Timer0 problem on ATtiny 1634
gertc
PostPosted: Thu Feb 15, 2018 12:46 am    Post subject: Timer0 problem on ATtiny 1634 Reply with quote
Hello again,
I realy have problem with the 1634.
I have being using the ATtiny167 without any problem, but I need two additional ports so I am switching to the ATtiny1634
The program does not jump to "Frequency_ab" on Timer0 Interrupts
$regfile = "attiny1634.dat"
$hwstack = 32
$swstack = 10
$framesize = 40
Config Portb.3 = Output                 'PWM Using Timer1
Config Porta.0 = Output                 '150Hz to 500Hz Square Wave
Dim Pu As Word
'COM PORT
'Open "comb.0:9600,8,n,1" For Output As #1
Config Timer0 = Timer , Prescale = 1
On Timer0 Frequency_ab
Enable Timer0
Start Timer0
Config Timer1 = Pwm , Pwm = 10 , Compare_a_pwm = Clear_up , Prescale = 1
   Waitms 1000
   Pwm1a = 512                          '50% ~4Khz PWM on PORTB.3  (OC1A)
Frequency_ab:
   Pu = Pu + 1
   'Print #1 , "Pu: " ; Pu
   If Pu => 62 Then                     '62=500Hz  206=150Hz
      Pu = 0
   Elseif Pu >= 31 Then                 '31=500Hz  103=150Hz
      Porta.0 = 1
   Elseif Pu >= 0 Then
      Porta.0 = 0
Excatly the same program (Except using different ports) it works fine with ATtiny167
$regfile = "attiny167.dat"
$hwstack = 32
$swstack = 10
$framesize = 40
Config Portb.0 = Output                 'PWM Using Timer1
Config Porta.2 = Output                 '150Hz to 500Hz Square Wave
Dim Pu As Word
'COM PORT
'Open "coma.0:9600,8,n,1" For Output As #1
Enable Timer0
Start Timer0
   Waitms 1000
   Pwm1a = 512                          '50% ~4Khz PWM on PORTB.0  (OC1AU)
Frequency_ab:
   Pu = Pu + 1
   If Pu => 206 Then                    '62=500Hz  206=150Hz
      Pu = 0
   Elseif Pu >= 103 Then                '31=500Hz  103=150Hz
      Porta.2 = 1
   Elseif Pu >= 0 Then
      Porta.2 = 0
The only different I can see is that all the Timer0 instructions for the ATtiny 1634 are in lover case and black. Timer1 instructions Upper case and red.
For the Attiny167 both Timer0 and Timer1 instructions are both Upper case and red.
Config TIMER0 = Timer , Prescale = 1
On TIMER0 Frequency_ab
I don't know if that means anything?
Thanks,
gerrysc
PostPosted: Thu Feb 15, 2018 10:13 am    Post subject: Reply with quote
this is a bug in the START statement. it does not know the T1634 and enables the wrong register.
Instead write TCCR0B=1 for this chip and it should work.
gertc
PostPosted: Thu Feb 15, 2018 7:01 pm    Post subject: Reply with quote
Thanks,
It works. I wounder why the T167 is giving me a 500Hz square wave and the T1634 only a 314Hz square wave? Both are using 8Mhz internal clock
Here is how I am using the Tccr0b. Not quite sure if it is correct.
 ' Config Timer0 = Timer , Prescale = 1
Enable Timer0
Start Timer0
Tccr0b = 1
gerrysc
