want to transfer eeprom via UART to PC... Problem with binar
boeseturbo
PostPosted: Tue Mar 28, 2017 4:51 pm    Post subject: want to transfer eeprom via UART to PC... Problem with binar Reply with quote
Hi friends,
I want to transfer eeprom from avr to pc. I tried to made it via binary format (printbin var)... That runs pretty nice, but When eeprom value is zero, the avr didnt transfer a byte to pc.
That is my problem which I have.
I want to transfer 128 byte, and when one value is zero, it is missing in data transfer. Has anybody an Idea?
  uart=inkey(#1)
  if uart =200 then
     csum=0
     for temp_byte = 1 to 128
     Readeeprom bblock , temp_byte
     printbin #1, bblock
     csum=csum+bblock
     next temp_byte
     printbin #1,csum
  end if
kind regards
Jan
PostPosted: Tue Mar 28, 2017 7:14 pm    Post subject: Reply with quote
printbin will also send a zero. it is simple to check with the simulator. (when you turn option to show as hex)
you better check your PC code.
boeseturbo
PostPosted: Tue Mar 28, 2017 10:02 pm    Post subject: Reply with quote
Okay.... mscomm.ocx didnt show zero Sad(( have to check it... thank you very much
PostPosted: Tue Mar 28, 2017 10:32 pm    Post subject: Reply with quote
To use mscomm.ocx in binary mode you have to setup it up something like this.
MSComm1.InputMode = comInputModeBinary
boeseturbo
PostPosted: Wed Mar 29, 2017 7:28 am    Post subject: Reply with quote
i used inputmode binary and also nulldiscard to false. when I use print chr(0) vb6 app didnt receive anything. Maybe it could be problem with bluetooth modul? I use HC-05 modul for data-transfer.
Also hyperterminal didnt receive zero byte.... MCS bootloader is full functional. Runs without any problems.
Cheers
here is my complete testcode:
$regfile = "xm128d4def.dat"
$crystal = 32000000
$hwstack = 400
$swstack = 400
$framesize = 400
Config Osc = Enabled , 32mhzosc = Enabled  , 32khzosc = Enabled
CONFIG EEPROM=mapped
dim temp_byte as Byte
Dim Bblock As Byte
dim uart as Byte
dim csum as Byte
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled , Hi = Enabled
Config COM3 = 38400 , Mode = asynchroneous , Parity = None , Stopbits = 1 , Databits = 8       ' use USART C0
Config Serialout2 = Buffered , Size = 255
Open "COM3:" For Binary As #1
  uart=inkey(#1)
  if uart =200 then
     csum=0
     print #1, chr(0);
     csum=csum+bblock
     next temp_byte
     printbin #1,csum;
  end if
   If uart = 123 Then
      Goto &H10000
PostPosted: Wed Mar 29, 2017 9:19 am    Post subject: Reply with quote
both print and printbin send ascii values from 0-255.
i think you can simply solve it by sending data as hex using : print hex(myByte)
then all you need to do is to 'decode' the hex ascii data back with a loop like
for b=1 to len(someString) step 2
s=mid(s,b,2)
bytevalue=val("&H" + s)
next
boeseturbo
PostPosted: Wed Mar 29, 2017 12:35 pm    Post subject: Reply with quote
Hi Mark,
i solved it. In VB6 input of mscomm must gone into an array. Than it will work Smile
Cheers
