How to Write and Read XMega User Signatures
Goto page Previous  1, 2
enniom
https://www.mcselec.com/c
PostPosted: Wed Jan 09, 2019 10:22 pm    Post subject: Reply with quote
This code works perfectly to access the XMega User Signature:
$regfile = "xm192A3Udef.dat"
$hwstack = 80
$swstack = 80
$framesize = 80
$crystal = 32000000
Config Osc = Disabled , 32mhzosc = Enabled
$loader = $18000                                            'Bootloader START Address
Disable Interrupts
Config Submode = New
Config Com7 = 56700 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "COM7:" For Binary As #1
Const Bascom = "BASCOM"
Dim B_io As Byte , W As Word , Z As Dword , Ss As String * 6 , Buf(6) As Byte At Ss Overlay
Ss = Bascom
Declare Sub User_sig(byval Rd_wr_er As Byte , Byval Offset As Word , Byref B_io As Byte)
     Z = Offset
     Pushall
     !lds r30,{Z}                                           'Will not accept Local Variables
     !lds r31,{Z+1}                                         'Global DIM Z is used
     Select Case Rd_wr_er
          Case 0
               Nvm_cmd = &H01                               'read
               Cpu_ccp = &H9D
               !lpm
          Case 1
               Nvm_cmd = &H1A                               'write
               Cpu_ccp = &H9D
               !spm
          Case 2
               Nvm_cmd = &H18                               'erase
               Cpu_ccp = &H9D
               !spm
          Case 3
               Nvm_cmd = &H23                               'move data to Flash Buffer
               Cpu_ccp = &H9D
               !spm
Nvm_wait:
     !lds r23, NVM_STATUS
     !sbrc r23,7
     !rjmp nvm_wait
     If Rd_wr_er = 0 Then !sts {b_io} , R0      'contents of User Signature
     Popall
'MAIN
     Call User_sig(2 , &H0000 , B_io)                       'Erase - This erases the
                                                            'complete 512 User Signature
                                                            'byte-space
     For W = 1 To 6 Step 2
          R0 = Buf(w)                                       'move data to r0 and r1 registers
          R1 = Buf(w + 1)
          Call User_sig(3 , W , B_io)                       'move to Flash Buffer
     Call User_sig(1 , &H0000 , B_io)                       'Write User Signature
                                                            'This was confirmed with ATMEL Studio
For W = 0 To 5
          Call User_sig(0 , W , B_io)                       'READ
          Print #1 , Chr(b_io) ;
Thanks to Laborratte, Mark Alberts and Netzman.
[ NOTE: the description given in AVR1316 about "byte" access to the User Signature is only true for READ operations. ]
E
Page 2 of 2
