mansur
Posted: Wed May 16, 2018 2:27 am Post subject: SD Card Speed Clock |
Dear All,
How many the maximum speed if we use atxmega to write the uSD Card (class 6) with logic converter (3v3 level). we want to use the pll clock until 48 MHZ or 64MHZ.
Yesterday i try to write the uSD card with logic converter with crystal set=32 MHZ and SPI clock CLK2 the result is success, but i try to edit and change the main clock to 48 MHZ, the uSD card not respons if CLK2, i'ts mean the logic converter not match with this clock.
any body already try without logic converter and pll clock?
(BASCOM-AVR version : 2.0.8.1 , Latest : 2.0.8.1 ) _________________ Mansur. H
Automation & Instrument Engineer |
Posted: Wed May 16, 2018 1:02 pm Post subject: |
Max default clock speed for a sd card is 48Mhz.
If you power up an sd-card it will always work on 3.3V, 1 bit bus and max. 45mhz clock. This to make all the new fast cards downwards compatible.
If you want a higher clock speed, lower voltage (1.8V) or change bus width you have to negotiate with the card to change the settings. Ask the card what he (or she) is capable of and then change the settings.
I did it in C, but never in Bascom. Hope you can find some examples else it's a long way to go. _________________ www.evertdekker.com Bascom code vault |
mansur
Posted: Tue May 22, 2018 5:24 am Post subject: |
[quote=\"Evert \"]Max default clock speed for a sd card is 48Mhz.
I did it in C, but never in Bascom. Hope you can find some examples else it\'s a long way to go.[/quote]
Hi evert,
thanks for your advice, i will try to replace the logic converter for sd card. _________________ Mansur. H
Posted: Tue May 22, 2018 1:56 pm Post subject: |
With Xmega you dont need the level converter. Xmega 3.3V ... SDCard 3.3V
To the Xmega I always link SDCard directly. |
mansur
Posted: Tue Jun 05, 2018 6:27 am Post subject: |
EDC wrote: | With Xmega you dont need the level converter. Xmega 3.3V ... SDCard 3.3V
Dear All,
The xmega with clock PLL to 48 MHZ success to write and read the SD card with class 10 capacity 32GB, the SPI clock prescaler set to CLK2.
$regfile = "xm32A4def.dat"
$crystal = 48000000 ' frequency used
$hwstack = 200
$swstack = 200
$framesize = 200
Config Osc = Enabled , 32mhzosc = Enabled , 32khzosc = Enabled ', 32khzosc = Enabled 'Enable the 32MHz and 32.768KHz Oscillator
Bitwait Osc_status.1 , Set 'Check if 32MHz Oscillator is ready
Bitwait Osc_status.2 , Set 'Check if internal 32.768 KHz Oscillator is ready
'Init and enable the DFLL (Digital Frequency Locked Loop) for automatic run-time calibration of the internal 32MHz Oscillator
Osc_dfllctrl = &B00000000 'The internal 32.768 KHz Oscillator is used for calibration
Set Dfllrc32m_ctrl.0 'Enable DFLL and autocalibration
'Set the Multiplication factor and select the clock Reference for the PLL
Osc_pllctrl = &B10_0_00110 ' 32MHz clock Source and Multiplication factor = 16
'^ 'Multiplication factor = 8
'PLL Source = 32MHz internal Oscillator (divided by 4 in hardware)
Set Osc_ctrl.4 ' PLL enable
Bitwait Osc_status.4 , Set 'Check if PLL is ready
Config Sysclock = pll , Prescalea = 1 , Prescalebc = 1_1 ' configure the systemclock ---> use PLL
Waitms 2
'config twic=1000
Const Ds3231w = &HD0 ' Addresses of Ds1307 clock
Const Ds3231r = &HD1
'(i2cinit
Dim Twi_start As Byte
Config Clock = User ' this will dim the bytes automatic
config date=DMY, separator=slash
'dim other needed variables
Dim Weekday As Byte
'Time$ = "07:58:00" ' to watch the day changing value
'Date$ = "14-05-18"
Config Com1 = 500000 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Config Priority = Static , Vector = Application , Lo = Enabled 'config interrupts
'$include "CONFIG_AVR-DOS.bas"
$include "Config_MMCSD_HC.bas"
'=====[ Global Vars ]==========================================================
Dim Btemp1 As Byte ' Needed for Fat Drivers
Dim Input_string As String * 100
Dim Output_string As String * 100
Dim File_handle As Byte
Dim File_name As String * 14
Dim X As Long
'Btemp1 = Initfilesystem(1)
Print "Starting... SDHC with ATXMEGA...."
'Print
'=====[ Includes ]============================================================
'$include "config_MMCSD_HC.inc"
Print "SD Card Type = " ;
Select Case Mmcsd_cardtype
Case 0 : Print "can't init the Card"
Case 1 : Print "MMC"
Case 2 : Print "SDSC Spec. 1.x "
Case 4 : Print "SDSC Spec. 2.0 or later"
Case 12 : Print "SDHC Spec. 2.0 or later"
'Print
If Gbdriveerror = 0 Then 'from.... Gbdriveerror = Driveinit()
$include "Config_AVR-DOS.bas" ' Include AVR-DOS Configuration and library
Print "Init File System ... " ;
Btemp1 = Initfilesystem(1) ' Reads the Master boot record and the partition boot record (Sector) from the flash card and initializes the file system
'1 = Partitionnumber
If Btemp1 <> 0 Then
Print "Error: " ; Btemp1 ; " at Init file system"
Print " OK --> Btemp1= " ; Btemp1 ; " / Gbdriveerror = " ; Gbdriveerror
Print "Filesystem = " ; Gbfilesystem
Print "FAT Start Sector: " ; Glfatfirstsector
Print "Root Start Sector: " ; Glrootfirstsector
Print "Data First Sector: " ; Gldatafirstsector
Print "Max. Cluster Nummber: " ; Glmaxclusternumber
Print "Sectors per Cluster: " ; Gbsectorspercluster
Print "Root Entries: " ; Gwrootentries
Print "Sectors per FAT: " ; Glsectorsperfat
Print "Number of FATs: " ; Gbnumberoffats
Print
Print
' Write Text to file
File_handle = Freefile() ' get a file handle
File_name = "My_file.txt"
Open File_name For Output As #file_handle ' open file for output with file_handle
' If the file exist already, the file will be overwritten !
Print #file_handle , "This is my 1 first Text to File with XMEGA !"
Close #file_handle
Print "Write to file done !"
'Now we want to read back the text we wrote to file and print it over Serial Interface
Open "My_file.txt" For Input As #file_handle ' we can use a constant for the file too
Print "File length = " ; Lof(#file_handle)
Line Input #file_handle , Input_string ' read a line
Print Input_string 'print the line
Close #file_handle
'WRITE TO FILE
Print "write to file"
File_name = "Test.txt"
Input_string = "1234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890"
Open File_name For Output As #10
While X < 10000 '10000 * 102 Byte / 100 = 10200 Byte
Print #10 , Input_string
X = X + 100
Wend
Close #10
X = Filelen(file_name)
Print "Total bytes written: " ; X
'READ FROM FILE
Open File_name For Input As #10
While Eof(#10) = 0
Line Input #10 , Output_string ' read a line
If Input_string <> Output_string Then
Print "Buffer Error! near byte: " ; X ; " " ; "[" ; Output_string ; "]"
else
print "Good Data" ;; "[" ; Output_string ; "]"
'Waitms 2000
Wend
Close #10
Print "Write and Readback test done !"
'Print the file name which was created before
Print "Dir function demo"
Input_string = Dir( "*.*")
'The first call to the DIR() function must contain a file mask The * means everything.
' Print File Names
While Len(input_string) > 0 ' if there was a file found
Print Input_string ; " " ; Filedate() ; " " ; Filetime() ; " " ; Filelen()
' print file , the date the fime was created/changed , the time and the size of the file
Input_string = Dir() ' get next
Wend
'Print
'Print "Diskfree = " ; Diskfree()
'Print "Disksize = " ; Disksize()
'Print "Date Time : " ; Date$ ; " " ; Time$
End If 'If Gbdriveerror = 0 Then
'(Getdatetime:
I2cstart ' Generate start code
I2cwbyte Ds3231w ' send address
I2cwbyte 0 ' start address in 1307
I2cwbyte Ds3231r ' send address
I2crbyte _sec , Ack
I2crbyte _min , Ack ' MINUTES
I2crbyte _hour , Ack ' Hours
I2crbyte Weekday , Ack ' Day of Week
I2crbyte _day , Ack ' Day of Month
I2crbyte _month , Ack ' Month of Year
I2crbyte _year , Nack ' Year
I2cstop
_sec = Makedec(_sec) : _min = Makedec(_min) : _hour = Makedec(_hour)
_day = Makedec(_day) : _month = Makedec(_month) : _year = Makedec(_year)
Setdate:
_day = Makebcd(_day) : _month = Makebcd(_month) : _year = Makebcd(_year)
I2cwbyte 4 ' starting address in 1307
I2cwbyte _day ' Send Data to SECONDS
I2cwbyte _month ' MINUTES
I2cwbyte _year ' Hours
I2cstop
Settime:
_sec = Makebcd(_sec) : _min = Makebcd(_min) : _hour = Makebcd(_hour)
I2cwbyte 0 ' starting address in 1307
I2cwbyte _sec ' Send Data to SECONDS
I2cwbyte _min ' MINUTES
I2cwbyte _hour ' Hours
I2cstop
mansur
Posted: Wed Jul 25, 2018 10:35 am Post subject: solved |
i have tried for xmega256a3u with pll clock upto 72mhz.
the prescale of spi for sd card is clk2 for sd card 32gb class 10.
the read and write success. but if increase the clock over 72mhz is not able to read. class 10 has speed limit.
i this 72 mhz is more fast enough. _________________ Mansur. H
mmarlette
Posted: Thu Aug 09, 2018 8:44 pm Post subject: |
This is an interesting example.
Quick look it appears that you are running in SPI divide by 4 mode. So 72/4=18MHZ SPI Clk
My understanding is that the max SPI clock rate is 25MHZ. So it must be a board layout or maybe you are using wires to connect to the SPI bus to the SD card?
Also read somewhere you must init at a lower rate, determine card speed and then increase clk accordingly. Not sure about this as I haven't seen it in the spec yet.
I am going to look in to this a bit more with my Xmega.
Thanks for sharing.
Regards,
Mark |
mmarlette
Posted: Wed Sep 26, 2018 9:18 pm Post subject: |
Finally got back to this to run some test with this and no problem at 24MHZ SPI SCK.
Here are some pictures from the verification process.
mmarlette
Posted: Wed Sep 26, 2018 9:58 pm Post subject: |
Same test software, re-targeted to the Ardunio M2560 board and IDE/ATA/SATA interface defined this time.
This board has a 16MHZ sysclock and the SPI is at /2 or 8MHZ.
The test drive is a Samsung EVO 860 256GB uSATA drive. This thing is SMOK'IN FAST!!!!
Need to make a level translator to do IDE/ATA/SATA on the Xmega, so that test is next.
Hoping to get almost 2MBs there......
Posted: Thu Oct 18, 2018 1:35 am Post subject: |
I have one tip for SDcard + Xmega + Arduino cheap MicroSD CARD board.
This is only valid for Xmega which is 3.3V like SDcard
In this cheap MicroSD card modules CD4050 is mounted. It can transit even 80ns..
So AVRDOS at 32MHz Xmega working only if SCK is divided by 8.
This can be easly fix by removing CD4050 chip and do six solder bricks on the CD4050 pads.
Please refer to CD4050 datasheet.
After this modification you can use uSD at 32MHz/2 for sure |
mansur
Posted: Thu Oct 25, 2018 4:11 am Post subject: |
[quote=\"mmarlette\"]Same test software, re-targeted to the Ardunio M2560 board and IDE/ATA/SATA interface defined this time.
The test drive is a Samsung EVO 860 256GB uSATA drive. This thing is SMOK\'IN FAST!!!!
[/quote]
Hi mmarlette,
can youd share the test code for this test, i will perform some test also to get best performance of read and write data to SD.
Because i have an experince sometime data failed write to sd card and the file change to data corruption (need to format), filename became unidentified name. _________________ Mansur. H
mansur
Posted: Thu Oct 25, 2018 4:14 am Post subject: |
[quote=\"mmarlette\"]This is an interesting example.
Also read somewhere you must init at a lower rate, determine card speed and then increase clk accordingly. Not sure about this as I haven\'t seen it in the spec yet.
Thanks for sharing.
Regards,
Mark[/quote]
I\'m using the direct PCB from atxmega to SD card device (same 3.3 Level). but i\'m still not yet check the actual spi SCK clock using oscilloscope. _________________ Mansur. H
