AndersL
Joined: 25 Jan 2010 Posts: 93 Location: Kragerø,Norway
Posted: Wed Jun 22, 2016 12:53 pm Post subject: LORA |
Hi all,
This is a working sample using the Lora SX1272 modules from Semtech. I’ve used Dorji DRF1272F modules at 868MHz and 900MHz.
There are a lot of info regarding Lora on the net, so go there for info.
Code is crude and not fully debugged, but working.
Tested to work with one module inside my house as TX and the RX with LCD into the woods 500 meter away.
This was on the lowest datarate and +17dbm.
Antennas used was 8 cm magnet wire whip.
I've ordered some more for 433MHz to test on and expect them to go even further. _________________ Anders |
Posted: Wed Jun 22, 2016 4:27 pm Post subject: RN2483 |
Thanks for sharing. Very nice.
Have done some testing with the RN2483 on 868 Mhz. A very small pitch to solder.
Found some break-out boards.
Got some testresults.
Have fun
Ben Zijlstra |
Posted: Thu Jun 23, 2016 11:33 am Post subject: |
Hi Anders,
Thank you for sharing. LORA is indeed very interesting. Good to have your code  _________________ Mark |
dk9uv
Posted: Fri Aug 12, 2016 10:35 am Post subject: |
Hi Anders,
thanks very much for the code.
I do have a couple of spare boards with RFM95, ATmega328 and FT232 USB from a student project
with documented and working C code, but would be interested in a BASCOM solution.
Do you probably have experience with the RFM95?
I will try your code with these boards (if you are interested I can send you a board).
With best regards
Chris |
AndersL
Posted: Mon Aug 22, 2016 12:08 pm Post subject: |
I recently ordered a pair of RFM95 to test, but afaik it's the same series as RFM98 witch should be the same chip type as SX1278.
The code attached is working for SX1278, and should be usable for the RFM95 (just edit the frequency)
I'll share my test when the RFM95's arrive. _________________ Anders |
EKO_BUDIANTO
Posted: Sat Jul 15, 2017 6:27 pm Post subject: |
Hi Anders
Can you ask for the wiring diagram?
Is the connection from SX1278 to ATmega328 only 5 pin?
Only GND, 3.3V, MOSI, DIO1 and DIO5 ?
Can I ask for the wiring diagram?
Thanks |
luc.goossens
Posted: Fri Jan 05, 2018 3:49 pm Post subject: Re: LORA |
[quote=\"AndersL\"]Hi all,
I\'ve ordered some more for 433MHz to test on and expect them to go even further.[/quote
Hi Anders,
Do you have a schematic on how you wired up the module to the controller?
This might help us out, as I\'m planning on using these modules on a Mega32
Thanks,
Luc |
Mortezayavari1366
Posted: Thu Mar 23, 2023 8:59 pm Post subject: |
AndersL wrote: | Hi,
I'll share my test when the RFM95's arrive. |
Hi Anders
I used your code for chip SX1278 for module LORA RA-02. But the reciever receives only one character.
Is it a problem with the program or module RA-02? |
