GLCD-UC1608-SPI library from Mrshilov and XMega
ivangel
PostPosted: Tue Oct 30, 2018 7:53 pm    Post subject: GLCD-UC1608-SPI library from Mrshilov and XMega Reply with quote
I have LCD based on UC1608 chip, connected with XMEGA 256 A3U, with SPI. I use library Mrshilov and at the beginning I had a problem with displaying characters and graphics. For correct displaying of characters it was enough to change in the original library ld / st to ldd / std and r23 to change to r11. Unfortunately the graphics either hangs up the CPU or it displays badly. I am asking for help because I\\\\\\\\\\\\\\\'m not good at Assembler
Code of modified library in Attachment
www.BlasterON.pl
Mrshilov
Bascom LCD Guru
PostPosted: Fri Nov 02, 2018 11:21 pm    Post subject: Reply with quote
Try to use virtual port. Like this:
$regfile = "xm256a3udef.dat"
$crystal = 32000000
$hwstack = 100
$swstack = 100
$framesize = 100
Config Osc = Disabled , 32mhzosc = Enabled
Config Vport0 = A
Config Port0 = Output
$lib "glcd-UC1608-spi.lib"
Config Graphlcd = 128x64sed , Si = Port0.0 , Sclk = Port0.1
ivangel
PostPosted: Thu Nov 08, 2018 6:12 pm    Post subject: Reply with quote
Thanx, i will try
www.BlasterON.pl
ivangel
PostPosted: Thu Nov 08, 2018 6:32 pm    Post subject: Reply with quote
Sorry, no luck...
It hangs many times, and finally when it starts it can be seen that the picture is destroyed
Any ideas yet?
its my init code:
Config Vport0 = C
$lib \\\"glcd-UC1608-spi_2.lib\\\"                                \\\'Library must be in LIB directory
\\\'$lib \\\"glcd-UC1608-spi.lib\\\"
Config Graphlcd = 128x64sed , Si = Port0.7 , Sclk = Port0.5
\\\' \\\"Sclk\\\" must be connected to D0 of display
\\\'  \\\"Si\\\"  must be connected to D3 of display
\\\' D6 of display must be connected to GND
\\\' D7 of display must be connected to +3,3V
\\\' CD, WR0, WR1, BM0, BM1 of display must be connected to GND
\\\'Const Negative_lcd = 1                                      \\\'Optional screen inversion
Const Rotate_lcd = 1                                        \\\'Optional rotate screen to 180
Initlcd
www.BlasterON.pl
