Mrshilov
Posted: Tue Apr 26, 2016 7:00 am Post subject: SSD1331 OLED RGB 0.95' display library |
Display with resolution 96x64, controller SSD1331, power 3.3V. SPI connection on this model:
In GEARBEST shop it cost $10. http://www.gearbest.com/lcd-led-display-module/pp_235707.html
Color balance may be adjusted, brightness operates with Lcdcontrast command.
It has hardware drawing lines and boxes. And it makes it very quick - look at video https://youtu.be/POjIicuz4lo
Posted: Tue Apr 26, 2016 8:39 am Post subject: |
Hello Mrshilov,
Just enjoyed the video
Thank you for sharing your work of this neat LCD driver.
As always a complete a great job, with lib, sample, PDF included.
Time to order the display _________________ Mark |
micha_b
Posted: Sun Jan 08, 2017 7:01 pm Post subject: |
Hi Mrshilov,
thank you for the code.
In my configuration the demofile works until the circle command is sent, from this point the
display does not respond anymore and needs a reset.
Text also doesn't work.
Rectangles and lines work perfect.
So as far as I understand, as long as you adress the build in Graficfunctions it works, additional commands doesn't.
I'm working with ATMEGA128, configuration is
Config Graphlcd = Color , Si = Portb.2 , Sclk = Portb.1 , A0 = Portc.6 , Cs1 = Portb.5 , Rst = PortB.4
$crystal = 14745600
Do you have an idea what is wrong?
Thank you very much again, this is the only bascom source code I found on the web for this amazing
display, and I don't want to switch to another programming language like arduino since bascom is much better.
Best,
Michael |
petros047
Posted: Wed Jan 31, 2018 9:27 am Post subject: |
I have buy this lcd but before I connect it I would like to know if you use 5v 3.3 shifter.
My board said that accept voltage from 3.3 to 5v but i would like to know how you guys have connected this lcd.
Also the dc pin is connected to ground? |
Mrshilov
Posted: Wed Jan 31, 2018 10:07 am Post subject: |
D/C pin named as "A0" in "Config Graphlcd".
CS is optional and may be connected to GND. RES also optional and may be connected to Vdd.
Vdd for SSD1331 is from 2.4V to 3.5V (see datasheet). |
