Porelo
Posted: Fri May 19, 2017 8:38 pm Post subject: Help me to understand what is wrong |
I want to write and read the data in an external eeprom 95640, but I'm having some problems. I need help to understand what's wrong the code is :
$regfile = "m128def.dat" ' specify the used micro
$crystal = 14745500 ' used crystal frequency
$baud = 38400 ' use baud rate
$hwstack = 100 ' default use 32 for the hardware stack
$swstack = 100 ' default use 10 for the SW stack
$framesize = 40
'DEFENIÇÃO DO LCD
Config Graphlcd = 240 * 128 , Dataport = Porta , Controlport = Portc , Ce = 2 , Cd = 3 , Wr = 0 , Rd = 1 , Reset = 4 , Fs = 5 , Mode = 6
'DEFENIÇÃO DO SPI
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = yes , Polarity = Low , Phase = 0 , Clockrate = 128 , Noss = 1 , Spiin = 1
Spiinit
Declare Function Read95640() As Word
Declare Function Write95640() As Word
' VARIAVEI GERAIS
' VARIAVEIS PARA 95640
95640_CS Alias PortE.5
Config 95640_CS = Output
Dim EndressoRead_Inicio as Word
Dim EndressoRead_Fim as Word
Dim Dados_na_Eeprom_Read(8) as Word
Dim EndressoWrite_Inicio as Word
Dim EndressoWrite_Fim as Word
Dim DadosWrite_Para_Eeprom(8) as Word
' ROTINA PARA VEREFICAÇÃO DE DADOS DA EEPROM ST95640
' Whole memory 0000h - 1FFFh = 8191 X8 =64K
' CHAMA ROTINA PARA VEREFICAR SE EXISTE UMA DATA DE INSTALAÇÃO
do
'EndressoWrite_Inicio = &H0000
'EndressoWrite_Fim = &h3
'DadosWrite_Para_Eeprom=4
'DadosWrite_Para_Eeprom=Write95640()
EndressoRead_Inicio = &H0000
EndressoRead_Fim = &h3
Dados_na_Eeprom_Read = Read95640()
loop
end
' ROTINA DA EEPROM
'DEFENIÇÃO DA EEPROM
Local Eepromsize as word
Eepromsize = &H1FFF
Local Spi_read As Byte
local A As Byte
Local B As Byte
Spi_read = &B00000011 ' Read from Memory Array
Locate 1,1 :Lcd "Start Reading..."
While EndressoRead_Inicio < EndressoRead_Fim 'H0 to H3
A = High(EndressoRead_Inicio)
B = Low(EndressoRead_Inicio)
Reset 95640_CS 'Reset Portd.1
Spiout Spi_read , 1
Locate 2,1 : lcd Spi_read
Spiout A , 1
Spiout B , 1
Locate 3,1 : lcd A
Locate 4,1 : lcd B
Spiin Dados_na_Eeprom_Read(1) , 16
Locate 5,1 :Lcd Dados_na_Eeprom_Read
Incr EndressoRead_Inicio
locate 6,1 : lcd "Address: " ; EndressoRead_Inicio
locate 7,1 : lcd Dados_na_Eeprom_Read
Locate 8,1 :Lcd "Read Finished"
Set 95640_CS
Waitms 250
Wend
End Function
Function Write95640()' As Word
Local Eepromsize as Word
Eepromsize = &H1FFF
Local I As Byte
Local Write_Enable As Byte
Local Write_to_Memory_Array As Byte
Local A As Byte
Local B As Byte
Write_Enable = &B00000110 ' Write Enable
Write_to_Memory_Array = &B00000010 ' Write to Memory Array
I=1
Locate 10,1 :Lcd "Start Write..." ; DadosWrite_Para_Eeprom
While EndressoWrite_Inicio < EndressoWrite_Fim 'H0 to H3
A = High(EndressoWrite_Inicio)
B = Low(EndressoWrite_Inicio)
Spiout Write_Enable , 1
nop
Locate 11,1 :Lcd Write_Enable
Spiout Write_to_Memory_Array , 1
nop
Locate 12,1 :Lcd Write_to_Memory_Array
Spiout A , 1
nop
Spiout B , 1
nop
Locate 13,1 :Lcd A
Locate 14,1 :Lcd B
Spiout DadosWrite_Para_Eeprom(1) , 4
nop
Locate 15,1 :Lcd Write_Enable;Write_to_Memory_Array;A;B;DadosWrite_Para_Eeprom
Incr I
EndressoWrite_Inicio=I
Locate 11,1 :Lcd "Write Finished"
Set 95640_CS
Waitms 100
Wend
End Function
Compiler 2.0.7.9.001
(BASCOM-AVR version : 2.0.7.9 , Latest : 2.0.7.8 ) |
Evert :-)
Posted: Sat May 20, 2017 9:13 pm Post subject: |
And what is the problem?
Did you disabled the M103 compatible fuse? and the jtag fuse? _________________ www.evertdekker.com Bascom code vault |
Porelo
Posted: Sat May 20, 2017 11:34 pm Post subject: |
What I want is: to write data in the eeprom "st95640" in a certain address and later to read those data.
The fuses in ATMEGA128 compatible mode and the jtag disable.
I can read some data I previously recorded in eeprom on an external recorder, but I can not get the atmega128 to do this.
Thanks for the help.
I made some changes in the routine that was wrong but continued with the same problem.
$framesize = 40
'$sim
'DEFENIÇÃO DO LCD
'DEFENIÇÃO DO SPI
Spiinit
dim contador as Byte
contador =0
' VARIAVEI GERAIS
Dim Dados_na_Eeprom_Read( as Word
Dim DadosWrite_Para_Eeprom( as Word
SET portd.0 ' Back light
do
incr contador
'if contador=3 then
' exit
'endif
loop Until contador=3
end
' ROTINA DA EEPROM
Eepromsize = &H1FFF
local A As Byte
Local B As Byte
Spiout Spi_read , 1
Spiout A , 1
Spiout B , 1
Locate 3,1 : lcd A
Locate 4,1 : lcd B
Set 95640_CS
Waitms 250
Wend
End Function
Eepromsize = &H1FFF
Local A As Byte
Local B As Byte
nop
nop
Spiout A , 1
nop
Spiout B , 1
nop
Locate 13,1 :Lcd A
Locate 14,1 :Lcd B
nop
Incr EndressoWrite_Inicio
Set 95640_CS
Waitms 300
Wend
End Function |
Posted: Sun May 21, 2017 5:09 am Post subject: |
Hello
You should read datasheet again with more attention
I read only 12 pages and find this. Im sure there is more nuances to find...
Quote: | For any instruction to be accepted, and executed,
Chip Select (S) must be driven High after the rising
edge of Serial Clock (C) for the last bit of the in-
struction, and before the next rising edge of Serial
Clock (C). |
Porelo
Posted: Sun May 21, 2017 7:27 pm Post subject: |
Thanks EDC for the tip !
I read the datasheet, and I think everything is ok, but I still can not record the data, I read but I do not record, what is wrong? |
