superbrad
Posted: Wed Mar 15, 2006 4:42 am Post subject: VS1002d Code |
Here's some VS1002 code. Thought maybe somebody might like it or be able to use it. I was actually surprised at how easy it was, I mean even I got it .
I used a SparkFun VS1002 breakout board and an M128L running at 3.3V to make the hardware simple. Here's what's hooked up to it:
Lines connected to the MCU:
SO -> Pinb.4
SI -> Portb.5
SCLK -> Portb.7
CS -> Portb.6
RST -> Porte.7
DREQ-> Pine.6
Remaining lines:
BSYNC -> 100K Pullup to Vcc
TX -> NC
RX -> 100K Pullup to Vcc
GND -> Vcc (WHOA! Just kidding, geez ... connect to GND)
Right, Left, Buff -> Stereo jack
MICP-MICN -> NC
GPIO0-GPIO3-> NC
Vin+ -> 3.3V
Remember I used the breakout board. If you are using your own board or a different breakout board, you're on your own for pinouts.
Have fun. If anybody has any suggestions or improvements, feel free to post.
Brad
Edit: All the includes come with the latest version of BASCOM-AVR and should be available in the Samples -> AVRDOS folder under your BASCOM directory. I usually just save my AVR-DOS projects into that folder so the includes are right there without a lot of copies of them scattered around my hard drive.
papa_of_t
Posted: Wed Mar 15, 2006 11:17 am Post subject: |
Hi, i had a look inside. I don't understand description "This file plays an MP3 file with a VS1002 chip from an MMC card (via AVR-DOS)." but the program is for displaying something (only)?
And also: Is is possible to get your includes (Config_MMC.bas, Config_AVR-DOS.BAS, fs_interpreter.bas) somewhere for free? i doubt.. _________________ Carsten,
with greetings from the nice city of Berlin |
george2002
Posted: Thu Mar 16, 2006 12:52 am Post subject: |
hi i downloaded newest version of bascom 1.11.8.1 and i cant find that code for driving vs1002 chip where is it ?
ps sry in opera i didn't saw correct this page and attahments and i was not logged in _________________ Hi 4 all
superbrad
Posted: Fri Mar 17, 2006 8:49 pm Post subject: |
Just a note - The above code has been corrected. It is now code that initializes the VS1002d and sends an MP3 song to the chip from an MMC card. Have fun!
- Brad |
george2002
Posted: Sat Mar 18, 2006 11:10 am Post subject: |
superbrad do you have bascom code to drive vs1001 ? because i got him from some time and now i have some time to get it working but if you chave some code to drive him that will helps me much _________________ Hi 4 all |
superbrad
Posted: Mon Mar 20, 2006 5:02 pm Post subject: |
George, the code is already posted above. Log in and you will be able to see it and download it.
- Brad |
george2002
Posted: Mon Mar 20, 2006 7:26 pm Post subject: |
yeah ok i logged in and downloaded that mmc-vs1002.bas but does it support vs1001 chip ? does this code will drive vs1001 too ? or only vs1002 ? do you have bascom example to drive vs1001 chip ?
thx in advice
george2002 _________________ Hi 4 all |
superbrad
Posted: Mon Mar 20, 2006 9:32 pm Post subject: |
It shouldn't be too different from the VS1001, but I can't say for sure what or how much is different as I don't have one and probably won't be getting one. A good place to start would be to check the datasheet. I know there's a significant difference with the BSYNC line that you would need to change to send data, but other than that, I don't know. Also, you'll need to change the crystal speed in the initialization subroutine to match whatever crystal you're using.
Good luck,
Brad |
george2002
Posted: Mon Mar 20, 2006 11:12 pm Post subject: |
thanks for replay now i'm studying datascheet and setting up ports and pins
i have last question to you brad, do you tested bigger sample bit rates then 8000Khz like 441000Khz ? can atmega drive that speeds ?
thanx for info
best regards
superbrad
Posted: Tue Mar 21, 2006 1:39 am Post subject: |
Yes, the file info about the MP3 I was testing it with was:
Under Pressure by Queen/David Bowie
Bitrate: 128 Kbit/s
Sample rate: 44100 KHz
It sounded very clear - I had an M128 running at 8 MHz with it reporting the state of the DREQ pin to an LED. It seemed as though it was only running it at about half load (but that's just judging by sight). I had it running at 4 MHz just fine as well, so I'm pretty sure you should be able to get it working pretty good.
Also, VLSI has an application notes PDF on their website - it was very helpful. It points out a lot of differences between the different versions of the VS series of chips.
Good luck,
Brad |
george2002
Posted: Tue Mar 21, 2006 1:57 pm Post subject: |
thanks for info
i just downloaded those aplication notes and starting to study them, anyway thanks for helping me much
regards
papa_of_t
Posted: Tue Mar 21, 2006 5:36 pm Post subject: |
Hey superbrad - this is a great example! Thank you very much. I am just waiting for my Sparkfun breakout board and then i will follow you _________________ Carsten,
Gmccomb
Posted: Sun Mar 26, 2006 7:51 pm Post subject: |
Superbrad, Many thanks for the code.
Alas, I find I'm having some compile errors, and am not sure why. I've left your file as-is. In 1.11.8.2, I'm getting the follow errors upon compilation (I've edited out the paths to the fs_interpreter.bas file to make the error listing easier to read):
Code: | Error : 242 Line : 639 Source variable does not match the target variable [ 0] , in File fs_interpreter.bas
Error : 15 Line : 640 Wrong datatype [ 200:getclassname] , in File : fs_interpreter.bas
Error : 15 Line : 646 Wrong datatype [ 200:getclassname] , in File : fs_interpreter.bas
Error : 15 Line : 1147 Wrong datatype [ 305:getclassname] , in File : fs_interpreter.bas
Error : 242 Line : 1637 Source variable does not match the target variable [ 0] , in File fs_interpreter.bas
Error : 242 Line : 1654 Source variable does not match the target variable [ 0] , in File : fs_interpreter.bas |
I put the mmc-vs1002.bas file in the same directory as all the other AVR-DOS files. The HW stack etc. have been changed to >128 (tried 128 for some, 256 for others, as in the other AVR-DOS examples, no change).
I noted that the DOS test example included the following function declaration (and corresponding function), and when added, the "Source variable does not match..." error was quieted, but not the others:
Code: | Declare Function Getattr0() As Byte |
Commenting out the include for fs_interpreter.bas removed all the errors, as one would imagine.
Any ideas?
-- Gordon |
papa_of_t
Posted: Mon Mar 27, 2006 10:52 am Post subject: |
Hi superbrad,
i'm still waiting for my sparkfun board , meanwhile i made some preparations and calculations - Question is if you ever tested microphone recording and if my thoughts are ok:
I want to use the best recording quality that i can get, and in my mind it is 24kHz sampling rate, expecting 12KByte (96 kBit) /second data stream - is it right in your eyes?
(onboard xtal = 12.288MHz, clock doubling -> Fc = 24.576MHz, d = 4 (minimum) -> Fs = 24576 / (256 * 4) = 24.000 ? -> 16 bit and 4:1 compression -> 12kByte(sec?) _________________ Carsten,
superbrad
Posted: Mon Mar 27, 2006 6:56 pm Post subject: |
Hi guys,
Gordon:
I'm not sure why AVR-DOS has problems with that. I was thinking maybe it was just a problem on my computer, but I guess not. I've never been able to get it to work without messing around with the FS_Interpreter.bas file. It seems as though it needs this file to work properly (even though it will compile without errors it won't work in my experience), but I have to edit out the lines inside the FS_Interpreter file that contains those errors to get it to compile OK. I believe this limits some functions of AVR-DOS, but they're not in use in the program anyways. And it never really compiled OK, it always leaves an error BUT - the way to check it is if it shows the "34% Flash Used" screen (or whatever amount of flash it is). This means it's written the binary file and you can send the program to the chip.
Also, I got errors any time I set any stack setting above 128, but 128 for all three settings seemed to work just fine.
Like I said, just try commenting out the lines that give you errors one at a time in the FS_Interpreter.bas file. I know it's not a clean solution, maybe Josef can shed a little light on this problem. Good luck with that - let me know if you need more help. I can send you my AVR-DOS files if necessary.
I imagine this is most likely a memory allocation problem. I'm in the process of adding XRAM to see if I can alleviate the problem.
Pops:
Sorry, I haven't gotten around to testing out the microphone. I intend to some time, but I probably won't get around to it for a few more weeks. Good luck!
Brad |
