I2C PCF8574T
Dead_Banzay
PostPosted: Mon Dec 26, 2016 5:28 pm    Post subject: I2C PCF8574T Reply with quote
Help please, run the LCD 16 * 2.
I can not understand what I'm doing wrong ((
Beard does not make you a philosopher
PostPosted: Mon Dec 26, 2016 6:32 pm    Post subject: Reply with quote
Try an i2cdelay of 10, thats 100KHz bus Speed.
Your missing i2cinit in you code.
Ian Dobson
Bascom Ambassador
PostPosted: Mon Dec 26, 2016 11:01 pm    Post subject: Check address Reply with quote
PCF8474 has I2c address &h40
Try the i2c scanner for the correct address
Have fun
Ben Zijlstra
PostPosted: Tue Dec 27, 2016 8:31 am    Post subject: Reply with quote
See if your i2c bus is actually working, with a i2c scanner. Something like this:
    Dim Adress_loop As Byte
    Print  "i2c  ";
    For Adress_loop = 2 To 254 Step 2                        'Scan every even address
       I2cstart                                              'setup i2c bus
       I2cwbyte Adress_loop                                  'get result
       If Err = 0 Then                                       'err=hw problem
          Print Adress_loop ; "," ;                     'no error so device
       End If                                                'exits
       I2cstop                                               'stop bus
    Next Adress_loop                                         'loop through each sensor
    Print  ""
Bascom uses 8 bit addresses so Ben is correct, you should try &H40.
Ian Dobson
DJ7DA
PostPosted: Sat Apr 14, 2018 8:02 pm    Post subject: Port assignement ?? Reply with quote
... a little late, but still valid:
PORTC.5 = SCL
PORTC.4 = SDA
(not the other way around)
DJ7DA
