Usart problem on ATxmega384C3
P_Santos
PostPosted: Fri Feb 08, 2019 12:47 am    Post subject: Usart problem on ATxmega384C3 Reply with quote
I'm use the Xmega384C3 to communicate to a HM11 Bluetooth module
If i send the command Print #5 , "AT+DISC?" from a computer with serial adapter, the HM11 understand every time the commnd and respond correctly,
but if send the same command trough the microcontroller, it works only one or two times
Can anyone help?
What make i wrong?
This is the code for setup the Usart and Timer
'****************************** Usart for HM11 *********************************
' portE.2/portE.3 - to BLE HM11
Config Com5 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "Com5:" For Binary As #5
Config Serialin4 = Buffered , Size = 70
'***************************** TIMER ******************************
Config Priority = Static , Vector = Application , Lo = Enabled ' , Med = Enabled , Hi = Enabled
'Timer C0
Config Tcc0 = Normal , Prescale = 1024
Tcc0_per = 31250
On Tcc0_ovf acorda 'Setup overflow interrupt do Timer/Counter C0
Enable Tcc0_ovf , Lo 'Activa overflow interrupt em LOW Priority
Best regards and thanks for help
P_Santos
PostPosted: Fri Feb 08, 2019 1:04 am    Post subject: Reply with quote
By default, after Print command Bascom add <CR><LF>
If you add semicolon at the end then those two characters will not be added. Then you can add one of them yourself.
Try one of this commands:
Print #5 , "AT+DISC?{013}" ;
Print #5 , "AT+DISC?{010}" ;
or catch this proper command from PC with second serial adapter or even uC with LCD how its look in binary.
P_Santos
PostPosted: Fri Feb 08, 2019 1:22 pm    Post subject: Reply with quote
Hello EDC,
Thank you, but it continue not working
Attached pictures of logic analyser of both, send trough serial adapter and from Atxmega TX pin
The voltage on the serial adapter TX is about 3,26V, on the Atxmega TX pin is about 3,21V
Tested with other terminal programms, send AT+DISC? with 10 or 13 or nothing on the end, the HM11 understand all that
The Usart configuration is
' portE.2/portE.3 - BLE HM11
The command from the Atxmega is Print #5, "AT+DISC?"
What is my mistake?
P_Santos
PostPosted: Fri Feb 08, 2019 1:31 pm    Post subject: Reply with quote
It looks like some baudrate error.
Do you try automatic clock calibration?
After Config clock and Config Sysclock for your config/speed try add last two lines from this example.
' ***************** SYSTEM CLOCK CONFIG **************************
'                INTERNAL 32MHz NO PRESCALE
' ENABLING AUTOMATIC OSCILLATOR CALIBRATION
    Osc_dfllctrl.0 = 1
     Dfllrc32m_ctrl.0 = 1
P_Santos
PostPosted: Fri Feb 08, 2019 1:51 pm    Post subject: Reply with quote
Sorry, the same result, mention of framming error
PostPosted: Fri Feb 08, 2019 2:06 pm    Post subject: Reply with quote
Better add to topic short but complete code that can be compiled.
Like this but with your settings.
Remember that declared $crystal=xxxxxxxxxx should/must match your Sysclock settings because registers for baudrate are set for clock speed you declare in "$crystal".
If real speed of uC is different then you end with result like yours.
$regfile = "xm128a3udef.dat"                                'FLASH-128KB,SRAM-8KB,EEP-2KB,7xTIMER,4xDMA,7xUSART,3xSPI,2xTWI,USB
$crystal = 32000000                                         '32MHz
$hwstack = 128                                              'FLASH 10K TIMES
$swstack = 128                                              'EEPROM 100K TIMES
$framesize = 512
    Osc_dfllctrl.0 = 1
...and every Xmega starts with internal 2MHz so code below should print correctly too (I think).
$regfile = "xm384C3def.dat"
$crystal = 2000000                                          '2MHz
$hwstack = 128
$swstack = 128
$framesize = 512
P_Santos
PostPosted: Fri Feb 08, 2019 2:23 pm    Post subject: Reply with quote
Hello IDC,
You are good
Now it works after add 32khzosc = Enabled to my Config Osc = Disabled , 32mhzosc = Enabled
now is: Config Osc = Disabled , 32mhzosc = Enabled , 32khzosc = Enabled
A question, why is Config Osc = Disabled, must it be Enabled
Thank you very much
Best reagards
P_Santos
PostPosted: Fri Feb 08, 2019 2:32 pm    Post subject: Reply with quote
Explanation for the question is in Help/Wiki page. Read -> https://wiki.mcselec.com/bavr/CONFIG_OSC
You can always hit F1 in the Bascom code editor if cursor blink near some statements Very Happy
On the mcs main page you can find section Application Notes where one of the topic is 'Statring with Xmegas"
Direct link -> https://www.mcselec.com/index.php?option=com_content&task=view&id=306&Itemid=57
..but is worth to read more of them Wink
