Posted: Sun Dec 24, 2017 2:40 pm Post subject: BASCOM-AVR 2081 |
With pleasure we announce the 2081 version of BASCOM-AVR
The most important changes since 2080:
- CONTINUE statement added
- REDO statement added
- NOP is now also a BASCOM BASIC statement
- The editor supports jump to implementation : hold CTRL key and hover the mouse over an identifier. When it becomes underlined and blue you can click it with the left mouse key.
Use CTRL+BACKSPACE to jump back
- when defining a constant named Updateeprom , the eeprom will be updated. which means that the value will only be written when it differs
- config timer1 for tiny 25/45/85 set the wrong register bits.
- the watchdog is disabled as part of the init procedure. it is now disabled BEFORE the optional call to init_micro and not after as in 2079.
- passing string constants with embedded {034} resulted in an extra (unwanted) space.
- accessing passed string array in sub without length info, but with constant index failed.
- crcmb funtion added to help. (checksum for modbus)
- for xmega i2cstop you can define a constant named _TWI_STOP_1 or _TWI_STOP_2 to change the behavior.
- makemodbus() function 1, 2 and 4 added to modbus.lib
- support for xmega added to getrc
- PDF download now also checks/download the BASCOM-AVR manual
- PRINTBIN did not accept a constant for the optional channel : printbin #someconst. Fixed.
- update from within the application simplified. see help.
- printbin raised error while printing multiple variables
- simulator did not show proper hex value for single variables.
- fusing which uses ftoa uses a table which could be loaded on a page boundary. this could lead to rampz problems. fixed.
- crc8UNI added for normal crc8 CCITT
- config clock additional option : highESR=1 to enable high ESR mode in xmega with 32 bit RTC
- FM24C64_256-XMEGA.lib added for xmega. read the lib notes.
- tcpip-w5500.lbx has been updated to support usage from boot space. See $loader
- stk500 board. osc can be set from menu
- using spimove() inside a sub with a parameter for the count, would load the wrong data.
- i2cwbyte would raise an error if a multi dim array was used.
- get/put/seek in AVR-DOS used in combination with $bigstrings would fail for numeric data
- xmega i2cstop has two new optional mode. See help.
- CONFIG SPI has a new option : EXTENDED=1 to have extended data size reading/writing.
- support for rgbW leds added (ws2812 with extra white led)
- CONFIG USI has a new option ALTPIN to support optional pins.
- xmega dat file fuse tables corrected.
This version can ONLY be downloaded from register.mcselec.com as a FULL SETUP.
Please read the (on line) help topic 'move to new pc'
This new version has a new integrated update function which will also download/run the full setup when available
The update wiz is not used anymore for new updates.
If you have a problem, write to support.
The help contains a 'what is new in 2081' topic for quick access to the changes in the help
(BASCOM-AVR version : 2.0.8.1 ) _________________ Mark |
JC
Joined: 15 Dec 2007 Posts: 586 Location: Cleveland, OH
Posted: Sun Dec 24, 2017 5:17 pm Post subject: |
Happy Holidays, Mark!
Thank you for the upgrade!
It obviously reflects a lot of work on your part, and it is well appreciated!
JC |
tiket
Posted: Sun Dec 24, 2017 6:28 pm Post subject: |
Merry Christmas.
Thank you for your gifts |
dabatek
Posted: Sun Dec 24, 2017 8:41 pm Post subject: |
Merry Christmas !
Thank you again, for nice work. |
Pikczu
Joined: 22 Jan 2006 Posts: 72 Location: Dublin, Ireland
Posted: Sun Dec 24, 2017 10:17 pm Post subject: |
Thank you for the update.
Looks like this become a tradition for Christmas.
Merry Christmas and Happy new Year ! |
Ev3658
Posted: Mon Dec 25, 2017 3:32 pm Post subject: |
Thank You
crcmb funtion - Thank You ! Thank You! Thank You! |
richhbd
Posted: Tue Dec 26, 2017 4:30 pm Post subject: |
Thanks Marc, what a great excuse to escape the family for a bit!
Big thank you for fixing Printbin #someconst. that is going to result in some code neatening very soon. |
andro
Posted: Tue Dec 26, 2017 9:57 pm Post subject: |
Many thanks for all You effort!
well appreciated!
all the best in New Year!
Andrej |
Posted: Wed Dec 27, 2017 10:23 am Post subject: |
you are welcome. glad that our efforts are appreciated. indeed it was a lot of work. it is not always visible.
talking about for code neating : check out the new continue and redo statements. _________________ Mark |
Posted: Wed Dec 27, 2017 10:52 am Post subject: |
many thanks Mark
A gift as a new version : it's a great idea !
have a nice happy new year !
jp |
mmarlette
Posted: Wed Dec 27, 2017 4:18 pm Post subject: |
Mark,
You always seem to be able to improve on what I call a perfect product!
GREAT work and I thank you as well with many others!!!
Merry Christmas and Happy New Year!!!!
Look forward to trying out the new commands.
I see the SPI EXTENDED.....ahh see a use already!
Regards,
Mark |
Plons
Joined: 24 May 2005 Posts: 435 Location: Hilversum - The Netherlands
Posted: Thu Dec 28, 2017 12:52 pm Post subject: |
Thanks Mark, for the continuous support of Bascom.
Best wishes for 2018 for all ! _________________ Bascom AVR ver 2.0.8.6
Dragon-lair: http://www.aplomb.nl/TechStuff/Dragon/Dragon.html
"leef met vlag en wimpel, maar hou het simpel" |
AndersL
Joined: 25 Jan 2010 Posts: 92 Location: Kragerø,Norway
Posted: Thu Jan 04, 2018 12:14 pm Post subject: |
Thanks a lot Mark, you’re the best!
A happy and prosper new year to you and all Bascomers _________________ Anders |
