Extended SPI
Darkcoder
PostPosted: Wed Oct 31, 2018 10:28 am    Post subject: Extended SPI Reply with quote
Hello everyone!
Does anyone manage to make the SPI extended mode work under 2.0.8.1 version?
I'm trying to config the SPI but it doesn't recognize it.
I'm using hard SPI and avr328 controller
Thank you
(BASCOM-AVR version : 2.0.8.1 , Latest : 2.0.8.1 )
PostPosted: Wed Oct 31, 2018 10:38 am    Post subject: Reply with quote
i can not find any info in the data sheet about extended mode. so it is not really clear what you refer to.
exactly where is this mode documented?
Darkcoder
PostPosted: Wed Oct 31, 2018 10:42 am    Post subject: Reply with quote
Thank you for your quick awnser
here you mention it
https://www.mcselec.com/index.php//index2.php?option=com_forum&Itemid=59&page=viewtopic&t=14024&highlight=&sid=b17f9e1a6d2db5e7f925b7d81b265c7d
- CONFIG SPI has a new option : EXTENDED=1 to have extended data size reading/writing.
and here
https://avrhelp.mcselec.com/index.html?config_spi.htm
EXTENDED
An optional parameter to extend the maximum data read/write size.
A value of 0 is default and will cause the SPIIN, SPIIOUT, SPIMOVE routines to handle a maximum data size of 255 bytes.
A value of 1 will extended the data size from bytes to words which means you can move data of 65535 bytes.
PostPosted: Wed Oct 31, 2018 10:51 am    Post subject: Reply with quote
ok, so this is not a real SPI option but a bascom option. it should work while compiling. but the dat files seems to be missing this option. i will have it checked.
PostPosted: Wed Oct 31, 2018 10:59 am    Post subject: Reply with quote
i had another look. the dat file is ok. but this option seems to be implemented for soft spi only. it could be the help file is wrong, or that the config option is missing for hardware. i will sort it out and let you know.
PostPosted: Wed Oct 31, 2018 11:07 am    Post subject: Reply with quote
this is a bug : both software and HW SPI (first channel) should support this mode. but the code for supporting this was put at the wrong place with the effect that only SOFT SPI (and xmega) support it. I have changed it for 2082.
Darkcoder
PostPosted: Wed Oct 31, 2018 11:30 am    Post subject: Reply with quote
Thank you very much! So if i want to use extended mode at the moment it works only at softspi?
Do you have any plan about the release of next update?
PostPosted: Wed Oct 31, 2018 11:37 am    Post subject: Reply with quote
you need to use either software spi or xmega in the current release.
we do not give release dates.
