Strange results form variable calculations
JL
PostPosted: Thu Jan 10, 2019 6:15 pm    Post subject: Strange results form variable calculations Reply with quote
Hello,
in my program I noticed some strange behaviour of some variables. All definitions are correct, no error messages etc. form compiler. The purpose of the program is to read an RC pulse and divide the measured range into 14 steps to control some lights.
wSwitchStep is 71, SwitchTolerance is 10, wPulseMinStore is 984
wLowLightWarn = wSwitchStep * 8 : wLowLightWarn = wLowLightWarn + wPulseSwitchMinStore
wLowLightWarnLow = wLowLightWarn - SwitchTolerance
wLowLightWarnHigh = wLowLightWarnHigh + SwitchTolerance
These definitions result in wLowLightWarn = 1552, wLowLightWarnLow = 1542, but wLowLightWarnHigh = 20 (!)
I'm using the same logic of variable assignment for the other switching states and there everything is o.k.
If I rename the variable like this, the calculation is correct.
wWarn= wSwitchStep * 8 : wWarn = wWarn + wPulseSwitchMinStore
wWarnL = wWarn - SwitchTolerance
wWarnH = wWarn + SwitchTolerance
Does somebody has an idea, what can cause this calculation error for variable wLowLightWarnHigh?
(BASCOM-AVR version : 2.0.8.1 )
Best regards
Jürgen
laborratte
PostPosted: Thu Jan 10, 2019 7:13 pm    Post subject: Reply with quote
Most likely a High too much: wLowLightWarnHigh = wLowLightWarnHigh + SwitchTolerance
JL
PostPosted: Fri Jan 11, 2019 10:57 am    Post subject: Reply with quote
laborratte wrote:
Most likely a High too much:...
Yes, that's it.
Believe me (or not); I spent some hours to find the cause, and wasn't able to see it Brick wall Brick wall in that bunch of code lines with similar definitions. It's the typical behaviour of seeing not the wood for the trees Wink
Best regards
Jürgen
