bytematch change in running programm
kempol
PostPosted: Sat Jul 15, 2017 8:39 am    Post subject: bytematch change in running programm Reply with quote
Is there a chance to change bytematch in running code?
By change I mean something like this:
Select Case A
Case 0
   Config Serialin1 = Buffered , Size = 202 , Bytematch = All
Case 1
   Config Serialin1 = Buffered , Size = 202 , Bytematch = 10       '10 = Lf, 13 = Cr
Of course above example will not work, but I'm wondering if it is possible to do something similar.
I have a project with different type of data (binary and ascii) and I would like to receive them on the same port which I can configure by simple DIP switch.
Thanks.[/quote]
(BASCOM-AVR version : 2.0.7.8 , Latest : 2.0.7.8 )
PostPosted: Sat Jul 15, 2017 8:38 pm    Post subject: Reply with quote
it will not work because of this code in mcs.lib
* Cpi r25,_CHECHCHAR0_char ;check with char to compare
but you could change it and put [_GOTCHAR0] in a custom lib with code like:
*lds r16,{YOURBYTE}
* CP r25, R16 ;check with char to compare
then you need to dim YOURBYTE as a byte and assign it a value of your choice.
We could integrate it as a new option in the compiler but you need to discuss that at support.
Mark Alberts
MCS Electronics
http://www.mcselec.com
PostPosted: Mon Jul 17, 2017 8:20 am    Post subject: Reply with quote
Of course you can do this in the library function, as Mark suggests.
But you can just as easily do it in running code, rather than in the config. And this gives you a lot more flexibility to handle all sorts of characters in the incoming stream.
while ischarwaiting() = 1 'character in buffer
bt = inkey()  'get the character as a byte
select case A 'your selection from external switch
 case 0
'... do whatever you want with bt as binary
case 1
'... do the alternate as ascii
 select case bt 'get the value
 case 10  'pick out the LF
' ... do whatever you want with the LF
 case ... anything else you want to handle specially, just create another case for it
 case else 'all other characters
'... put them in string, or whatever
 end select
end select
end while
Bascom is plenty fast enough to handle all sorts of constructions like this, and process characters one by one as they come in, especially when using buffered serial input.
If you do a search on the forum for "NMEA" you will find several examples using this to decode NMEA strings passed from GPS units. But the technique can be applied to almost anything.
Adrian Jansen
laborratte
PostPosted: Mon Jul 17, 2017 1:28 pm    Post subject: Reply with quote
Third option: use BYTEMATCH = ALL and check the received byte in your sub:
dim MyMatch as byte
MyMatch = 10 'or what you want
Serial1ByteReceived:
'r25 holds the received byte (Bascom Version 2.0.8.0, check mcs.lib if any doubt)
'r16 can be used as the content is no longer necessary
$asm
   lds r16,{MyMatch} 'load variable MyMatch to Register R16
   cp r25,r16           'Compare received Byte with MyMatch
   breq Serial1ByteReceived_Matched  'If equal, jump to "Serial1ByteReceived_Matched"
   ret 'Fast back to buffered serial in
$end asm
Serial1ByteReceived_Matched:
  pushall
  (...) 'your code
  popall
return
So you have fast buffered serial in and you do not need to write your own lib.
