e-doc
Posted: Tue Jul 12, 2016 11:22 pm Post subject: |
You recommend to build this dongle below?
Which settings are correct to use it under BASCOM?
Is there a chance to get the 5V-supply from the LPT-port?
What's the function of D1? Just reverse polarity protection for the line driver 74HC244?
Is 74HC the correct "family" regarding the logic levels?
I thougt LPT and AVR levels are TTL, so shouldn't be 74HCT or 74LS better choice?
http://hw-server.com/parallel-port-lpt-ieee-1284#signaly |
Printpix52
Posted: Tue Jul 12, 2016 11:54 pm Post subject: |
Hi!!
My programmer have long had working well and now my port probe my programmer is LPT3-3BC-STK200 / STK300 not detect the microcontroller is the same flaw that says my companion.
Today I'm using STK500 works well !!
[img][/img] |
Plons
Joined: 24 May 2005 Posts: 435 Location: Hilversum - The Netherlands
Posted: Wed Jul 13, 2016 12:23 am Post subject: |
e-doc wrote: Quote: | You recommend to build this dongle below? |
No.
But at the bottom of that webpage I give a list of things you can do when the LPT programmer doesn't work.
And the Sample Electronics programmer is just another version of the PPPPD. _________________ Bascom AVR ver 2.0.8.6
Dragon-lair: http://www.aplomb.nl/TechStuff/Dragon/Dragon.html
"leef met vlag en wimpel, maar hou het simpel" |
e-doc
Posted: Wed Jul 13, 2016 12:45 am Post subject: |
albertsm wrote: | you might want to add some delay to the settings. this depends on the clock speed of the micro. |
I tried values between 0 to 2000.
Reading uC-ID did not work.
albertsm wrote: | but it is also important you can read the busy signal correct.
also, you could try lower resistor values. i had to decrease to 220 or 100 for some lpt cards. but when busy reads correct the used resistor value is ok. |
I tried values between 100 Ohm to 1.5 kOhm, which works OK.
2,2 kOhm is too high, /busy signal not recognized.
So 470 Ohm should work.
Plons wrote: | e-doc wrote: Quote: | You recommend to build this dongle below? |
No. |
Ah, OK, thanks for clarifying this. I was thinking about to build it.
Plons wrote: | But at the bottom of that webpage I give a list of things you can do when the LPT programmer doesn't work. |
Do you mean this?
Quote: | Unpack the RegistryFix, read the info, and implement the register-change (it can be undone, but make a "Restore point", just to be safe ... )
The attachment comes from Kanda.com. It can be found on their website, but it's not simple to find.
Background info: from SP2 and on, WinXP checks the Parallel Port every minute or so to find out if the user attached a printer. That interferes with our use of the PP. The registry-patch ensures that the PP is still checked, but only during a Power-up sequence. |
Plons wrote: | the Sample Electronics programmer programmer is just another version of the PPPPD. |
I can't believe setting "Sample Electronics programmer" should work with this dongle, because of very different usage of the LPT pinout.
Your dongle looks more like a modified STK200, correct (?)...
I like your dongle, I think I will build one.
Can you explain please, what is the function of Q1? |
Posted: Wed Jul 13, 2016 9:19 am Post subject: |
do you have a new chip to test? maybe the chips you use , were used with an external oscillator. in that case it will never work : you have to apply a clock signal to the xtal input pin to make it work.
while you can build another lpt programmer, that is a complete different topic. i leave this topic. good luck with it. _________________ Mark |
e-doc
Posted: Wed Jul 13, 2016 11:21 am Post subject: |
I also tried with an external crystal.
I did not have a 8MHz or 4MHz, only 3.5MHz, but I read somewhere, the frequency doesn't matter for programming.
Yes, I will try another chip, maybe this one has a problem... |
Plons
Posted: Wed Jul 13, 2016 11:54 am Post subject: |
I didn't say that setting "Sample Electronics programmer" should work with this dongle.
Isn't that on the page ?
Both use the LPT-port. The recommendations are for the LPT-port and therefor apply to both programmers
I like your dongle, I think I will build one. Wink
You don't read/listen. Building the PPPPD will not help to solve the problem you are having now.
The function of Q1 is explained in the text .... it's a level shifter
Note to self: take that webpage offline ... it's just a drain of time and energy. _________________ Bascom AVR ver 2.0.8.6
Posted: Wed Jul 13, 2016 12:54 pm Post subject: |
Quote: | I also tried with an external crystal. |
you need to apply a clock signal. for example from a clock generator, or from a simple 555 generator.
just a crystal will not be sufficient if an external oscillator is selected. _________________ Mark |
Plons
Posted: Wed Jul 13, 2016 1:00 pm Post subject: |
e-doc wrote: | I also tried with an external crystal.
The fuse setting of your AVRs is unknown; therefor
1. ISP could be disabled
2. Clock options could be set for external clock
and more ...
I think you should have mentioned in this thread that your AVR's are not factory-new.
edit: a few minutes late ... _________________ Bascom AVR ver 2.0.8.6
e-doc
Posted: Wed Jul 13, 2016 1:41 pm Post subject: |
albertsm wrote: | Quote: | I also tried with an external crystal. |
just a crystal will not be sufficient if an external oscillator is selected. |
OK, I have several clock modules I could check.
Is it correct that the clock frequency doesn't matter (not too low and not over the max. clock)?
Plons wrote: | I think you should have mentioned in this thread that your AVR's are not factory-new. |
I first had to solve the LPT problem.
My AVRs are new, but maybe pre-programmed by manufacturer (they are industry remnants).
Plons wrote: | You don't read/listen. Building the PPPPD will not help to solve the problem you are having now. |
Reading/listening and understandig are two different things.
I'm not a native english speaker and my school english is very rusty, sorry for that...
Anyway - thanks for all your help! |
e-doc
Posted: Thu Jul 14, 2016 7:49 am Post subject: |
Update/feedback to clean up the chaos I left in this thead:
At the end I managed to read out uC-ID and fusebits:
e-doc
Posted: Thu Jul 14, 2016 8:15 am Post subject: |
uC-ID is almost correct:
Read out Mega88P, actually it is Mega88PA (don't know if the difference matters).
Checking driver list:
giveio.sys - didn't work -> removed
inport32.sys - installed and used by LPT port test utility (X-Lent-Electronics)
ptilink.sys, raspti.sys, parport.sys - installed and used by windows XP
tvicport - installed and used by BASCOM-AVR, same version as downloadable from makers website
The only way I could make it work:
- removed crystal from uC
- start LPT port test utility (by X-Lent-Electronics http://www.xlentelectronics.nl/LPTTest/LPTTestUtilx64r.htm)
- choose correct LPT base address (378h for LPT1 or whatever you selected in BIOS before, ECP or EPP mode)
- close LPT port test utility
- power up uC (5V external supply)
- start BASCOM-AVR
- choose programmer "sample electronics cable"
- choose correct LPT address (378h)
- load any project or create any new code
- menu "program/send to chip"
- identify chip
- read out fusebits
- check empty chip -> OK
Changing only one of these points results in BASCOM cannot identify chip and cannot read out anything.
I checked this repeatedly, it is reproducable.
This shows:
- LPT hardware is OK
- programmer cable works
- connections to uC are correct
- power supply is correct
- uC is not locked
I think Tvicport maybe not initialized correctly by BASCOM-AVR 2.0.7.5. demo.
LPT port pins stay in "hi-z-state" and do nothing BASCOM want them to do.
If initialized by starting LPT port test utility, the status changes to "in/output mode" (changes to correct high or low level) BASCOM-AVR can controll LPT correctly.
Can you please check this, Mr. Alberts? |
Posted: Thu Jul 14, 2016 9:25 am Post subject: |
it works fine with my version. it could be the other driver you use/need on your system, or it could be the demo. maybe someone else can try it . i only perform tests on the latest version.
I did not found any notes about a problem with the sample electronics programmer. _________________ Mark |
e-doc
Posted: Thu Jul 14, 2016 1:09 pm Post subject: |
albertsm wrote: | ...or it could be the demo. maybe someone else can try it .
It would be nice if anybody could check it.
I removed all drivers except Microsoft and the 2 required drivers, so I think it could be an issue with the demo 2.0.7.5.
Is there a newer beta or older demo version I could check? |
Printpix52
Posted: Fri Jul 15, 2016 1:23 am Post subject: |
The demo version 1.11.98 5 years ago worked fine but the latest does not work 2.0.7.5.
And you have the same fault probe your.
Watch my video when started 5 years ago ....
https://www.youtube.com/watch?v=XzrAA3JO-gA |
