Posted: Thu Jul 05, 2018 4:08 pm Post subject: Write or Put ?
Hi,*
I never use AVRdos to write somethng, only to read
ex :
Chdir"lalong"
Sentence ="lalong.txt"
Ff =Freefile() Open Sentence ForInputAs #ff
Lineinput #ff , Stdir ' read a line and result in stdir string Wait1 LoopUntilEof(ff)<>0 Close #ff
Chdir"\"'change to the root directory
The result was 491625N031317ELONGPONT without any "
so I would like replace the file from my ATMEGA2560
I use :
Chdir"lalong" Print"kill lalong.txt" Kill"lalong.txt" l
Waitms100
Ff =Freefile() Open"lalong.txt"forOutputAs #ff
Write #ff , Sentence
Close #ff
Waitms100
Ff =Freefile() Open"lalong.txt"ForInputAs #ff
Print"stdir"; Stdir
the result is
"484754N021849EBAGNEUX"
So my question : It is possible to write a string without " " as VBA for excel does ?
Thanks for your help
Jp _________________ pleasure to learn, to teach, to create
Posted: Fri Jul 06, 2018 10:02 am Post subject: solved
Hi Mark
and thanks for your answers
During the night ....I add some line and now it's solved
IfLeft(stdir , 1)=Chr(34)Then'suppression du " si stdir vient du clavier Delchar Stdir , 1 End If IfRight(stdir , 1)=Chr(34)Then
Lenst =Len(stdir) Delchar Stdir , Lenst
like that if the file is write with VBA it is good, and if it is write from the AVRDOS it is good also
JP _________________ pleasure to learn, to teach, to create
