Mega2561 strange problem ONLY on Port A.6
KenHorse
PostPosted: Mon Aug 29, 2016 10:35 pm    Post subject: Mega2561 strange problem ONLY on Port A.6 Reply with quote
I use part of Port A as logic inputs in my project and have noticed a peculiar problem on only one pin:
$regfile = "m2561def.dat"
$hwstack = 400
$swstack = 550
$framesize = 345
$Baud = 9600
UCSR0A.U2X = 0
DDRA = &B1000_0011
PortA.2 = 1 : PortA.3 = 1 : PortA.4 = 1 : PortA.5 = 1 : PortA.6 = 1
For some reason, grounding PortA.6 results in a massive increase in current draw (upwards of 100 ma) but no other pins respond this way. I have noticed this all 2561's I've tried (at least 3) and even on the M128. I can find nothing in the ERRATA for either AVR. The only way to prevent it is to turn off the internal pullup on A.6
Thoughts?
PostPosted: Tue Aug 30, 2016 6:32 pm    Post subject: Re: Mega2561 strange problem ONLY on Port A.6 Reply with quote
You have a hardware problem somewhere, short-circuit to another pin, a.s.o., as the software is not the culprit.
Ah, yes, beside in case the shown is your actual code, it misses an End, without the µC may run in an unknown condition.
As the M2561 and M128 aren't pin-compatible, I do not have to ask if the same PCB was used. I'd try different designed PCBs anyway.
KenHorse
PostPosted: Tue Aug 30, 2016 6:34 pm    Post subject: Re: Mega2561 strange problem ONLY on Port A.6 Reply with quote
I only posted the relevant section of my code as the total program is several thousand lines.
As for the pin compatibility, indeed they ARE the same (you're thinking the 2560 perhaps?)
PostPosted: Tue Aug 30, 2016 6:40 pm    Post subject: Reply with quote
Yes, checked the wrong pinout.
KenHorse
PostPosted: Tue Aug 30, 2016 6:50 pm    Post subject: Reply with quote
It happens! Very Happy
I just checked my pc layout (done with Cadsoft Eagle) and that pin goes only where it should (and I checked for unintended shorts and there are none).
The M128 I used before I changed out to the 2561 behaved exactly the same way. I'll be darned if I can figure it out!
(perhaps running this through AVR Freaks might be better as perhaps this isn't a Bascom issue (but it might be the way the code is compiled!)
PostPosted: Tue Aug 30, 2016 7:27 pm    Post subject: Reply with quote
Question How do I have to understand this?
The result of the compilation is assembler code, which can be run through AVR Studio, that's what I did.
At the end of the code one checks what registers are set, if the extended memory controller isn't switched on in this case. Saw no problems.
Does the actual shown and compiled code is liable for the problem, or is it only an excerpt to be posted here?
These processors have compatibility fuses, afair these are switched on by default, did you check this?
PostPosted: Tue Aug 30, 2016 9:06 pm    Post subject: Reply with quote
you do not really think that there is code in bascom that would treat pin 6 different than other pins, right?
if you are sure that your hardware is 100% ok, the cause is inside the processor.
I advise to write to atmel support. that there is no errata yet does not mean much.
KenHorse
PostPosted: Tue Aug 30, 2016 11:38 pm    Post subject: Reply with quote
Well Mark... I wasn't picking on Bascom Very Happy
I was just wondering aloud as there was no errata regarding this issue from Atmel and as the issue was observable on several different AVRs, process of elimination and all that...
I am taking this to Atmel at this point and appreciate the comments (from everyone).
PostPosted: Wed Aug 31, 2016 6:34 am    Post subject: Reply with quote
It's a bit unsatisfying not to get response, if one tries to point out potential issues:
KenHorse
PostPosted: Wed Aug 31, 2016 4:14 pm    Post subject: Reply with quote
I have checked the fusebits and they appear to be correct as all other aspects of using the M2561 in my application work properly so I took Mark's comments to heart and will follow up with Atmel. I do appreciate your suggestions very much
