I think, Config TCP is not confortable with W5500
Goto page 1, 2  Next
katipefendi
PostPosted: Sat Jul 14, 2018 12:06 am    Post subject: I think, Config TCP is not confortable with W5500 Reply with quote
Hi all,
i try to use the code from Atilio Mosca [url] https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=13767&highlight=dhcp [/url]
it is works but only till SETTCP.
After then i have to disconnect and connect the Wire to Cs = PORTB.4. then it works.
Has anybody an idea, why this it is so?
My Config see below:
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 4 , Noss = 0
Spiinit
Config Tcpip = Noint , Mac = 0.8.220.77.05.30 , Ip = Ip_ , Submask = Subnetmask_ , Gateway = Gateway_ , Localport = 2005 ,  Chip = W5500 , Spi = 1 , Cs = Portb.4
plouf
PostPosted: Sat Jul 14, 2018 5:34 am    Post subject: Reply with quote
whats the reason of Cs = Portb.4 ? as i see you use a single hardware SPI
try removing it from config
katipefendi
PostPosted: Sat Jul 14, 2018 11:06 am    Post subject: Reply with quote
Not works
Config Tcpip = Noint , Mac = 0.8.220.77.05.30 , Ip = 192.168.178.77 , Submask = 255.255.255.0 , Gateway = 192.168.178.1 , Localport = 2005 , Chip = W5500 , Spi = 1
Is it Possible the Cs = PORT.4 with BASCOM to disconnect and connect again?
plouf
PostPosted: Sat Jul 14, 2018 12:09 pm    Post subject: Reply with quote
dont understand !
now it works or not ?
C(hip)S(elect) reason is if you have more that 1 conected
katipefendi
PostPosted: Sat Jul 14, 2018 12:30 pm    Post subject: Reply with quote
without Cs = PORT.4 from Config is not work. I have frequently Hard Reset
The Cs have to be in Config, i have this from BASCOM Help.
The Function from Atilio Mosca [url] https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=13767&highlight=dhcp [/url]
Get the DHCP OK if SETTCP it if was set.
But it will not set until I disconnect and reconnect the Cs wire once.
I think tihs is an Error in BASCOM.
plouf
PostPosted: Sat Jul 14, 2018 6:39 pm    Post subject: Reply with quote
i have try here DHCP for 5100 works, then recompile for 5500 and replace chip.... not working
ALSO i have hard time getting my project with 5500 working back .. seems that W5500 lib have some glitches for sure Smile
(i did some test with 5500 since you asked these to check out)
PostPosted: Sat Jul 14, 2018 9:51 pm    Post subject: Reply with quote
Im using W5500 without any problems. Look on the attached pics. One is original (bought in Poland ~20$), second is from China 4,7$
They both work...same Very Happy
Because my Bascom programmed devices have settings for ETH stored in the eeprom Im using this following steps:
1.First of all Im configuring pin SS of hardware SPI as output and set it HIGH(mandatory to be output, set HI is because Im using this pin for CS).
2.Configure Hardware SPI as Master with NOSS = 1 (it means "no ss")
3.Then I configure Wizz with my chosen CS pin. Pin can be same as original SS pin or any other. If another pin is used then I configure it as Output first and set it High.
-Important (for me)-step is that I configure WIzz with parameter Noinit
This is decribed in the Help. So I must complete/can change configuring by Settcp later.
With this order everything works fine for me. I can change settings almost in the fly by sending AT commands.
I also store once sent settings in the eeprom so next boot is quicker.
So ->NOSS=1 ->Noinit parameter ..and when you have alias for the Wizz CS pin then you can use it anytime you want.
katipefendi
PostPosted: Sat Jul 14, 2018 10:54 pm    Post subject: Reply with quote
Yes, TCP is not Problem, the Problem is, if you use the UDP
PostPosted: Sat Jul 14, 2018 10:56 pm    Post subject: Reply with quote
Okay. I will test it tommorow. Im curious Very Happy
katipefendi
PostPosted: Sun Jul 15, 2018 12:47 am    Post subject: Reply with quote
If i use UDP, then I measure the following first picture on the PIN Cs
and
if i use TCP, then I measure the following second picture on the PIN Cs
six1
PostPosted: Thu Aug 23, 2018 7:34 am    Post subject: Reply with quote
@Mark
can you confirm, that DHCP Sample isn't working on WIZ5500 ?
best, Michael
PostPosted: Thu Aug 23, 2018 9:29 am    Post subject: Reply with quote
no, i did not test it on all supported wiz chips. So i can not confirm if it works or not.
it should work but since wiznet makes each new chip totally different, it would not surprise me if there is some difference.
A csw_reset (soft chip reset) is executed, it should be sufficient.
six1
PostPosted: Thu Aug 23, 2018 3:36 pm    Post subject: Reply with quote
thank you Mark!
@katipefendi
check hint from Mark! (csw_reset)
PostPosted: Thu Aug 23, 2018 9:16 pm    Post subject: Reply with quote
I connected the w5500 and while the provided samples work, indeed the Settcp hangs the chip.
After checking it seems that the w5500 register does not reset properly.
According the datasheet : If this bit is 1, All internal registers will be initialized. It will be
automatically cleared as 0 after S/W reset.
So at init and re init the bit is set, then there is a check to see if the bit clears. With a hard reset this seems to work, while with a soft reset, it doesnt.
To fix it, you can remark these lines in the tcpip-w5500.LBX file (open with nodepad)
Search the label _Re_init_tcpip_lp: and remark the lines as shown :
_Re_init_tcpip_lp:
; rcall _read_TCPSPIX
;.OBJ FCD7
; rjmp _Re_init_tcpip_lp
then save.
six1
PostPosted: Fri Aug 24, 2018 9:57 am    Post subject: Reply with quote
Thanks a lot Mark!
Goto page 1, 2  Next
Page 1 of 2
