P_Santos
Posted: Fri Feb 08, 2019 12:47 am Post subject: Usart problem on ATxmega384C3 |
Hello,
I'm use the Xmega384C3 to communicate to a HM11 Bluetooth module
If i send the command Print #5 , "AT+DISC?" from a computer with serial adapter, the HM11 understand every time the commnd and respond correctly,
but if send the same command trough the microcontroller, it works only one or two times
Can anyone help?
What make i wrong?
This is the code for setup the Usart and Timer
'****************************** Usart for HM11 *********************************
' portE.2/portE.3 - to BLE HM11
Config Com5 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "Com5:" For Binary As #5
Config Serialin4 = Buffered , Size = 70
'***************************** TIMER ******************************
Config Priority = Static , Vector = Application , Lo = Enabled ' , Med = Enabled , Hi = Enabled
'Timer C0
Config Tcc0 = Normal , Prescale = 1024
Tcc0_per = 31250
On Tcc0_ovf acorda 'Setup overflow interrupt do Timer/Counter C0
Enable Tcc0_ovf , Lo 'Activa overflow interrupt em LOW Priority
Best regards and thanks for help
P_Santos
(BASCOM-AVR version : 2.0.8.1 ) |
Posted: Fri Feb 08, 2019 1:04 am Post subject: |
By default, after Print command Bascom add <CR><LF>
If you add semicolon at the end then those two characters will not be added. Then you can add one of them yourself.
Try one of this commands:
Code: | Print #5 , "AT+DISC?{013}" ;
Print #5 , "AT+DISC?{010}" ; |
or catch this proper command from PC with second serial adapter or even uC with LCD how its look in binary. |
P_Santos
Posted: Fri Feb 08, 2019 1:22 pm Post subject: |
Hello EDC,
Thank you, but it continue not working
Attached pictures of logic analyser of both, send trough serial adapter and from Atxmega TX pin
The voltage on the serial adapter TX is about 3,26V, on the Atxmega TX pin is about 3,21V
Tested with other terminal programms, send AT+DISC? with 10 or 13 or nothing on the end, the HM11 understand all that
The Usart configuration is
' portE.2/portE.3 - BLE HM11
The command from the Atxmega is Print #5, "AT+DISC?"
What is my mistake?
Best regards
P_Santos |
Posted: Fri Feb 08, 2019 1:31 pm Post subject: |
It looks like some baudrate error.
Do you try automatic clock calibration?
After Config clock and Config Sysclock for your config/speed try add last two lines from this example.
Code: | ' ***************** SYSTEM CLOCK CONFIG **************************
' INTERNAL 32MHz NO PRESCALE
Config Osc = Disabled , 32mhzosc = Enabled , 32khzosc = Enabled
' ENABLING AUTOMATIC OSCILLATOR CALIBRATION
Osc_dfllctrl.0 = 1
Dfllrc32m_ctrl.0 = 1
P_Santos
Posted: Fri Feb 08, 2019 1:51 pm Post subject: |
Sorry, the same result, mention of framming error
Regards |
Posted: Fri Feb 08, 2019 2:06 pm Post subject: |
Better add to topic short but complete code that can be compiled.
Like this but with your settings.
Remember that declared $crystal=xxxxxxxxxx should/must match your Sysclock settings because registers for baudrate are set for clock speed you declare in "$crystal".
If real speed of uC is different then you end with result like yours.
Code: | $regfile = "xm128a3udef.dat" 'FLASH-128KB,SRAM-8KB,EEP-2KB,7xTIMER,4xDMA,7xUSART,3xSPI,2xTWI,USB
$crystal = 32000000 '32MHz
$hwstack = 128 'FLASH 10K TIMES
$swstack = 128 'EEPROM 100K TIMES
$framesize = 512
Osc_dfllctrl.0 = 1
...and every Xmega starts with internal 2MHz so code below should print correctly too (I think).
Code: | $regfile = "xm384C3def.dat"
$crystal = 2000000 '2MHz
$hwstack = 128
$swstack = 128
$framesize = 512
Wait 1
P_Santos
Posted: Fri Feb 08, 2019 2:23 pm Post subject: |
Hello IDC,
You are good
Now it works after add 32khzosc = Enabled to my Config Osc = Disabled , 32mhzosc = Enabled
now is: Config Osc = Disabled , 32mhzosc = Enabled , 32khzosc = Enabled
A question, why is Config Osc = Disabled, must it be Enabled
Thank you very much
Best reagards
P_Santos |
