enniom
Posted: Mon Feb 27, 2017 4:18 am Post subject: XMEGA PLL Clock in 2.0.8.0 - Compile error? |
This problem is a little difficult to explain.
This code snippet has been used for some time in Bascom versions 2.0.7.8, 2.0.7.9 and 2.0.8.0. The complete program compiles and works properly in all versions when $CRYSTAL = 32MHz.
Code: | $regfile = "xm192a3udef.dat"
$hwstack = 1600
$swstack = 1600
$framesize = 1600
Osc_dfllctrl.0 = 1
Dfllrc32m_ctrl.0 = 1 'enable CALIBRATION
Const Clk_spd = 32
#if Clk_spd = 32
$crystal = 32000000
Config Osc = Disabled , 32mhzosc = Enabled ' 32 MHz enabled
Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1 'use 32 MHz
#endif
#if Clk_spd = 24
$crystal = 24000000
Config Osc = Disabled , 32mhzosc = Enabled 'internal 2 MHz and 32 MHz enabled
Osc_pllctrl = &B10_0_00011
' ^ 'Multiplication factor
'00 2mhZ
'10 PLL Source = 32MHz internal Oscillator (divided by 4 in hardware)
Set Osc_ctrl.4 ' PLL enable
Bitwait Osc_status.4 , Set 'Check if PLL is ready
Config Sysclock = Pll , Prescalea = 1 , Prescalebc = 1_1 ' configure the systemclock ---> use PLL
Waitms 2
#endif
#if Clk_spd = 40
$crystal = 40000000
Osc_pllctrl = &B10_0_00101
'00 2mhZ
Waitms 2
#endif
#if Clk_spd = 48
$crystal = 48000000
Osc_pllctrl = &B10_0_00110 ' 8MHz clock Source and Multiplication factor = 6 = 48
'00 2mhZ
Waitms 2
#endif
When the PLL is used for other clock speeds, it compiles and works properly in Bascom versions 2.0.7.8 and 2.0.7.9.
However, in version 2.0.8.0, these two errors are generated when the PLL is used:
Quote: | Error : 222 Line : 7307 Illegal character [expected (, got '' [_PRDWORD]] , in File : C:\Users\elm\Desktop\Testing\Test.bas
Error : 222 Line : -68717 Illegal character [expected (, got '' [_PRDWORD]] , in File : C:\PROGRAM FILES (X86)\MCS ELECTRONICS\BASCOM-AVR\LIB\MCS.LBX
I don't really know where to look in the code to find the statement(s) that may be causing these errors.
Any help would be appreciated.
E
kimmi
Posted: Mon Feb 27, 2017 5:46 am Post subject: |
ih,
compile no error in latest bascom version (downloaded yesterday) !
with all xtal settings
result from
Quote: | Compiler version :2.0.8.0
Compiler build :2.0.8.0.001
IDE version :2.0.8.0.006
Windows OS :Windows 10 Pro
Report : Xmega_xtal_error
Date : 02-27-2017
Time : 05:30:08
Compiler : BASCOM-AVR LIBRARY V 2.0.8.0
Processor : XM192A3U
SRAM : 4000 hex
EEPROM : 800 hex
ROMSIZE : 31FFE hex
ROMIMAGE : 342 hex -> Will fit into ROM
ROMIMAGE : 834 dec
FLASH USED : 0 %
XTAL : 48000000 Hz
Stack start : 5FFF hex
Stack size : 640 hex
S-Stacksize : 640 hex
S-Stackstart : 59C0 hex
Framesize : 640 hex
Framestart : 4D40 hex
Space left : 11542 dec |
_________________ / Kim |
Posted: Mon Feb 27, 2017 10:01 am Post subject: |
_PRDWORD was used in older versions.
So i guess you mixed up the libs. You should never mix libs/compilers/IDE. _________________ Mark |
enniom
Posted: Mon Feb 27, 2017 3:16 pm Post subject: |
Thank-you Mark and Kim.
Downloaded and installed the version 2.0.8.0 now available for download and the issue is RESOLVED! Thank-you.
Previous 2.0.8.0 version:
IDE version :2.0.8.0.004
Current 2.0.8.0 version:
Hope this helps.
E |
