No PWM output on OC1B
gertc
PostPosted: Wed Feb 07, 2018 11:52 pm    Post subject: No PWM output on OC1B Reply with quote
I am making an Digital to Analog conversion using PWM. Using OC1B I have no problem, but if I use OC1A I am not getting any PWM output.
Now back to the basic, using the code from the help file. Still the same problem
Am I missing something, or are there a bug in the compiler when using the ATtiny1634?
Here is 4 small test programs I tryed out:
Bascom Ver. 2.0.8.0
$regfile = "attiny1634.dat"
$hwstack = 32
$swstack = 10
$framesize = 40
Config Portb.3 = Output                 'OC1A pin 18  (ATtiny1634 SOIC)
Config Porta.6 = Output                 'OC1B pin 3   (ATtiny1634 SOIC)
' -- TEST 1 --
Config Timer1 = Pwm , Pwm = 10 , Compare_a_pwm = Clear_up , Compare_b_pwm = Clear_down , Prescale = 1
Enable Timer1
Start Timer1
   Waitms 1000
   Pwm1a = 800                          '4Khz on PORTB.3  (OC1A)
   Pwm1b = 800                          'Output High on PORTA.6 (OC1B)
' -- TEST 2 --
Config Timer1 = Pwm , Pwm = 10 , Compare_b_pwm = Clear_up , Prescale = 1
Enable Timer1
Start Timer1
   Waitms 1000
   Pwm1b = 800                          'Output Low on PORTA.6 (OC1B)
' -- TEST 3 --
Config Timer1 = Pwm , Pwm = 10 , Compare_b_pwm = Clear_down , Prescale = 1
Enable Timer1
Start Timer1
   Waitms 1000
' -- TEST 4 --
Config Timer1 = Pwm , Pwm = 10 , Compare_a_pwm = Clear_up , Prescale = 1
Enable Timer1
Start Timer1
   Waitms 1000
   Toggle Porta.6                       'PORTA.6 Toggling HI/LOW << PORT IS WORKING AS NORMALLY OUTPUT
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.8.1 )
PostPosted: Thu Feb 08, 2018 5:08 am    Post subject: Re: No PWM output on OC1B Reply with quote
Comments in your code tell the contrary, there OC1A is described to put out 4kHz. What is correct?
If you want to check whether registers are set correctly, simply print TCCR1A and TCCR1B to console and compare with the data sheet.
Alternatively run the simulator, write down these register values from the register overview, or do a print to the console and compare.
Why do you enable the timer interrupt without ISR btw.? Makes no sense. At least you don't enable interrupts generally, so it has no effect.
gertc
PostPosted: Thu Feb 08, 2018 11:05 pm    Post subject: Reply with quote
Hello MWS,
Thank you for your reply.
The text should have said: "Using OC1A I have no problem, but if I use OC1B I am not getting any PWM output."
When I run the program in the simmulator I get: TCCR1A = B3, and TCCR1B = 01
IF I change Compare_b_pwm to Clear_up then TCCR1A = A3, and TCCR1B = 01
Why does TCCR1A change, and not TCCR1B?
I looked at the data sheet, and to be honest, I am not quite shure what is going on
The code now looks as this:
$sim
$hwstack = 32
$swstack = 10
$framesize = 40
   Waitms 1000
   Pwm1a = 700                          '4Khz on PORTB.3  (OC1A)
   Pwm1b = 400                          'Output High on PORTA.6 (OC1B)
laborratte
PostPosted: Thu Feb 08, 2018 11:54 pm    Post subject: Reply with quote
as far I can see there is a bug in attiny1634.dat file (Version 2.0.8.0): the [WIO] - definition of OCR1B is not correct (should be $6a, not $2e), in [IOEXT] OCR1BL and OCR1BH is missing.
Please contact support and ask for a fix.
Don't get control register and compare register wrong. the behavior of pwm pins is defined in TCCR1A only.
gertc
PostPosted: Fri Feb 09, 2018 12:15 am    Post subject: Reply with quote
Thanks,
Maybe not only the ATtiny1634. I tryed the same with an ATtiny4313, where also only OC1A works
Anyway, I will contact support as suggested.
Regards,
gerrysc
Printpix52
PostPosted: Fri Feb 09, 2018 12:46 am    Post subject: Reply with quote
Good I did a test for atmega16 are you correct or not? Shocked
$regfile = "m16adef.dat"
$hwstack = 40
$swstack = 16
$framesize = 32
'OC1A Pin 19
Config Portd.5 = Output
'OC1B pin 18
Config Portd.4 = Output
Config Timer1 = Pwm , Prescale = 1 , Pwm = 10 , Compare_a_pwm = Clear_up , Compare_b_pwm = Clear_up
'08 bit
Tccr1a.5 = 1 : Tccr1a.5 = 0 : Tccr1b.4 = 0 : Tccr1b.4 = 0
   Waitms 1000
   Pwm1a = 700
   Pwm1b = 400
   Toggle Portd.4
PostPosted: Mon Feb 12, 2018 12:48 pm    Post subject: Reply with quote
the 1634def. dat is derived from the atmel tn1634 file :
.equ OCR1BL = 0x2e
.equ OCR1BH = 0x2e
but.. the datasheet shows indeed a different address.
I think Tomi corrected this for 2081. And i checked the 2081 files and that is indeed the case.
I think we better derive from the atdf files in the future.
Notice that 1634 and 4313 are entirely different chips.
Mark Alberts
MCS Electronics
http://www.mcselec.com
gertc
PostPosted: Tue Feb 13, 2018 11:13 pm    Post subject: Reply with quote
I installed ver. 2081, and everything works fine.
Sorry I didn't do that earlier.
Thanks for all the help.
gerrysc
