allsetgo
Posted: Tue May 30, 2017 4:59 pm Post subject: UART Communication between two ATMEGA164P |
Hello Everyone
Attached is my Hardware Schematic.
I am trying to send data from MICRO2 to MICRO1
I have FT232 for USB communication on both MICRO's UART1
I have connected the RX0 of MICRO2 to TX0 of MICRO1 & TX0 of MICRO2 to RX0 of MICRO1
MICRO 2 code
Code: | $regfile = "M164pdef.dat"
$crystal = 14745600
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 57600
Config Serialin = Buffered , Size = 8
Print 2
Waitms 50
Loop |
MICRO 1 Code
$crystal = 14745600
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 57600
Config Com1 = 57600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Com2 = 57600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Open "COM1:" For Binary As #1
Open "COM2:" For Binary As #2
Dim A As Byte
A = Ischarwaiting()
Print #2 , A
The output is always 0.
I also tried the INPUT command but nothing worked.
Thank you for the help
(BASCOM-AVR version : 2.0.7.5 , Latest : 2.0.7.8 ) |
Posted: Tue May 30, 2017 6:12 pm Post subject: |
For buffered Serialin you must Enable Interrupts in MICRO 1 Code |
allsetgo
Posted: Tue May 30, 2017 7:20 pm Post subject: |
Thank you sooo much. I am glad I asked. I would had tried everything else in the world. |
allsetgo
Posted: Tue May 30, 2017 7:24 pm Post subject: |
One more question
How can I read a Single Data type over UART.
e.g.
Speed = 11.85
Print Speed
How should I read it on other MICRO
I tried INPUT command |
Visovian
Posted: Wed May 31, 2017 6:41 am Post subject: |
Code: | Dim S As Single
Dim B As Byte
B = Ischarwaiting(#1)
If B = 1 Then
Input #1 , S
Print #2 , "number = " ; S
Loop |
allsetgo
Posted: Wed May 31, 2017 3:21 pm Post subject: |
Thank you for the reply.
I tried the exact same code. The output is always 0.0
number = 0.0
Any other recommendation |
allsetgo
Posted: Wed May 31, 2017 3:46 pm Post subject: |
here is the code for MICRO2
$crystal = 14745600
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 57600
Config Serialout = Buffered , Size = 8
Dim Speed_avg As Single
Speed_avg = 5.0
Print Speed_avg
Waitms 10
Loop |
Here is the receiver code MICRO 1
$crystal = 14745600
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 57600
Config Serialin = Buffered , Size = 20
Config Serialin1 = Buffered , Size = 20
Dim Speed As Single
Dim A As Byte
A = Ischarwaiting(#1)
If A = 1 Then
Input #1 , Speed
Print #2 , "number = " ; Speed
Loop |
OUTPUT is number = 0.0 |
Visovian
Posted: Thu Jun 01, 2017 7:41 am Post subject: |
Then search for the fault in hardware. |
Posted: Thu Jun 01, 2017 11:17 am Post subject: |
Hw can't work this way.
U6 R2OUT is connected to Micro1 TXD and Micro2 RXD.
When Micro1 tries to send something over the TXD line U6 is still pulling on it with the result that that voltage level on the line will not change.
So Micro1 can't send because of this. You can verify it with a scope or simple remove U6 to see if it works. _________________ www.evertdekker.com Bascom code vault |
allsetgo
Posted: Mon Jun 05, 2017 2:58 pm Post subject: |
Thank you for the suggestions.
The HW works fine even with MAX232 IC mounted. I also removed it and tried
The INPUT command works fine with string data type.
Inputbin and InputHex commands work fine.
Single char transfer works fine too
It's sending and receiving Single/Integer data type is not working with INPUT command |
