call functions from library
PostPosted: Mon Apr 16, 2018 11:01 am    Post subject: call functions from library Reply with quote
How do I call the functions in the KS108 libray
initialize the lcd
turn on the lcd
I am trying to run multiple lcds and almost have it working
Regards Paul
PostPosted: Mon Apr 16, 2018 1:47 pm    Post subject: Reply with quote
If you look in the LIB/LBX file you'll see labels like:-
_Init_display
_gwrite_cmd
_clear_graph:
_clear_text:
So maybe you could just set the required registers then jump to the label. I'm not sure if that'll work, but it's worth a try.
Ian Dobson
http://www.planet-ian.com
PostPosted: Mon Apr 16, 2018 6:38 pm    Post subject: Reply with quote
This was sometime discussed but maybe I dont remember exact answear . Probably syntax was "!Call _initlcd" SO exclamation sign must precede the Call if you want to call some routine from library.
[EDIT] Updated to the LINK to the discussion Wink
PostPosted: Tue Apr 17, 2018 10:29 am    Post subject: Reply with quote
Thank you EDC
I remembered there was a discussion I searched but could not find it
Even closer now I just have to work out the calls to make
So far I have one and a half LCDs need to initialize he other half (chip)
I am using a 2 x 4 cmos switch to chose CS1 & CS2
Regards Paul
PostPosted: Tue Apr 17, 2018 10:41 am    Post subject: Reply with quote
If they should show different content then I agree but if content is same on the both then I link them parallely and most of the "non serial" LCD`s works fine Very Happy
PostPosted: Tue Apr 17, 2018 10:47 am    Post subject: Reply with quote
I have it working two 64 x 128 LCDs
I could have four as its a 2 x 4 switch
I had to select CS1 & CS2 manually
Then initialize both chips at once
also need to put pull down resistors on CS1 & CS2 as the switch goes high Z when not selected.
regards Paul
 Glcd_cs1 Alias Portc.2
 Glcd_cs2 Alias Portc.3
        'select port 1 on switch
          Reset Portd.7
          Set Portd.6
   Set Glcd_cs1
   Set Glcd_cs2
         !call _Init_lcd
   Reset Glcd_cs1
   Reset Glcd_cs2
          'select port 0 on switch
            Reset Portd.7
             Reset Portd.6
   Set Glcd_cs1
   Set Glcd_cs2
         !call _Init_lcd
   Reset Glcd_cs1
   Reset Glcd_cs2
