NTP function
jboavida
PostPosted: Wed Feb 22, 2017 1:20 pm    Post subject: NTP function Reply with quote
I'm using the NTP function provided by Micheal (aka Six1) from this post.
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=11141
I can get the current time from the NTP servers. I had try 3 or 4 different and all work ok.
Well almost Smile I can get sync time correctly at first time (after power up).
Then if I sync again after 2 hours I get the same time as before (does not update).
Example:
Power on
Get NTP -> 09:05:21 -> Correct
After 2 hours:
Get NTP -> 09:05:21 -> incorrect -> same as last sync
Power off and on again
Get NTP -> 11:05:21 -> Correct
What i'm doing wrong?
Tks
Joaquim
jboavida
PostPosted: Wed Feb 22, 2017 8:06 pm    Post subject: Reply with quote
Got it. In the test code "M128_Protocols_Test.bas" file there was a missing "Enable Interrupts".
The NTP function "Check_Time" compares the "Local _time" with "Ntp_request_time".
"Local _time" var is increased by one in a timer interrupt every second. Since interrupts were not enabled, the timer event never fired, so the var was never increased.
So, same time forever...
Code is ok...
Joaquim
