$regfile = "m328pdef.dat"
$hwstack = 64
$swstack = 32
$framesize = 128
'* LCD KEYPAD SHIELD DEMO *
'* RobotDyn Shield with resistive keypad *
'* Demo shows hardware configuration, and *
'* function for reading switches *
'* by BARTek *
Config Submode = New
'* ALPHANUMERIC LCD *
Config Lcdpin = Pin , Rs = Portb.0 , E = Portb.1 , Db4 = Portd.4 , Db5 = Portd.5 , Db6 = Portd.6 , Db7 = Portd.7
Config Lcd = 16x2
Cursor Off , Noblink : Cls
'* CONFIG ADC FOR SWITCHES *
'* TIMER2 FOR TIME BASE *
Config Timer2 = Timer , Prescale = 1024 , Compare_a = Disconnect , Clear_timer = 1
Compare2a = 155 '10ms @16MHz
'* VARIABLES *
Const Sw_r = 1
Const Sw_u = 2
Const Sw_d = 3
Const Sw_l = 4
Const Sw_s = 5
'switches
Dim Old_key As Byte , Key_cnt As Byte , Key As Byte
'demo
Dim Lr As Integer , Up_dn As Integer , Flipb As Byte
Function Read_keypad() As Byte
'function with autorepeat
Local Adc_read As Word , Read_key As Byte , Key_val As Byte
Adc_read = Getadc(0)
Select Case Adc_read
Case 0 To 100 : Read_key = Sw_r 'right = 0
Case 101 To 250 : Read_key = Sw_u 'up = 145
Case 251 To 400 : Read_key = Sw_d 'dwn = 330
Case 401 To 600 : Read_key = Sw_l 'left = 506
Case 601 To 850 : Read_key = Sw_s 'select = 743
Case Is > 851 : Read_key = 0 'no key = 1023
If Read_key <> 0 Then
If Old_key = Read_key Then
If Key_cnt < 20 Then
Incr Key_cnt
Key_val = 0
Key_cnt = 0
Key_val = Read_key
Key_cnt = 15
Key_val = 0
Old_key = Read_key
Read_keypad = Key_val
End Function
'for demo
Locate 1 , 1 : Lcd "UpDn=0"
Locate 2 , 6 : Lcd "< 0 >"
Locate 1 , 14 : Lcd "*"
If Tifr2.ocf2a = 1 Then '10ms
Tifr2.ocf2a = 1
Key = Read_keypad()
If Key <> 0 Then
Select Case Key
Case Sw_u
If Up_dn < 9 Then Incr Up_dn
Locate 1 , 6 : Lcd Up_dn ; " "
Case Sw_d
If Up_dn > -9 Then Decr Up_dn
Case Sw_r
If Lr < 9 Then Incr Lr
Locate 2 , 7 : If Lr >= 0 Then Lcd " " : Lcd Lr
Case Sw_l
If Lr > -9 Then Decr Lr
Case Sw_s
Locate 1 , 14
If Flipb = 0 Then
Lcd " *" : Flipb = 1
Lcd "* " : Flipb = 0
Key = 0
