Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled , Hi = Enabled
   Enable Interrupts                                        'TWIC needs interrupts
' Enter main loop
Main:
   Set Led2
   Reset Led3
   Dim Tempb As Byte
   Tempb = &HFF
   Dim Tt As Byte
      If I2c_receiverstop = 1 Then                          'all data is received
         #if Debugoutput = 1
            Print #1 , "recieve completed"
         #endif
         I2c_receiverstop = 0
         Select Case I2c_receivebyte(1)
            Case 10:
            Case 11:
            Case 12:
            Case 13:
' Timer 0 isr routine
Tc0_isr:
   Toggle Led1
'   TWIC routines
Twi_stop_rstart_received:                                   'Single byte commands
   #if Debugoutput = 1
      Print #1 , "Master sent stop or repeated start"
   #endif
   Set I2c_receiverstop
Twi_addressed_goread:
   #if Debugoutput = 1
      Print #1 , "We were addressed and master will send data"
   #endif
Twi_addressed_gowrite:
   #if Debugoutput = 1
      Print #1 , "We were addressed and master will read data"
   #endif
Twi_gotdata:
   #if Debugoutput = 1
      Print #1 , "Twic: " ; Twic ; " Twic_btw : " ; Twic_btw
   #endif
   I2c_receivebyte(twic_btw) = Twic
Twi_master_needs_byte:
   #if Debugoutput = 1
      Print #1 , "Master needs byte : " ; Twic_btr
   #endif
   Twic = 56
Twi_master_need_nomore_byte:
   #if Debugoutput = 1
      Print #1 , "Master does not need anymore bytes"
   #endif
PostPosted: Tue Feb 12, 2019 9:00 pm    Post subject: Re: Strange behavior with TWIxslave Reply with quote
A bit too busy it seems.
Does that give you some hint?
If it's the game of 'catch the bug in lengthy code', you certainly have a point. Very Happy
Tiny
PostPosted: Tue Feb 12, 2019 9:36 pm    Post subject: Reply with quote
the dim array declaration is to small Embarassed, but the "Print #1 , "Twic: " ; Twic ; " Twic_btw : " ; Twic_btw" command shows the error.
Twi_gotdata:
   #if Debugoutput = 1
   #endif
PostPosted: Tue Feb 12, 2019 10:01 pm    Post subject: Reply with quote
You can do forensic examinations of why an overwritten memory range will produce a certain fault condition, which is then shown via print.
It actually can be done to find out exactly why this happens, you need to check which variables are affected and watch for interactions.
But this may serve academic purposes only.
Better fix the too small array and report if the effect is gone.
Tiny
PostPosted: Tue Feb 12, 2019 10:04 pm    Post subject: Reply with quote
I will fix the small array and check it tomorrow
Tiny
PostPosted: Wed Feb 13, 2019 7:53 am    Post subject: Reply with quote
Thanks MWS,
It was the to small array declaration. Embarassed
