Bascom IDE Editor
16mk
PostPosted: Thu Mar 02, 2017 3:51 pm    Post subject: Bascom IDE Editor Reply with quote
Hello,
The names of registers are in lower cases in some .bas files but PINx and PORTx always change automatically into upper.
Sometimes they (registers) change into upper in whole file after changing window and return back, but after saving/closing/opening they are lower again
This situation is both with or without .cfg file.
What determine this ?
Regards,
PostPosted: Thu Mar 02, 2017 4:34 pm    Post subject: Reply with quote
the names of registers defined in the DEF file are only shown in capital. the source itself is not altered. so portB will show as PORTB.
the color is determined by the option settings.
when you open a source for a m2561 and then switch the regfile to say tiny13, only the registers known to tiny13 are shown in capital.
when no $regfile is found in the code, the registers can not be colored the right way.
16mk
PostPosted: Thu Mar 02, 2017 8:45 pm    Post subject: Reply with quote
Two different files, but almost similar.
Beginning of the first one
$lib "xmega.lib"
$regfile = "xm8e5def.dat"
$crystal = 8000000
$hwstack = 64
$swstack = 40
$framesize = 40
$baud = 4800
Osc_ctrl = &B00_1_0000_0
The same part of second file
$lib "xmega.lib"
$crystal = 8000000
$hwstack = 64
$swstack = 40
$framesize = 40
'$baud = 4800
OSC_CTRL = &B00_1_0000_0
There is $regfile in both and no errors after compiling, so the names are recognized.
