krolikbest
Posted: Fri Nov 17, 2017 1:04 pm Post subject: Modbus slave number |
I would like to send some modbus frame from advantech panel to ATMega8 in modbus, rs 485. Panel is a master, avr is a slave. First problem i encountered is that i don't know how to set up a slave number for avr? Let say, on a panel i have a button and by pressing it i would like to send a some number, i.e "1" to avr. On a panel i've configured already connection chanel and slave number should be = "11". So how to do it on ATMega8 side?
Thank you,
Martin
[b][color=red](BASCOM-AVR version : 2.0.7.6 , Latest : 2.0.7.8 )[/b][/color] |
Posted: Sat Nov 18, 2017 9:04 am Post subject: |
The modbus data packet is just an Array of Bytes.
In the main Loop I have
If Modbus_have_data > 0 Then 'Have we got a modbus packet
Call Modbus_task() 'Handle Modbus packet
Modbus_have_data = 0 'Clear flag
End if
Note Modbus_have_data is set to 1 (By a timer interrupt) when data arrives at the Serial port then nothing for a short day (approx 1ms)
Sub Modbus_task()
'Function : Check modbus packets calling the correct decoder (read/write) .
'Author : Ian Dobson
'Inputs : None
'Outputs : None
'Limitations : :
'Date : 13.2.2016
If Modbus_buffer(1) = _modbus_slave_address Then 'Slave address correct
Modbus_temp1 = Modbus_have_data - 2 'Low Byte
Modbus_temp2 = Modbus_have_data - 1 'High Byte
Modbus_checksum_serial = Makeint(modbus_buffer(modbus_temp1) , Modbus_buffer(modbus_temp2))
Modbus_temp1 = Modbus_have_data - 3
Modbus_checksum_user = Crcmb(modbus_buffer(1) , Modbus_temp1 ) 'checksum from data
If Modbus_checksum_user = Modbus_checksum_serial Then 'checksum OK?
Call Debug_modbus(modbus_have_data -1 , "I")
Register_start = Makeint(modbus_buffer(4) , Modbus_buffer(3)) 'get start register
Incr Register_start
Modbus_register_count = Makeint(modbus_buffer(6) , Modbus_buffer(5)) 'get register count
Select Case Modbus_buffer(2)
Case Is = 3 'Read Holding Registers
Call Modbus_fc3()
Case Is = 16 'Preset Multiple Registers
Call Modbus_fc16()
If Modbus_watchdog_counter < 3 Then 'no comms for ca 3 seconds
Toggle Led_status
krolikbest
Posted: Sat Nov 18, 2017 6:55 pm Post subject: |
Thank you for an idea hot to respond when modbus frame arrives. I was a little way-out in this subject because i thought that slave number should be written somewhere... Now i understand. |
Posted: Sat Nov 18, 2017 7:03 pm Post subject: |
Here are my comments for my modbus slave. Note the slave address is the first Byte in the Array.
'The following functions are supported
'FC3 read multiple registers
'FC16 write mutliple registers
'Master to slave data packet- read registers
'11 - Slave Address
'03 - Function code
'006B - The Data Address of the first register requested
'0003 - The total number of registers requested
'7687 - Checksum
'Response
'11 - Slave Address
'03 - Function code
'06 - The number of data bytes to follow
'AE41 - Value of register 1
'5652 - Value of register 2
'4340 - Value of register 3
'49AD - Checksum
'Master to slave data packet- write register
'11 - Slave Address
'06 - Function code
'006B - The Data Address of the register
'0003 - The value to write
'7687 - Checksum
'Response
'11 - Slave Address
'06 - Function code
'0003 - The value to written
'7687 - Checksum
krolikbest
Posted: Sat Nov 25, 2017 7:32 pm Post subject: |
Finally i've done. Now i know how to set an address of device (AVR as a slave) an the rest is to take apart the frame. Piece of cake
Thank you.
Thread to close. |
krolikbest
Posted: Tue Nov 28, 2017 9:15 pm Post subject: |
When do you reset is_request?
Maybe try
if is_request=1 then
is_request=0
Printbin A(1);8 'A is an array of bytes. Array is Ok (with modbus crc) i've checked in rs485 sniffer
end if
krolikbest
Posted: Tue Nov 28, 2017 10:42 pm Post subject: |
is_request is reset in URxC after receiving all bytes of the master's frame, but i've also tested your solution. Eventually came for an idea to switch off communication error in panel master (Advantech product). So now on the lcd of atmega8 i have what i want and on panel's side there is no communication errors but all buttons, edits, etc are functioning. I will do short movie on youtube tomorrow.
Regards,
Martin |
krolikbest
Posted: Thu Nov 30, 2017 7:12 pm Post subject: |
modbus works in there the master sends a packet to a slave and the slave answers with a packet. The slave should only "talk" when they're spoken too by the master.
With your solution I have the Feeling that the slave (your Atmel) is just sending packets to the master even with being asked to. Adding that short delay (20ms) gives the master/other slaves time to communicate.
krolikbest
Posted: Thu Nov 30, 2017 7:37 pm Post subject: |
right, 20ms is time to work for other devices. even i gave later ~100ms and it is sill working well. In this little example are working 3 slave devices + panel master.
Regrads,
Martin |
