Read Cypress Flash S25FL164K
allsetgo
PostPosted: Fri Feb 17, 2017 7:36 pm    Post subject: Read Cypress Flash S25FL164K Reply with quote
Hello
I have connected Cypress Flash S25FL164K with ATMEGA164p via SPI. I am not able to read the flash. has anyone worked with cypress flash before?
All I am doing is sending instruction ABh and as per datasheet I should get the device ID back. I have attached the datasheet for ref. Refer pg. 60, (6.6.1- Legacy Device Identification Commands)
$regfile = "M164pdef.dat"
$crystal = 14745600                                         'this freq give 0.0% error for all baud rates up to 115200
$baud = 57600
$hwstack = 80                                               'used for GOSUB addresses {default is 32}
$swstack = 80                                               'default use 10 for the SW stack
$framesize = 80                                             'space size for Registers defining variables
Config Serialin = Buffered , Size = 8
Config Spi = Hard , Interrupt = Off , Data_order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 1
Spiinit
Dim Spi_buffer As Byte
Dim Read_data As Byte
Spi_buffer = &B10101011  ' send Instruction code ABh
Reset Portb.4        ' Make CS/ low
 Spiout Spi_buffer , 1
 Spiin Read_data , 1
 Waitms 1
 Set Portb.4          ' Make CS/ high
 Print Read_data
(BASCOM-AVR version : 2.0.7.5 , Latest : 2.0.7.8 )
kimmi
Moderator
PostPosted: Fri Feb 17, 2017 10:56 pm    Post subject: Reply with quote
you must setup noss =0 and add a pin for CS sample code use portb.0 for CS
you must sent AB + 3 dumyi bytes
$crystal = 14745600
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 57600
'SPI config
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 0
Spiinit
'CS pin  setup a pin for CS
Chip Alias Portb.0
Config Portb.0 = Output
Set Chip
Dim Spi_buffer(6) As Byte
Dim Read_data(6) As Byte
Dim Inst As Byte
Declare Sub Read_id()
   Call Read_id()                                           '&HAB cmd
   Wait 5
When Used Only To Obtain The Device Id While Not In The Deep Power -down State,
shifting the instruction code ABh followed by 3-dummy bytes.
The Device Id Bits Are Then Shifted Out On The Falling Edge Of
Sck With Most Significant Bit(msb) First.
Sub Read_id()
Inst = &HAB                                                 ' send Instruction code ABh  see 8.5.2
   Spi_buffer(1) = Inst
   Spi_buffer(2) = &H00                                     '3-dummy bytes
   Spi_buffer(3) = &H00
   Spi_buffer(4) = &H00
   Reset Chip                                               ' Make CS/ low
   Spiout Spi_buffer(1) , 4                                    'sent ab + 3 dummy   see 8.5.2
   Spiin Read_data(1) , 1                                      'Read  Device Id
   Set Chip                                                   ' Make CS/ high
   Print "ID : " ; Hex(read_data(1)) ;                         ' see 6.6.1
   If Read_data(1) = &H14 Then Print "  W25q16"
   If Read_data(1) = &H16 Then Print "  S25FL164K"
This is how i write read W25Q16dv
compare it to your datasheet
$regfile = "m328pdef.dat"
$baud = 38400
$hwstack = 64
$swstack = 64
$framesize = 80
'SPI config
Spiinit
'Chip Select handling of portB.0
'If the Noss = 1, the hardware SS  internal management but are not limited,
'IMPORTANT!
'The Winbond W25Q16DV 16Mbit chip (also) organized WORD,
'So the CS rate is to be treated separately, as the HW-solving and bytes
' datasheet
'http://www.elinux.org/images/f/f5/Winbond-w25q32.pdf
'25q   mcu
'/CS : Chip
'DO  : MISO
'DI  : MOSI
'Clk : Sck
'wp & hold pullup+3,3v
'CS pin
Chip Alias Portb.0
Set Chip
Declare Sub Jedec_id()
Declare Sub Device_id()
Declare Sub Parameter_page()
Declare Sub Read_data()
Declare Sub Write_data()
Declare Sub Clear_mem()
Declare Sub Clear_pp()
Declare Sub Write_dis()
Declare Sub Write_en()
Declare Sub Stbit()
Dim Sent_data(8) As Byte
Dim Sent_p(8) As Byte
Dim read_data_tmp(8) As Byte
Dim my_data(8) As Byte
Dim Data_in(4) As Byte                                      ' the array of input data
Dim Data_out(8) As Byte                                     ' the array of 'output data
Dim Mem_p As Byte
Dim St_bit As Bit
Dim Dummy As Byte
Dim Datas As Word
Dim Data_l As Byte At Datas Overlay
Dim Data_h As Byte At Datas + 1 Overlay
Dim Address As Long
Dim Addr_l As Byte At Address Overlay
Dim Addr_m As Byte At Address + 1 Overlay
Dim Addr_u As Byte At Address + 2 Overlay
Dim Addr_x As Byte At Address + 3 Overlay
Addr_x = 0
Dim A As Word
Dim B As Byte
'  W25Q16 (2097151 bytes)  = 16 Mbit
Print "Start ."
Print "read chip id"
Call Jedec_id()
Print Hex(read_data_tmp(1)) ; Hex(read_data_tmp(2)) ; Hex(read_data_tmp(3))
Print
Print "read Manufacturer Device Id "
Call Device_id()
Print Hex(read_data_tmp(4)) ; Hex(read_data_tmp(5)) ; Hex(read_data_tmp(6))
Print
'call Clear_mem()
'test for mem write data 256 bytes write
A = 0
Print "Write 255 bytes "
For Address = 0 To &HFF Step 2
   Incr A
   Data_h = Addr_m
   Data_l = Addr_l
   Call Write_data()
   Print Hex(address) ; "h: " ; Hex(data_h) ; Hex(data_l)
Print "Writeing DONE "
Wait 5
Print "data dump: "
wait 1
For Address = 0 To &HFF Step 2                            '8191
   Call Read_data()
   Print Hex(address) ; "h: " ; Hex(my_data(1)) ; Hex(my_data(2))
Print "Reading DONE "
' Manufacturing and Memory code reading
Sub Jedec_id()
   Mem_p = &H9F
   Reset Chip
   Spiout Mem_p , 1
   Spiin Read_data_tmp(1) , 3
   Set Chip
   'Call Stbit()
Sub Device_id()
   Mem_p = &H90
   Reset Chip
   Spiout Mem_p , 1
   Spiin read_data_tmp(1) , 6
   Set Chip
   Call Stbit()
' PARAMETER PAGE
   Address = 0                                                 'Long type variable!
   Sent_p(1) = &H53                                           'read parameter page
   Sent_p(2) = &H00                                         'address 3 byte
   Sent_p(3) = &H00                                           '000000
   Sent_p(4) = &H00
   Reset Chip
   Spiout Sent_p(1) , 4
   Spiin read_data_tmp(1) , 3
   Set Chip
   Addr_u = read_data_tmp(1)
   Addr_m = read_data_tmp(2)
   Addr_l = read_data_tmp(3)
   Print "CHIP ID: " ; Read_data_tmp(1) ; Read_data_tmp(2) ; Read_data_tmp(3)
   ' address Checking
   'Parameter page deleted?
   If Address = &HFFFFFF Then                               '16777215
      Address = 0
      Print "Flash: empty "
      Wait 2
      Goto Zero
   'The memory is full? (Address = 1FFFFF)
   If Address = &H1FFFFF Then                               '16777215
      Print "Flash: full "
   Address = Address + 2
   Zero:
      Call Clear_pp()
      Sent_data(1) = &H52                                   'parameter page write
      Sent_data(2) = &H00                                   'dummy
      Sent_data(3) = &H00                                   'dummy
      Sent_data(4) = &H00                                   'address
      Sent_data(5) = Addr_u                                 'data1
      Sent_data(6) = Addr_m                                 'data2
      Sent_data(7) = Addr_l                                 'data3
      Sent_data(8) = &H00                                   'data4 -> empty because of a couple of bytes to be!
      Call Write_en()
      Reset Chip
      Spiout Sent_data(1) , 8
      Set Chip
      Call Stbit()
' RAM read
Sub Read_data()
   my_data(1) = 0
   my_data(2) = 0
   Mem_p = &H03
   Sent_data(1) = Mem_p
   Sent_data(2) = Addr_u
   Sent_data(3) = Addr_m
   Sent_data(4) = Addr_l
   Reset Chip
   Spiout Sent_data(1) , 4
   Spiin my_data(1) , 2
   Set Chip
   Call Stbit()
' RAM write
Sub Write_data()
   Mem_p = &H02
   my_data(1) = Mem_p
   my_data(2) = Addr_u
   my_data(3) = Addr_m
   my_data(4) = Addr_l
   my_data(5) = Data_h
   my_data(6) = Data_l
   Call Write_en()
   Reset Chip
   Spiout My_data(1) , 6
   Set Chip
   Call Write_dis()
   Call Stbit()
' Clear RAM
Sub Clear_mem()                                             ' clear flash ram
   Call Write_en()
   Mem_p = &HC7
   Reset Chip
   Spiout Mem_p , 1
   Set Chip
   Call Stbit()
' Clear PARAMETER PAGE
Sub Clear_pp()                                              ' clear parameter page
   Call Write_en()
   Mem_p = &HD5
   Reset Chip
   Spiout Mem_p , 1
   Set Chip
   Call Stbit()
' WRITE Disable - Enable
Sub Write_dis()                                             ' write disable
   Mem_p = &H04
   Reset Chip
   Spiout Mem_p , 1
   Set Chip
Sub Write_en()                                              ' write enable
   Mem_p = &H06
   Reset Chip
   Spiout Mem_p , 1
   Set Chip
' STATUS bit
' It will only be over when the memory of the transactions are finished!
Sub Stbit()
   St_bit = 0
   Kezd:
      Mem_p = &H05
      Reset Chip
      Spiout Mem_p , 1
      Spiin Dummy , 1
      Set Chip
      St_bit = Dummy.0
      If St_bit = 0 Then Exit Sub
      Goto Kezd
      St_bit = 0
data via comport :
[00]Start .
read chip id
EF4015
14EF14
Write 255 bytes
00000000h: 0000
000000FEh: 00FE
Writeing DONE
data dump:
00000000h: 0000
000000FAh: 00FA
000000FCh: 00FC
000000FEh: 00FE
/ Kim
allsetgo
PostPosted: Mon Feb 20, 2017 8:52 pm    Post subject: Reply with quote
Thanks Kim for your response.
'SPI config
Spiinit
' I am using SS/ pin of Atmega164p i.e. PORTB.4 as CS/ for Flash. i.e. Noss =0 ; ( The NOSS parameter with a value of 1, will not set the SS line to logic 0 when the SPI operation begins.)
I tried sending 3dummy bytes after ABh instruction although the datasheet of the flash I am using(S25FL164K) does not say that is reqd.
The MISO line is high all the time and the SPIIN reads FF. If I send on ABh and no dummy bytes, it is still high all the time.
Hardware connections:
ATMEGA164P (44pin)
MOSI (PORTB.5) to MOSI of flash
MISO (PORTB.6) to MISO of Flash
SCK ( PORTB.7) to SCLk of Flash
SS/(PORTB.4) to CS/ of Flash
Is there anything else I should look in to
kimmi
Moderator
PostPosted: Tue Feb 21, 2017 8:37 am    Post subject: Reply with quote
did you config PORTB.4 as output ?
and Set Portb.4 after config to output
datasheet say it loud & clear page 78 see 8.5.2
/ Kim
allsetgo
PostPosted: Tue Feb 21, 2017 4:19 pm    Post subject: Reply with quote
Thanks Kim
I am able to read the device ID now.
I made Noss=1 in Config SPI, and Used Set and Reset for PORTB.4
kimmi
Moderator
PostPosted: Wed Feb 22, 2017 2:37 am    Post subject: Reply with quote
Good
pls post the working code you have
for other users with same issues
/ Kim
