krolikbest
Posted: Sun Jan 08, 2017 9:25 pm Post subject: ATMega8 i2cslave display and button |
Hello,
recently I've made one of my ATmega8 as a slave (I2C).Master is RaspberryPi. I can discover its address so far But now I would like to implement some additional operations like button and lcd display. So there is my code:
<code>
$regfile= "m8def.dat"
$crystal=8000000
config PinB.1=input
Config Lcdpin = Pin , Db4 = PortD.4 ,Db5 = PortD.5 , Db6 = PortD.6 , Db7 = PortD.7 ,E = PortD.0 , Rs = PortD.1
Config Lcd = 16 * 2
Config Twislave = &H20,Btr = 1,Bitrate = 100000,Gencall = 1
$baud = 19200
$hwstack = 32
$swstack = 10
$framesize = 40
if pinB.1=1 then
Locate 1,1
LCD "* "
end if
if pinB.1=0 then
Locate 1,1
LCD "OK"
end if
'End
Twi_stop_rstart_received:
Print "Master sent stop or repeated start"
Twi_addressed_goread:
Print "We were addressed and master will send data"
Twi_addressed_gowrite:
Print "We were addressed and master will read data"
Twi_gotdata:
Print "received : " ; Twi
Twi_master_needs_byte:
Print "Master needs byte : " ; Twi_btr
Twi = 65 ' twi must be filled with a value
Twi_master_need_nomore_byte:
Print "Master does not need anymore bytes"
</code>
But after pressing button connected to the PinB.1 nothing happens..
If I remove I2C staff it works obviously : after pressing button on the display I see 'OK' or '*'.
What is wrong?
I use Bascom-AVR 2.0.7.6, new library i2cslave, ATMega8-16PU
Martin
(BASCOM-AVR version : 2.0.7.6 , Latest : 2.0.7.8 ) |
Posted: Mon Jan 09, 2017 2:09 pm Post subject: |
A few remarks :
- please use the code tags when posting code.
- this code:
Code: | if pinB.1=1 then
Locate 1,1
LCD "* "
end if
if pinB.1=0 then
Locate 1,1
LCD "OK"
end if |
can be written as :
Code: | Locate 1,1
if pinB.1=1 then
LCD "* "
else
LCD "OK"
end if |
- you use portd.1 for the LCD , but you also use PRINT. This will disable the UART pins. SO i suggest to remove the PRINT statements. _________________ Mark |
krolikbest
Posted: Mon Jan 09, 2017 7:01 pm Post subject: |
Thank you for answer.
Of course, You are right, so i did as suggested but unsuccessful. I remarked print even removed, but nothing has changed.
But under simulator the whole program works, at least display is changing depending on button state.
OK, done!
It was really good hint with UART. I had to change PinD.0 (RxD) as well and then it works.
<SOLVED> |
