GETRC with xmega128d4
boeseturbo
PostPosted: Fri Mar 17, 2017 3:55 pm    Post subject: GETRC with xmega128d4 Reply with quote
Hi friends,
I tried to make cap. touchsensor (I use 1k 100nF like in helpfile). This working on mega328PB very good, but same code on XMEGA128D4 isn working.
Dim W As Word
'the first parameter is the PIN register.
'the second parameter is the pin number the resistor/capacitor is connected to
'it could also be a variable!
W = Getrc(pind , 4)
Print W
W is also zero on xmega.
Has anybody a solution for this?
Cheers
Jan
PostPosted: Sat Mar 18, 2017 10:56 am    Post subject: Reply with quote
try to use a virtual port. (config VPORT0)
boeseturbo
PostPosted: Tue Mar 21, 2017 1:07 pm    Post subject: Reply with quote
Hi Mark,
can you send me a sample?
I tried this and have no luck with it Sad
dim temp as word
Config VPort0 = C
temp=getrc(Pin0,7)
print temp
end
Cheers
enniom
PostPosted: Tue Mar 21, 2017 11:03 pm    Post subject: Reply with quote
Have you seen my dog?
0
\___/
boeseturbo
PostPosted: Wed Mar 22, 2017 12:13 am    Post subject: Reply with quote
0
\___/
żżżż
boeseturbo
PostPosted: Thu Mar 23, 2017 2:05 pm    Post subject: Reply with quote
so,
I rewrite lib.... include attachment... Than it will work (in this case for Portb)...
$lib "getRc_xmega_PINB.lib"
touch=getrc(pinB,7)
Cheers
NOTE : nice to share but notice that it is not allowed to publish the libs without prior permission. MCS will check this.
you replaced code like
Ldd r22,Z+1 ; get DDRx
with
Lds r22,DDRB ; get DDRx
that is nice but not the proper way.
MSX
PostPosted: Sun Apr 02, 2017 11:40 am    Post subject: Reply with quote
I did it "by hand":
'Get  RC-Pin
Dim RC_value as Word
Config Porta.5 = Output
Set Porta.5
Waitms 10                                                  'charge cap
Config Porta.5 = Input
Config Xpin = Porta.5 , Outpull = Pulldown                  'discharge cap
While Pina.5 = 1 And RC_value < 65534
   Incr RC_value
Wend
Tada...RC_value has it
Printpix52
PostPosted: Mon Apr 03, 2017 4:41 am    Post subject: Reply with quote
MSX wrote:
I did it "by hand":
'Get  RC-Pin
Set Porta.5
   Incr RC_value
Wend
???Porta.5=output y Porta.5=input????
MSX
PostPosted: Tue Apr 04, 2017 8:26 am    Post subject: Reply with quote
Yes, right.
Porta.5 = Output to Charge the capacitor
then wait 10ms, or better 100ms
then switch the port as Input
Porta.5 = Input, and turn the avr pull-down on.
Then test how long it takes to discharge the capacitor.
