Using multiple LCDs
Paulvk
PostPosted: Mon Apr 30, 2018 10:40 am    Post subject: Using multiple LCDs Reply with quote
Normally with bascom you use only one lcd but sometimes its nice to have more than one
Here I will show how to use four or more by switching the chip select lines with an analog switch IC.
Below is a circuit diagram to show how its done I will post some code when I have finished testing
Paulvk
PostPosted: Sat May 12, 2018 5:30 am    Post subject: Reply with quote
Here are two LCDs displaying different information
this is data from my offgrid solar system
and code used to initialise the two LCDs
Regards Paul
 Glcd_cs1 Alias Portc.2
 Glcd_cs2 Alias Portc.3
   'select LCD two
            'Portd.7 = 0
          Reset Portd.7
            'Portd.6 = 1
          Set Portd.6
       'make both chip select 1
   Set Glcd_cs1
   Set Glcd_cs2
       'call initialise LCD from library
         !call _Init_lcd
       'make both chip select 0
   Reset Glcd_cs1
   Reset Glcd_cs2
     'select LCD one
             'Portd.7 = 0
            Reset Portd.7
            'Portd.6 = 0
             Reset Portd.6
   Set Glcd_cs1
   Set Glcd_cs2
         !call _Init_lcd
   Reset Glcd_cs1
   Reset Glcd_cs2
jure_m
PostPosted: Thu Jun 21, 2018 8:36 am    Post subject: Reply with quote
Hi Paul,
check if this is of any use for you.
I have used SPI because I wanted to drive LCD with 8-pin AVRs.
Best regards
Jure
Paulvk
PostPosted: Thu Jun 21, 2018 11:59 am    Post subject: Reply with quote
Hello jure
Yes we have two solutions for character LCDs SPI & I2C
These are graphic LCDs it would be great to have the same for them
they use almost two ports.
Regards Paul
