secelapsed fehler invalid data type [[0011]0[_SEC]]
gwabbel
PostPosted: Sat Jan 26, 2019 1:16 pm    Post subject: secelapsed fehler invalid data type [[0011]0[_SEC]] Reply with quote
Hi all,
i have found an error in bascom version 2.0.8.1 - if you do a syntax check the following code will produce an error by refering to the functions secofday() and secelapsed(var_long). The error is: invalid data type [[0011]0[_SEC]] although the variables are of the right type (long).
bascom code:
$framesize = 200
$swstack = 200
$hwstack = 200
'Microcontrollertyp festlegen
$regfile = "m328pdef.dat"
'Taktfrequenz 16MHz extern
$crystal = 16000000
'Baudrate 38400 , 8,N,1
$baud = 38400
Dim Sekunde As Long
Dim Timestamp As Long
Timestamp = Secofday()
Wait 5
Sekunde = Secelapsed(timestamp)
If Sekunde > 30 Print "Hallo"
Has anyone an idea what I'm doing wrong?
Many thanks for an answer!
enniom
PostPosted: Sun Jan 27, 2019 3:26 pm    Post subject: Reply with quote
Where is Config Clock?
Then try
Timestamp = Syssec()
E
PostPosted: Mon Jan 28, 2019 10:19 am    Post subject: Reply with quote
i see that the help not clearly mention that you need to use CONFIG CLOCK in order to use the date/ time functions.
Please see help about CONFIG CLOCK and add it to your code.
gwabbel
PostPosted: Fri Feb 01, 2019 5:16 pm    Post subject: Reply with quote
.... thank you ! now it works!
regards
Georg
