kimmi
Posted: Mon Feb 06, 2017 4:04 pm Post subject: |
Quote: | read data will be 4000 + count_x
4000 to 4063 |
i have just placed an order and added few 93c46 8-dip
when i get them i try to make the code read/write
it will take a few days before i get them ...
btw , did you connect 93c46 right for Pin_out & Pin_in ?
Code: | Cs Alias Portc.0
Config Portc.0 = Output
Pin_out Alias Pinc.3 <<<<<<<<<<<<<<<<<<<
Config Portc.3 = Input
Pin_in Alias Portc.2 <<<<<<<<<<<<<<<<<<<
Config Portc.2 = Output
Sck Alias Portc.1
Config Portc.1 = Output |
or
Pin_in Alias Pinc.3 <<<<<<<<<<<<<<<<<<<
Pin_out Alias Portc.2 <<<<<<<<<<<<<<<<<<<
Sck Alias Portc.1
_________________ / Kim |
jeezywonder
Joined: 19 Jan 2017 Posts: 34 Location: Russia, Vladivostok
Posted: Tue Feb 07, 2017 12:37 am Post subject: |
yeah, i checked, doesnt work anyway |
jeezywonder
Posted: Tue Feb 07, 2017 3:46 am Post subject: |
inattention - was always my problem.
Kimmi was right, problem was in wrong ports. What about the code - it works
At the moment im trying to get into "write" section of code. |
jeezywonder
Posted: Tue Feb 07, 2017 7:32 am Post subject: |
Kimmi, how to use your "write" code section , to write a data? Show me how to use it , please =)
I mean, if i want to send a command through UART, and tell to MK what i want to write and in which address.
Is it possible?
Becouse as i see the "write section" dont write any data to EEPROM. |
kimmi
Posted: Tue Feb 07, 2017 8:45 am Post subject: |
to write you set address and my_data
Code: |
Address = 1 '<<< the address to write
My_data = 600 '<<< your data to sent
'setup sent data
My_93c46 = W_93c46
Shift My_93c46 , Left , 6
My_93c46 = My_93c46 + Address ' added addtess here
Shift My_93c46 , Left , 16
My_93c46 = My_93c46 + My_data ' My_data wil be here
Shift My_93c46 , Left , 7
Call Write_data_93c46()
Waitms 10 |
to read set address and a word var for data
Code: |
Address = 1 '<<< the address to read
My_93c46 = R_93c46
My_93c46 = My_93c46 + Address ' added address
Shift My_93c46 , Left , 23
Call Read_data_93c46()
Waitms 10
in sub read_data_93C46()
we use
Code: | Shiftin Pin_in , Sck , R_data(count) , 1 , 16 , 40 |
here you can change R_data(count) to the word VAR you like to get data in
sample
Code: |
dim Got_data as word '
Shiftin Pin_in , Sck , got_data , 1 , 16 , 40 |
jeezywonder
Posted: Tue Feb 07, 2017 10:46 am Post subject: |
kimmi wrote: | to write you set address and my_data
Code: |
'setup sent data
My_93c46 = W_93c46
Waitms 10 |
Code: |
My_93c46 = R_93c46
Waitms 10
we use
sample
Code: |
Thanks, mate. I got it.
But how to make a code receive Console(like write what i need and in address that i need) commands though UART?
I thought about
but seems its wrong |
kimmi
Posted: Wed Feb 08, 2017 12:45 am Post subject: |
You can try like this:
Code: | $regfile = "m8def.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 32
$framesize = 32
$baud = 9600
Cs Alias Portc.0
Pin_in Alias Pinc.3
Sck Alias Portc.1
'Config Shiftin = New
Const R_93c46 = &B110
Const W_93c46 = &B101
Dim Synch_byte As Byte , My_address As Byte
Dim My_data As Word , Got_data As Word , Read_enable As Word
Dim Check_w As Bit , Check_r As Bit
Dim My_93c46 As Long
Declare Sub Write_data_93c46(byval 93c_addr As Byte , Byval 93c_data_in As Word)
Declare Sub Read_data_93c46(byval 93c_addr As Byte )
Declare Sub Setup_93c46()
Declare Sub Menu()
Cs = 0
' Enable serial EEPROM (EWEN):
Read_enable = &B1001100000000000
Call Setup_93c46() 'allways do this after power on !!!!
Waitms 50
Print " 93CXX READ/WRITE DATA DEMO"
Call Menu()
If Ischarwaiting() = 1 Then '
Synch_byte = Waitkey()
'SAVE DATA '
If Synch_byte = 48 Then
Print
Print "STORE DATA.."
Input "ADDRESS + ENTER " , My_address Noecho
Print "ADDR : " ; My_address
Input "DATA + ENTER " , My_data Noecho
Print "DATA : " ; My_data ; " - ADDRESS : " ; My_address ; " ..Wait... "
Waitms 25 '
Set Check_w
'SENT DATA '
If Synch_byte = 49 Then
Print
Print "READ DATA.."
Print "READING ADDR : " ; My_address ; " ..Wait..."
Set Check_r
'FOR SAVE DATA
If Check_w = 1 Then
Check_w = 0
Synch_byte = 0
Call Write_data_93c46(my_address , My_data)
My_address = 0
My_data = 0
Waitms 200
Print "OK" ; Chr(13); 'sent back info its saved with "OK"
Wait 1
Call Menu()
'FOR READ DATA
If Check_r = 1 Then
Check_r = 0
Synch_byte = 0
Call Read_data_93c46(my_address)
Print "READ DATA IS : " ; Got_data
My_address = 0
Got_data = 0
Wait 1
Call Menu()
' Enable serial EEPROM 9bits
Sub Setup_93c46()
Cs = 1
Waitms 1
Shiftout Pin_out , Sck , Read_enable , 1 , 9 , 40 ' write enable command
Cs = 0
Waitms 10
End Sub
' write address and data
My_93c46 = W_93c46
My_93c46 = My_93c46 + 93c_addr
My_93c46 = My_93c46 + 93c_data_in
Cs = 1
Waitus 1
Shiftout Pin_out , Sck , My_93c46 , 1 , 25 , 40 ' address and data
Cs = 0
Waitms 10
End Sub
'read address put it in got_data
My_93c46 = R_93c46
Cs = 1
Waitus 1
Shiftout Pin_out , Sck , My_93c46 , 1 , 9 , 40 ' address
Shiftin Pin_in , Sck , Got_data , 1 , 16 , 40 ' read data
Cs = 0
Waitms 10
End Sub
Sub Menu()
Print
Print "MENU :"
Print "PRESS 0 = STORE DATA"
Print "PRESS 1 = READ DATA"
Print
End Sub
jeezywonder
Posted: Wed Feb 08, 2017 7:13 am Post subject: |
Hi Kimmi,
What i tried to do is send address to EEPROM and the data we want to write. I'm sending by console on another PC.
I searched a help, and found
Seems like it works
Code: | Dim B As Byte
Dim A As Byte
Inputbin B
' For Count = 1 To 64 '128 Step 2 ' 1K: 64*16
' Count_x = Count - 1
My_data = B
Address = 3
'setup sent data
My_93c46 = W_93c46
My_93c46 = My_93c46 + Address 'Count_x
'My_data = 4000 + Count_x
My_93c46 = My_93c46 + My_data ' as word
' Shiftout Pin_out , Sck , My_93c46 , 1 , 25 , 40
'sent
'Next
Wait 5
End |
I send "001" therefore i writw "001" to third EEPOM memory cell, the same with address and data:
Code: | Do
Inputbin A
Inputbin B
My_data = 1
Address = B
'setup sent data
My_93c46 = W_93c46
'sent
'Next
Wait 5
End |
But how to make the both variables receive data from UART and assign it to "address" and "My_data"?
Code: | Do
Inputbin A
Inputbin B
My_data = B
Address = A
'setup sent data
My_93c46 = W_93c46
'sent
'Next
Wait 5
kimmi
Posted: Wed Feb 08, 2017 11:50 am Post subject: |
did you read help for inputbin ?
Code: | Dim Address As Byte , My_data As Word
Inputbin Address , My_data
'setup sent data
My_93c46 = W_93c46
'sent
'Next
Wait 5
End |
jeezywonder
Posted: Wed Feb 08, 2017 12:56 pm Post subject: |
kimmi wrote: | did you read help for inputbin ?
'setup sent data
My_93c46 = W_93c46
'sent
'Next
Wait 5
End |
Yeah, how it works btw?
I send a 1st message and it will asign to Address? And second message will assign to My_data? How Inputbin understands which data to aplly and to which variable?
Thanks, kimmi
PS Seems like the topic became popular, 720 views, wow |
kimmi
Posted: Wed Feb 08, 2017 6:34 pm Post subject: |
the Inputbin will wait for 3 bytes
1 byte = address (dim as byte)
2 bytes = data (dim as word) = 2 bytes
????? send message
from terminal program or other mcu ?
if other mcu its :
TX : address 25 data 4001
Code: | Dim Data_rx As Word , Addr As Byte
Data_tx = 4001
Addr = 25
Printbin Addr ; Data_tx |
RX : get address & data
'setup sent data
My_93c46 = W_93c46
'sent
'Next
Wait 5
'you get output as :
'SB OP address data not used
'1 01 011001 0000111110100001 0000000
' 25 4001 dont care
jeezywonder
Posted: Thu Feb 09, 2017 7:54 am Post subject: |
kimmi wrote: | the Inputbin will wait for 3 bytes
????? send message
if other mcu its :
Data_tx = 4001
Addr = 25
'setup sent data
My_93c46 = W_93c46
'sent
'Next
Wait 5
' 25 4001 dont care
I'm sending it from VB Console from another PC, through Com-port. Therefore i need to know which values i need to send, as i get it i have to send 22 bits, First 6 is address the another 16 is write data, OP and SB we dont count cuz we have them in code. On my Console the things equals to this:
Code: | dim Data_tx as word
dim Addr as byte
Data_tx = 5
Addr = 2
Want to write 5 in second EEPROM's memory cell, it will looks like?
Code: | ' 000010 0000 0000 0000 0101 ' 22 bits |
Sorry for long explanations from your side, but its really confusing for me to understand |
kimmi
Posted: Thu Feb 09, 2017 1:53 pm Post subject: |
This forum is about Bascom not VB
i think i helped you on the right track
so you can finish your project
a little bit of reading will do the rest for you _________________ / Kim |
jeezywonder
Posted: Fri Feb 10, 2017 1:45 am Post subject: |
kimmi wrote: | Hi,
a little bit of reading will do the rest for you |
Thanks you mate, you helped a lot.
OffTop:
(How can i contact you, in a thanks purpose?) |
kimmi
Posted: Fri Feb 10, 2017 2:17 pm Post subject: |
no need for more than thanks !
but you can allways find me in my chat if I'am online _________________ / Kim |
