This was sometime discussed but maybe I dont remember exact answear . Probably syntax was "!Call _initlcd" SO exclamation sign must precede the Call if you want to call some routine from library.
Thank you EDC
I remembered there was a discussion I searched but could not find it
Even closer now I just have to work out the calls to make
So far I have one and a half LCDs need to initialize he other half (chip)
I am using a 2 x 4 cmos switch to chose CS1 & CS2
Regards Paul
If they should show different content then I agree but if content is same on the both then I link them parallely and most of the "non serial" LCD`s works fine
I have it working two 64 x 128 LCDs
I could have four as its a 2 x 4 switch
I had to select CS1 & CS2 manually
Then initialize both chips at once
also need to put pull down resistors on CS1 & CS2 as the switch goes high Z when not selected.
regards Paul
Glcd_cs1 AliasPortc.2
Glcd_cs2 AliasPortc.3
'select port 1 on switch ResetPortd.7 SetPortd.6 Wait1 Set Glcd_cs1
Set Glcd_cs2
!call _Init_lcd
Reset Glcd_cs1
Reset Glcd_cs2
Wait1 'select port 0 on switch ResetPortd.7 ResetPortd.6 Wait1 Set Glcd_cs1
Set Glcd_cs2
!call _Init_lcd
Reset Glcd_cs1
Reset Glcd_cs2
