Posted: Mon May 23, 2016 11:54 am Post subject: Making DNS & NTP requests |
Instead of putting this in the web server blog
I thought I would put it separately so it can be fully explained
Both Ben and SIX1 have made code to do this
Ben for the ENC28J60
SIX1 for wiznet
But they did not break it down to a byte by byte explanation
and with some work so far I find I can use less memory to do it
I also will try to make it more portable
We need to make a DNS request to get an IP "A" record from the time server pool
then when we have that we can then ask for the time NTP request
First a break down of a DNS request for www.mcselec.com
' DNS request for www.mcselec.com
' w w w m c s e l e c c o m
' X Y 1 0 0 1 0 0 0 0 0 0 [3] 77 77 77 [7] 6D 63 73 65 6C 65 63 [3] 63 6F 6D [0] 01 01
' [3] for 3 characters [7] for 7 characters [3] for 3 characters [0] for no characters
' these will change depending on how many characters in the URL name
' X & Y are random numbers to identify the message
' last two 01 01 IP "A" record
' 0F 01 MX record
' So the bytes are
'16 bit random number ,bytes 1 & 2
'byte 3 &H01
'byte 4 &H00
'byte 5 &H00
'byte 6 &H01
'byte 7 &H00
'byte 8 &H00
'byte 9 &H00
'byte 10 &H00
'byte 11 &H00
'byte 12 &H00
'byte 13 &H03 3 characters
'byte 14 &H77 w
'byte 15 &H77 w
'byte 16 &H77 w
'byte 17 &H07 7 characters
'byte 18 &H6D m
'byte 19 &H63 c
'byte 20 &H73 s
'byte 21 &H65 e
'byte 22 &H6C l
'byte 23 &H65 e
'byte 24 &H63 c
'byte 25 &H03 3 characters
'byte 26 &H63 c
'byte 27 &H6F o
'byte 28 &H6D m
'byte 29 &H00 0 characters
'byte 30 &H01 "A" record
'byte 31 &H01 for Internet
Regards Paul
Posted: Mon May 23, 2016 3:35 pm Post subject: Nice work |
Thanks for sharing Paul! |
Posted: Tue May 24, 2016 10:45 am Post subject: |
Now a program that builds the request
then prints it to a terminal in HEX to compare it to the example
I used an Arduino M2560
Note 1194 bytes of flash without the print to terminal
Next step is to put it into a function just wish we had local arrays!
Regards Paul
$regfile = "m2560def.dat"
$baud = 19200
$hwstack = 100
$swstack = 100
$framesize = 100
Dim Buffer (200) As Byte
Dim Pos As Byte
Dim Url As String * 40
Dim Work (15) As String * 20
Dim Char As String * 1
Dim Lenurl As Byte
Dim W As Byte
Dim X As Byte
Dim Y As Byte
Dim Z As Byte
Url = "www.mcselec.com" 'use example url
' X Y 0 1 0 1 0 0 0 0 0 0 [3] 77 77 77 [7] 6D 63 73 65 6C 65 63 [3] 63 6F 6D [0] 01 01
'53360100000100000000000003777777076D6373656C656303636F6D000101
' 0F 01 MX record
' So the bytes are
'byte 3 &H01
'byte 4 &H00
'byte 5 &H00
'byte 6 &H01
'byte 7 &H00
'byte 8 &H00
'byte 9 &H00
'byte 10 &H00
'byte 11 &H00
'byte 12 &H00
'byte 14 &H77 w
'byte 15 &H77 w
'byte 16 &H77 w
'byte 18 &H6D m
'byte 19 &H63 c
'byte 20 &H73 s
'byte 21 &H65 e
'byte 22 &H6C l
'byte 23 &H65 e
'byte 24 &H63 c
'byte 26 &H63 c
'byte 27 &H6F o
'byte 28 &H6D m
'Clear buffer
For Pos = 1 To 200
Buffer (pos ) = &H00
'First two bytes are a random 16 bit number
'this is the transaction ID
Buffer (1) = Rnd(&Hff )
Buffer (2) = Rnd(&Hff )
'Now to set the flags bytes 3 & 4 Standard query = &H1000
Buffer (3) = &H01
'Now the Questions bytes 5 & 6 = &H0001
Buffer (6) = &H01
Pos = 13 'point to byte 13 in the buffer
'Split up the parts of the URL www mcselec com
Lenurl = Split(url , Work (1) , ".")
'Lenurl will = 3 so we have 3 parts to this URL
'work(1) will be www
'work(2) will be mcselec
'work(3) will be com
'now we need to go through each part
'and build up the ASCII packet
For X = 1 To Lenurl
Z = Len(work (x ))
Buffer (pos ) = Z 'find the number of characters in the part of the URL
Incr Pos 'move to the next byte in the buffer
For W = 1 To Z
Char = Mid(work (x ) , W , 1)
Buffer (pos ) = Asc(char )
Incr Pos
Buffer (pos ) = &H00 'no more url's
Incr Pos
Buffer (pos ) = &H01
Incr Pos
For X = 1 To Pos
Print Hex(buffer (x ))
Posted: Thu May 26, 2016 9:50 am Post subject: |
Now moving it into a function
still some more work to be done but it works
$baud = 19200
$hwstack = 100
$swstack = 100
$framesize = 100
Dim Work (5) As String * 20
Dim Result As String * 40
Dim Urls As String * 40
Declare Function Dns_req (byref Url As String * 40 ) As String * 40
' Url = "www.mcselec.com" 'use example url
' 0F 01 MX record
' So the bytes are
'byte 3 &H01
'byte 4 &H00
'byte 5 &H00
'byte 6 &H01
'byte 7 &H00
'byte 8 &H00
'byte 9 &H00
'byte 10 &H00
'byte 11 &H00
'byte 12 &H00
'byte 14 &H77 w
'byte 15 &H77 w
'byte 16 &H77 w
'byte 18 &H6D m
'byte 19 &H63 c
'byte 20 &H73 s
'byte 21 &H65 e
'byte 22 &H6C l
'byte 23 &H65 e
'byte 24 &H63 c
'byte 26 &H63 c
'byte 27 &H6F o
'byte 28 &H6D m
Urls = "www.mcselec.com"
Result = Dns_req (urls )
'print buffer to terminal in HEX format
'to confirm result
For X = 1 To Pos
Function Dns_req (byref Url As String * 40) As String * 40
Local Pos As Byte
Local Char As String * 1
Local Lenurl As Byte
Local W As Byte
Local X As Byte
Local Y As Byte
Local Z As Byte
' Print Urls ; " url"
'Clear buffer
For Pos = 1 To 200
Buffer (3) = &H01
Buffer (6) = &H01
For X = 1 To Lenurl
Z = Len(work (x ))
For W = 1 To Z
Incr Pos
Incr Pos
Incr Pos
End Function
Posted: Mon Aug 08, 2016 5:24 pm Post subject: NTP? |
Paul
Any luck on the NTP?
Have fun
Ben Zijlstra |
six1
Posted: Tue Aug 09, 2016 7:55 am Post subject: |
Hello Ben , six1
Been busy with other things have not tested my DNS yet against a server
So I am yet to get on to the NTP
Regards Paul |
