m128can error 377
Ghitab
PostPosted: Sat Apr 08, 2017 10:56 pm    Post subject: m128can error 377 Reply with quote
Hello. Need little help, I'm stuck with this error 377 : Unexpected non numeric characters found [PORTA.0] .
e(1)=&H20+index_mesaj
e(2)=&h00
e(3)=&H0e
e(4)=&H61
e(5)=&h02
e(6)=&h36 '/////error line
e(7)=&h00
e(Cool=&H00
Bok = Cansend(4 , e(1),Cool
Config Canmob = 4 , Bitlen = 11 , Idtag = &H0300 , Msgobject = Disabled , Msglen = 8'
If I change E(6) from hex 36 into decimal 54 , I have no error, but sometime I have error on other random line too.
I have this strange error only on this at90can128 mcu, most of the code I used on another project with atmega32m1 and there I had no issue.
Why error refer to PORTA.0?
Thank you.
Bascom Ambassador
PostPosted: Sat Apr 08, 2017 11:50 pm    Post subject: Check name of your aliases Reply with quote
You have to check the name of your aliases.
Newvar alias oldvar
If you check how a variable should look like check the help.
58 is not a valid variabele name and you aliased PORTA.0 to variable 58.
Could be that I am totally wrong but can not test it on my SmartPhone.
From the help:
Variable Names
A BASCOM variable name may contain up to 32 characters.
The characters allowed in a variable name are letters and numbers.
The first character in a variable name must be a letter.
Have fun
Ben Zijlstra
Ghitab
PostPosted: Sun Apr 09, 2017 8:22 pm    Post subject: Reply with quote
Thank you Ben.
You are right, I rename output 54 to other name and now works ok.
Best regards.
