very strange problem with PWM
mastermindjp
PostPosted: Mon Sep 11, 2017 9:29 am    Post subject: very strange problem with PWM Reply with quote
Hello friends
I am facing a very strange problem with the PWM in BASCOM 2.0.8.0, i am not giving any command to PWM still its by default both the PWM's are high (ATMEGA32A)
$hwstack = 32
$regfile = "m32def.dat"
$swstack = 10
$framesize = 40
'$sim
Config Timer1 = Pwm , Pwm = 10 , Compare A Pwm = Clear Down , Prescale = 1024
Config Lcdpin = Pin , Db7 = Portc.2 , Db6 = Portc.3 , Db5 = Portc.4 , Db4 = Portc.5 , E = Portc.6 , Rs = Portc.7
Config Lcd = 20 * 4
Cursor Off Noblink
what should be the problem here??
Aniruddha
(BASCOM-AVR version : 2.0.8.0 , Latest : 2.0.7.8 )
We are not innovating, we are just manipulating innovations done by Mother Nature.......
PostPosted: Mon Sep 11, 2017 9:35 am    Post subject: Reply with quote
try to remark this : Config Timer1 = Pwm , Pwm = 10 , Compare A Pwm = Clear Down , Prescale = 1024
mastermindjp
PostPosted: Mon Sep 11, 2017 9:44 am    Post subject: Reply with quote
hello Mark Sir,
you mean to say command out the like this:
$hwstack = 32
$regfile = "m32adef.dat"
$swstack = 10
$framesize = 40
'$sim
'Config Timer1 = Pwm , Pwm = 10 , Compare A Pwm = Clear Up , Prescale = 1024
Config Lcd = 20 * 4
Cursor Off Noblink
i did this, result is pwm's are low.
Aniruddha
PostPosted: Mon Sep 11, 2017 9:55 am    Post subject: Reply with quote
first of all, always leave out unrelated code like lcd in the sample.
second, describe better what your problem is. you say 'both pwm' but what is that? pwm0, pwm1 or pwm2 and a,b,c ?
Also, tell what you expect.
the config timer1 will setup the timer for pwm and set the pwm port A to output. the level can not be changed after that.
mastermindjp
PostPosted: Mon Sep 11, 2017 10:08 am    Post subject: Reply with quote
ok, will keep the suggestions in mind.
Problem is if i write code like this:
$hwstack = 32
$swstack = 10
$framesize = 40
'$sim
and compile and burn it in the controller, i am getting PWM1A as high, which should not happen. earlier in the demo version i was using, same code worked fine.
why is it so??
Aniruddha
PostPosted: Mon Sep 11, 2017 10:24 am    Post subject: Reply with quote
when a problem is fixed in the demo, it can lead to this.
i see nothing wrong with the code : portd.5 is set to output.
no other ports are altered. and you specified pwn1a which is portd.5
if you do not want output you should use : COMPARE_A_PWM_NO_OUTPUT instead of COMPARE_A_PWM
PostPosted: Mon Sep 11, 2017 2:36 pm    Post subject: Reply with quote
With Clear_down your pin will be OFF/LOW with PWM=1023
If pin should be OFF/LOW with PWM=0 then configure it as Clear_up
It is your intention that frequency is so low? Maybe it is for some heater but look at the calculations.
$hwstack = 32
$swstack = 10
$framesize = 40
'                                                       > UP <
'16000000Hz/Prescale 1024 = 15625Hz
'15625Hz/1024(10Bit PWM) = 15,25Hz
Pwm1a = 0                                                   'LED_ON
  Wait 2
Pwm1a = 1023                                                'LED_OFF
Pwm1a = 512                                                 'LED_BLINK
mastermindjp
PostPosted: Tue Sep 12, 2017 12:19 pm    Post subject: Reply with quote
Hello Mark Sir,
I got it, in demo it was working in reverse way, like if i set PWM1A = 0 the input for MOSFET connected to PORTD.5 is low, but if i set PWM1A = 1023 then input is high.
in this version its working like this:
$hwstack = 32
$swstack = 10
$framesize = 40
'$sim
Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Down , Prescale = 1024
Pwm1a = 100                                                 'out put to MOSFET connected at PORTD.5 is high
Pwm1a = 1023                                                'out put to PortD.5 is low
Wait 5
'Pwm1a = 512
'Wait 1
'Pwm1a = 0
'Wait 1
Aniruddha
PostPosted: Wed Sep 13, 2017 12:23 am    Post subject: Reply with quote
Hmmm. 1023 in the code for 8bit PWM gives me a feeling you not understand "the clue" Very Happy
8BitPwm (Pwm= Cool means that timer will work/count from 0 to 255
9BitPwm (Pwm=9) means that timer will work/count from 0 to 512
10BitPwm (Pwm=10) means that timer will work/count from 0 to 1023
Prescale in the config in the simplest words will divide processor frequency.
...but PWM resolution do it too because timer must count into 1024 in the max resolution.
....... but you cannot use value 1024 for PWM=8 because it can hold/count up to 255.
Write value 1023 into 8Bit counter is not considered by processor the way you think Very Happy
mastermindjp
PostPosted: Wed Sep 13, 2017 9:09 am    Post subject: Reply with quote
Hello EDC,
Thank you for the valuable guidance, literally i was not aware of the fact. Its good to have people like you around.
Thank you
Aniruddha
