$regfile = "m328pdef.dat"
$crystal = 16000000
$baud = 9600
$hwstack = 40
$swstack = 40
$framesize = 40
$lib "I2C_TWI.LBX"
Config I2cdelay = 1 '10
Config Twi = 100000
Config Scl = Portc.5
Config Sda = Portc.4
Dim M As Word
Dim Rejestr(27) As Byte
Dim Ch0_byte1 , Ch0_byte2 As Byte
Dim Ch0_word As Word
Dim Ch1_byte1 , Ch1_byte2 As Byte
Dim Ch1_word As Word
Dim Proxl , Proxh As Byte
Dim prox_word as Word
Dim Addr_w As Byte
Dim Addr_r As Byte
Dim Apds_base , Apds_adres , Wynik As Byte
Dim Tmp As Byte
Declare Sub Writeregdefault(byval Nr_rejestru As Byte , Byval Zmienna As Byte)
Declare Function Readreg(byval Nr_rejestru As Byte) As Byte
Addr_w = &H72
Addr_r = &H73
Rejestr(1) = &H00
Rejestr(2) = &H01 'ATIME
Rejestr(3) = &H02 'PTIME
Rejestr(4) = &H03 'WTIME
Rejestr(5) = &H04 'AILTL
Rejestr(6) = &H05 'AILTH
Rejestr(7) = &H06 'AIHTL
Rejestr(8) = &H07 'AIHTH
Rejestr(9) = &H08 'PILTL
Rejestr(10) = &H09 'PILTH
Rejestr(11) = &H0A 'PIHTL
Rejestr(12) = &H0B 'PIHTH
Rejestr(13) = &H0C 'PERS
Rejestr(14) = &H0D 'CONFIG
Rejestr(15) = &H0E 'PPULSE
Rejestr(16) = &H0F 'CONTROL
Rejestr(17) = &H10
Rejestr(18) = &H11
Rejestr(19) = &H12 'ID
Rejestr(20) = &H13 'STATUS
Rejestr(21) = &H14 'Ch0DATAL
Rejestr(22) = &H15 'Ch0DATAH
Rejestr(23) = &H16 'Ch1DATAL
Rejestr(24) = &H17 'Ch1DATAH
Rejestr(25) = &H18 'PDATAL
Rejestr(26) = &H19 'PDATAH
Rejestr(27) = &H1E 'POFFSET
Apds_base = &HA0
I2cinit
'***************** Write to registers ******************
Call WriteRegDefault(1 , &H05) '05 - proximity, 03-light sensor -> according to z datasheetem page 19
Call WriteRegDefault(2 , &HED)
Call WriteRegDefault(4 , &HFF)
Call WriteRegDefault(15 , &H08)
Call WriteRegDefault(27 , &H00)
Call WriteRegDefault(14 , &H00)
Call WriteRegDefault(9 , &H00)
Call WriteRegDefault(10 , &H00)
Call WriteRegDefault(11 , &H32)
Call WriteRegDefault(12 , &H00)
Call WriteRegDefault(13 , &H22)
'PDRIVE, PDIODE, PGAIN, AGAIN -> CONTROL
I2cstart
I2cwbyte Addr_w
Tmp = Rejestr(16)
I2cwbyte Apds_base Or Tmp 'write to CONTROL register
' wynik = &B00000000 or &B00100000 or &B00001100 =&H2C
I2cwbyte &H2C
I2cstop
'***************** Read from registers ******************
For M = 1 To 27
I2cstart
I2cwbyte Addr_w
Tmp = Rejestr(m)
I2cstart
I2cwbyte Addr_r
I2crbyte Apds_adres , Nack
I2cstop
Print Hex(rejestr(m)) ; " " ; Hex(apds_adres)
Next M
Waitms 100
'********** PROXIMITY SENSOR '********** Enable=&H05
ProxH = ReadReg(26)
Waitms 20
ProxL = ReadReg(25)
Waitms 20
prox_word = Makeint(proxL , proxH)
Print "proximity: " ; prox_word
''********** LIGHT SENSOR '********** Enable=&H03
'CH0
Ch0_byte2 = ReadReg(22)
Waitms 20
Ch0_byte1 = ReadReg(21)
Waitms 20
'CH1
Ch1_byte2 = ReadReg(24)
Waitms 20
Ch1_byte1 = ReadReg(23)
Ch0_word = Makeint(ch0_byte1 , Ch0_byte2)
Ch1_word = Makeint(ch1_byte1 , Ch1_byte2)
Print "ch0: " ; Ch0_word ; " ch1: " ; Ch1_word
Waitms 100
Sub WriteRegDefault(byval Nr_rejestru As Byte , Byval Zmienna As Byte)
I2cstart
I2cwbyte Addr_w
Tmp = Rejestr(nr_rejestru)
I2cwbyte Zmienna
I2cstop
End Sub
Function ReadReg(byval Nr_rejestru As Byte) As Byte
I2cstart
I2cwbyte Addr_w
I2cstart
I2cwbyte Addr_r
I2crbyte Readreg , Nack
I2cstop
End Function
