serial port communication and analog input
Goto page Previous  1, 2
PostPosted: Sun May 07, 2017 12:01 pm    Post subject: Reply with quote
I prefer to store result from the Format function into the some variable first and then print it. Mabe this is the case. Try mod code for that.
Adc_read = Getadc(0)
   If Previous_adc <> Adc_read Then
    Previous_adc = Adc_read
     Helpw = Adc_read * 49
     Helpw = Helpw / 10
     Helpstr = Str(helpw)
     Helpstr = Format(helpstr , "0.000")
     Print "Uvor " ; Helpstr
..and maybe next improvement can be done by printing in small chunk of data (one byte) via config Serialout
'*             USART BUFFER FOR REMOTE COMMANDS                  *
  Config Serialin = Buffered , Size = 20
 Dim Char As Byte , Cmd_timeout As Byte , Got_str As Byte
 Dim Command As String * 20
 Dim Helpstr As String * 15
  Config Serialout = Buffered , Size = 30       '<- ADD THIS LINE <-
EDIT: I forget about increasing $framesize = 32 (at the top of program code). It is used when you print something and working on strings.
Because Mega328P have 2000 bytes SRAM you can increase $framesize to 64 or higher without any fear Very Happy
$framesize = 64
PostPosted: Sun May 07, 2017 2:38 pm    Post subject: Reply with quote
It is just a idea.
some years ago, sorry I didn't fund the file, because I have to do something similar, i used 2 P a big one for the main job an another for the analog measurement : a Tyny 45
In this case you can use one to control the motor(s) and another one for the main and the analog input.
JP .....now it is time to go to the votation !
Walt
PostPosted: Sun May 07, 2017 8:55 pm    Post subject: serial port communication and analog input Reply with quote
The problem is not the program. All is working fine.
The link between the PC and the Ardunio is wireless. The communication is simplex.
That the reason why print command of the ADC input was not transmitted to the PC.
If I connect the serial ports with a cable together the communication of all the signals is ok.
So I have to find a way to solve the problem with the wireless transmission.
Walter
Walt
PostPosted: Sun May 07, 2017 9:14 pm    Post subject: serial port communication and analog input Reply with quote
Thank you very much for your help.
In this constellation the new settings of the motor will not be transmitted form the PC to the Ardunio
Its an overlap the in the simplex transmission of the wireless module.
Walter
PostPosted: Sun May 07, 2017 9:23 pm    Post subject: Reply with quote
Good to know it work now.
For wireless ESP8266 WiFi or Bluetooth HC-05, BLE HM-10, HM-11(100m) work good for me Wink
Page 2 of 2
