Starting Bootloader from Application
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR
Alex20q90
PostPosted: Sat Mar 10, 2018 12:02 pm    Post subject: Starting Bootloader from Application Reply with quote
Hello,
i have a new problem! I use a ATMega8u2 mit LUFA Bootloader. In Bascom i can flash my Application with Bascom over the "FLIP"-Programmer directly via USB. It works.
If i would flash again, i need to pull down the /RESET-Pin to low to start the Bootloader.
A Try to call the bootloader-Adress from my App wont work.
Sample code:
$regfile = "M8u2def.dat"
$crystal = 8000000
Switch Alias Pinc.2                                         ' Tasterabfrage an diesem Port
waitms 200
 If Switch = 1 Then ' Call Bootloader if switch is pressing by power-on
  goto &h1000 ' goto &h800 also wont work **
do
' Here my Mainprogramm
loop
I cant call the Bootloader! Also i tried to force a uC-Reset with WatchDog.
**In the BASCOM-Prog is the Bootloader at $800 (Fusebit High KL 00:Bootsize 2048 words at $800) but the Bootloader starts at &H1000.
FBH: 1: Reset vector is $0000
FBExt: 0:Hardwareboot enabled.
I Also tried Reset vector is bootloader
Hardwareboot disabled
(BASCOM-AVR version : 2.0.8.1 )
PostPosted: Sat Mar 10, 2018 1:31 pm    Post subject: Re: Starting Bootloader from Application Reply with quote
That was to expect.
I thought about helping you through, but considering your previous thread, your low discussion ability and low esteem about other discussion partners as devote helpsters, I do not think I would enjoy it much.
Also I regularly find it arrogant if persons formerly seeking help just leave after their question was answered, while giving a damn about others getting stuck by trying to find out the final result of a thread. You seem to be such a self-centered candidate.
Ok, ranted that, now just a hint:
LUFA Bootloader
That's the suggested process by the LUFA library for AVR.
It surly works, if not for you then because you did it wrong.
Evert :-)
PostPosted: Sat Mar 10, 2018 3:59 pm    Post subject: Reply with quote
Goto &Hxxx should work,
However &H1000 is not a valid Bootloader address, what is valid depends on how big your bootloader loader is, have a look at the datasheet page 239.
Alex20q90
PostPosted: Sat Mar 10, 2018 6:05 pm    Post subject: Re: Starting Bootloader from Application Reply with quote
Evert Smile wrote:
Thanks Evert!
I read it in the past and i tried this to start my bootloader with this adress, after it did not work i look onto the programmers buffer who looks like it starts by $1000. Maybe i give up to early with $800.
EDIT: i tried the adress $800 (&h0800) but i cant call the bootloader.
Also tried with restart by Watchdog!
Now i see in the documentation of LUFA
http://www.fourwalledcubicle.com/files/LUFA/Doc/120219/html/_page__software_bootloader_start.html
that it use a "Magic_Key".
In my case it is in the Bootloadeer with
#define MAGIC_BOOT_KEY           0xDC42
and in the App i have to start with (example)
  void Jump_To_Bootloader(void)
      // If USB is used, detach from the bus and reset it
      USB_Disable();
      // Disable all interrupts
      cli();
      // Wait two seconds for the USB detachment to register on the host
      Delay_MS(2000);
      // Set the bootloader key to the magic value and force a reset
      Boot_Key = MAGIC_BOOT_KEY;
      wdt_enable(WDTO_250MS);
      for (;;);
But the Magic_key have to written in the Memory! But i cant find the place of adress where its have to been written!
MWS wrote:
That was to expect.
d'oh!
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR All times are GMT + 1 Hour
