Send sms via AT commands doesn't work
jakub.jnm
PostPosted: Fri Apr 08, 2016 10:39 pm    Post subject: Send sms via AT commands doesn't work Reply with quote
Hi all,
i am not able to figure out why i am not able to send sms via AT commands. I have atmega32 directly connected to SIM800L and using following sub routine
Sub Sendsms()
            Print "ATZ"
            Wait 3
           Print "AT+CMGF=1"
           Wait 3
Print "AT+CMGS="00000000"
      Wait 3
Print "
test2 "
      Wait 3
Print Chr(26)
       Wait 2
When i am connected via serial to sim800l module those commands are working. Can some please help?
(BASCOM-AVR version : 2.0.7.1 , Latest : 2.0.7.8 )
PostPosted: Sat Apr 09, 2016 3:45 pm    Post subject: Reply with quote
Wiring OK? Baudrate OK? Crystal Setup correctly?
Maybe try just writing a small script that blinks an LED every second (just to check the AVR is running at the correct speed). This is important as AVR's use the CPU clock to generate the clock for the UART.
Ian Dobson
http://www.planet-ian.com
PostPosted: Sat Apr 09, 2016 7:18 pm    Post subject: Reply with quote
You need to give us some more info....
Show some more code and preferably a schematic.
What does the gsm module sends back to you after the ATZ?
kimmi
Moderator
PostPosted: Sun Apr 10, 2016 3:09 pm    Post subject: Reply with quote
dont know if SIM800L use quotes (") in CMGS number but you can try it
Print "AT+CMGF=1"
Waitms 500
Print "AT+CMGS={034}+xxxxxxxxxx{034}"
Print " test2 "
Waitms 500
Print Chr(26)
Wait 5
/ Kim
jakub.jnm
PostPosted: Tue Apr 12, 2016 11:48 pm    Post subject: Reply with quote
Print "AT+CMGF=1"
Waitms 500
Print " test2 "
Waitms 500
Print Chr(26)
Wait 5
Yes, correct!! It's working now. Thx a lot
slavcio2012
PostPosted: Mon May 01, 2017 4:06 pm    Post subject: Reply with quote
Print "AT + CMGF = 1" ;Chr(13)
Bascom Ambassador
PostPosted: Tue May 02, 2017 1:57 am    Post subject: Cr/Lf Reply with quote
Do a search on M590 in this forum. You will find a SMS sender / receiver. Check the Bascom code. I am missing carriage return/line feed.
Most terminal programs sends a Cr/Lf at the end of te line.
Have fun
Ben Zijlstra
